Zitat von TRex
9039 Datum+Uhrzeit Logikbaustein
pour mon ami Warichet
je la faite pour tois.
tu le trouve sous logic\Hoegg\Wochentag
PeterAngehängte Dateien
I'm using Baustein 9039Zitat von TRex Beitrag anzeigendo you have an Array in the Group-Adress from 0-128?
the value today (17.2.2011) have to be 3
I think I got it right now, by just adding 1.Angehängte Dateien
If you have an GA with legth of 1-Bit it will be always 1
Thank you for the hint
I've added 1 to the output A7, and have the week start with 1 on mondayZitat von TRex Beitrag anzeigenA7 is Day of Week from 0 to 6
0 ist Monday, 6 is sunday ...
Hey Warichet,
I had sent you but xxAPI the demo project. So it's mentioned.
Uwe
like in Python the Time(6)
Now you have the counter and you make an object with Text to select the day. (dynamic text)
then take the 0 to monday, 1 to tuesday...
I must be blind (and the search also)
no track of "Wochentage"
could it be the 17775 Textselektor ???
Thank you for the hint, sounds good.Zitat von EPIX Beitrag anzeigenI use the dynamic Text "14-Byte Textanzeige Wochentage" to transfer the numeric Value into a Text...
By modifying the dy.Text you could realise any language to be displayed instead of "Montag!
Where can I find this module ? I looked in the Download .... no luck
Maybe it has another name ?
I would also display the day-of-the-week in the Visu.Zitat von Wasserkocher Beitrag anzeigenIch nutze den Baustein 9039 Datum+Uhrzeit (wochentag 0-6) um in meinem Visu header den Tag und das Datum generieren zu lassen
So far, I can display date and time, but not the day-of-the-week.
I cannot find Baustein 9039, looks like an internal ?
I've seen a hint to the Baustein of Tilo, but I'm unable to make it work.
The only KO I can see is the numeric value for day-of-the-week , I'd like to display Monday instead of 1.
Thanks
ahh verdammt sofort ins schwarze! Der Variablen Bereich wars!!!
vielen Dank Marcel!!!
Hallo Fabian,
hab den Baustein auch in Betrieb und funktioniert einwandfrei.
Hast im HS eventuell die Werte limitiert? min=1 oder so?
Marcel
