Forums-Treffen auf der L&B 2016
WICHTIG: Die Registrierungsfrist für das Forums-Treffen auf dem GIRA-Stand am Montag, den 14.3. läuft:
Bitte anmelden unter: Forums-Treffen L&B 2016 im Service-Bereich.
SmartHome.py Monitor
  • SmartHome.py Monitor
    Hi, I'm Stefano from Italy.
    I have a working smarthome.pi installation updated to Smartvisu 2.7. I had to fix io_smarthome.py.js to get it working.
    In SmartHome.py Monitor I see no data:
    Do I made some mistake?
    Thanks
  • #2
    Hi Stefano!
    You have to define the needed items within your smarthome.py configuration.
    The file "smarthome.py.html" in the "pages/base" directory contains at the end a comment with the uses items.
    hope that helps
    Regards
    Rhaegar
    • #3
      Thank you!
      It's not completely clear: have I to create a new item in smarthome/items folder? Or what else?
      • #4
        Thank you!
        Yes. If you use the "old" smarthome.py version (0.9).
        In version 1.0 of smarthome.py the needed items are already defined and registred.
        Regards
        Rhaegar
        • #5
          Ok, so this is the problem, I have 0.9.
          I update from smarcontrol page, and check here https://github.com/mknx/smarthome/tags but I can't find v 1.0
          Why?
          • #6
            Hi Stefano,
            welcome to the community.
            Just wait a little bit. 1.0 will be released soon. I have to do some final tests and then i will release 1.0 and a new Pi-Image.
            so long
            Marcus
            • #7
              Ok, I'm not in rush
              Just one clarification: could I update all my rasp machine via SmartControl page or will I need a new installation?
              Thanks
              • #8
                Why?
                Version 1.0 is "on the way". Probably you can download the new complete (beta) image for the raspberry (http://knx-user-forum.de/smarthome-p...rthome-py.html)
                Or, if you can't wait until the release of 1.0: With 0.9 you can
                alternately use this "http://knx-user-forum.de/smarthome-p...-auslesen.html"
                all you have to do is to rename the items, so they match the names in the smarthome.py monitor and you have to define the items for sun and moon data (rise, set, position, moonphase, moonlight). This is described in the "smarthome.py" documentation.
                bye
                rhaegar
                • #9
                  Hi Stefano,
                  you have to use the new image, but you could import your configuration and visualization via smartControl.
                  so long
                  Marcus
                  • #10
                    Great! Thank you all!
