Baustein: 13665_SamsungTV (free!)
    Hello,
    I developped my own (unlimited and free!) SamsungTV building block.
    • Since the other building block (https://service.knx-user-forum.de/?c...nload&id=11881 by Alexander Kirpal) didn't work with Experte >4.5 and wasn't free.
    • Some of you might also use the same functionality via the Babtech Appmodule (with Samsung App), however, that isn't free either
    • This works native on homeserver (tested with 4.5 - 4.8) and is free!
    I didn't tested it with Samsung >2016 models (Tizen OS), it might need a different connection method, but that's for v2.0
    Download: https://service.knx-user-forum.de/?c...nload&id=13665
    Zitat von Roeller Beitrag anzeigen
    Hello,
    Hello Roeler,
    Right now i have tested this with the Samsung UE65LS03N (Tizen based as far as i can see) and the module doesn not work as expected.
    Looking forward to your version 2.0
      Hi Cevers,
      Within one or two months I'll have time to take a look at it..
      Roel
        Hi Cevers,
        Roel
        No rush, already happy someone is working on it.
        The client sees this more as an "extra" anyway
          I’m also interested in a new block that works with newer models, and with firmware 4.9
            This block works with Firmware 4.9 but not with the Tizen TVs.
              hello i am very interested in the 2.0 version. My TVs are all J series.
              Greetz
              Besten Gruß
              norman
                Hi all,
                it tried to use it with one Samsung UE43NU7090, but no chance to get it working.
                Roeller : Is there any chance that you'll (or someone else) get it working again (also with newer TV models)?
                BR, Chris
                Zuletzt geändert von MatthiasS; 22.12.2020, 16:21.
                  Hallo zusammen.Ich habe den Baustein gerade gegen den von Hr. Kirpal ersetzt.
                  Bei mir läuft der Baustein. Experte 4.11.2
                  Tv Samsung UE55F6500.
                  Hoffe das so ein Baustein auch für neuere Modelle gepflegt wird.
                  Danke dafür.
                  Funktioniert einwandfrei.
                    steveoutoe Du meinst, Du hast den Baustin von Roel eingebaut und den von Alex Kirpal ausgebaut? Nicht, dass jemand auf die Idee kommt, es genau umgekehrt zu tun ;-)
                      Moin Ja genau so...
                      Missverständlich Ausgedrückt.
                        Moin zusammen, gibt es inzwischen auch eine Möglichkeit für neuere Geräte mit dem Tizen Betriebssystem ?
                          Das würde mich ebenfalls interessieren. Es gibt von Samsung die MDC (Multi Display Control) Dokumentation und dort ist schon sehr viel möglich - aber leider nicht über http, sondern nur über einen TCP/IP Async-Mode.
                            ich habe den Baustein auch heruntergeladen; danke dafür. Ich bekomme die Funktion bei mir aber nicht zum Laufen...Wie muss ich den Ausgang definieren? Vielleicht kann mir jemand helfen...
                            Vielen Dank und Gruß,
                            Markus
                            ​image.png​
