Auf der Suche nach einer Wetterstation
  • Gaston
    Zitat von Warichet Beitrag anzeigen
    So, you've already done the low-level hardware interface ! If I remember well, it is a RS485. Next, I guess you do a Webabfrage to capture your data in the HS.
    Nope, i'm no friend of tinkering. The interface is a TCP/IP datalogger which is either plugged into a special receiver device (Envoy) or into th estandard console.
    My needs are moderate (my budget as well )
    Well, the Vantage pro is not for moderate needs
    Temperature -> No problem of course. The VP exists in normal and active flavors, where the active one has a fan to reduce the effect of the sun on th etenmperature measurment. Also th einside temperature is measured and a possibility to extend with additional sensors
    Luminosity (Brightness) -> The VP does not really measure the brightness but the energy (Watt/m2) and the UV index (I think this is only th ePlus variant)
    Wind speed + Wind direction -> yep
    Rain sensor + Rain volume measure (pluviomètre) -> Rain rate and quantity are measured at 0.2mm intervals (european version)
    Air humidity (Luftfeuchte, humidité atmosphérique) -> relative humidity is measured in % (inside and outside)
    Air pressure (Luftdruck, pression atmosphérique) -> included
    Dew point (Taupunkt, point de rosée, although it can be calculated) -> has to be calculated anyway
    I know the Vantage Pro can do all that, plus much more, but I don't need the extra stuff.
    I should have read this first
    Python ?!? It sound like you've written a Baustein to cope with the weather station ?
    Yes, this is correct. The function module will directly cature the data via TCP from the datalogger at programmed intervals.
  • Warichet
    Zitat von Gaston Beitrag anzeigen
    It is quite sure it will work.
    I have a fully configured Vantage Por 2 Plus Active with additional sensors for leaf wettness, 3 soil temperatures and 1 soil wettness as well as a heating to measure snow as well.
    The values I'm considering are:
    Temperature
    The reading of the current values does completely work at this time from python.
  • Gaston
    I'm very interested in the outcome of your work.
    I already noticed the Vantage Pro as an excellent device. No KNX device does fullfill my needs. This is not a critic, as those devices are designed for building management and my needs are rather beyhond simple building management.
    Hi Raymond,
    It is quite sure it will work. It has to, as I have a fully configured Vantage Por 2 Plus Active with additional sensors for leaf wettness, 3 soil temperatures and 1 soil wettness as well as a heating to measure snow as well.
    So far I develop it ouside the HS to reduce the need to upload and wait for the HS to restart for debugging. The reading of the current values does completely work at this time from python. The station does transmit about 70 values for a station configured with the maximum of sensors.
    I will probably not implement the 200+ Hi/Low values downloadable as well as the archive of recorded data as the homeserver is not expected to be down a lot so these can be evaluated inside the HS
    Currently I am implementing some error handling for broken or error prone connections and will probably soon move it into the HS
  • Warichet
    Hi Gaston,
    Ich arbeite zur Zeit daran die Vantage Pro 2 von Davis (eine Profi Wetterstation) in den Homeserver anzubinden.
  • SnowMaKeR
    Ich muss Arndt Recht geben.
    Hab ich auch 2 Jahre so gemacht.
    Die Elsner hat dafür völlig ausgereicht.
    Aber auch die neue BMS sollte dafür hervorragend, vielleicht sogar besser, geeignet sein.
    Die Lösung von BMS ist eigentlich keine Wetterstation, sondern eine Wetterzentrale. Diese meldet nicht nur "jetzt ist´s hell" und ein paar Werte, sondern verknüpft das intern schon sehr, sehr intelligent.
    Aber zurück zur Elsner.
    Ich hab mir nach den 2 Jahren dann den EIBPC geholt.
    Elsner ohne Logik + EIBPC ist eine hervorragende Kombination auch in Bezug auf den Preis.
  • R2D2
    Nein, schon klar, daß der HS weitaus mehr kann. (Ich hab jetzt seit ein paar Wochen auch so ein Schätzchen im Keller stehen, und auch noch genug Fragen dazu, mit denen ich Euch heimsuchen werde).
    Mein Hinweis war nur dahin gemeint, daß der (meist notorisch klamme) EIB-Häuslebauer vielleicht die ersten Jahre durchaus einfache Logikfunktionen wie eben z.B. Sonnenschutz mit Jalousien über den Suntracer fahren kann, und nicht sofort in den HS investieren muß.
    Wenn die Ansprüche an Funktionen steigen (oder gleich höher sind), geht´s kaum ohne, klar.
  • Dundi
    Arnd...du vergleichst einen HS mit einer Wetterstadion?
    Möchtest du darüber nachdenken wollen?
  • R2D2
    Zitat von cboge Beitrag anzeigen
    Ich habe auch die Elsner "Suntracer KNX" als 230V Variante im Einsatz.
    Montage, Parametrierung und Betrieb seit Frühjahr 2010 völlig problemlos.
    Tag zusammen; mein erster Post hier, und gleich Schleichwerbung....
    Der Charme des Suntracers sind m.M.n. vor allem die recht umfangreichen integrierten Logikfunktionen. Damit hab ich bei meinem Haus jahrelang die Investition in einen Homeserver herausschieben können, weil Rollädenautomatik, Sonnenschutzfunktionen, usw. in absolut brauchbarer Qualität alleine über den Suntracer realisierbar sind. Für den Preis in meinen Augen optimal.
    Arnd (der nicht von Elsner gesponsort wird)
  • Gaston
    Falls ein Homeserver zur Verfügung steht und es eine richtige "Männerwetterstation" sein soll : Ich arbeite zur Zeit daran die Vantage Pro 2 von Davis (eine Profi Wetterstation) in den Homeserver anzubinden. Das wird allerdings auch noch mindestens 1-2 Monate dauern bis der Baustein Releasereife erreicht hat.
    Gruss,
    Gaston
  • cboge
    Elsner Wetterstation
  • moudi
    Und wie schauts mir der hier aus ? Brauchbar ?
    Theben 1329201 Wetterstation KNX mit Regensensor, 465,00 € - EIB KNX und Powernet Online Shop
    Gruss moudi
  • tbi
    Hallo Moudi
    Zitat von moudi Beitrag anzeigen
    Anscheinend hat das Teil von Gira den Temp. Sensor im Gehäuse. Und das Gehäuse muss ja zwecks Regen und Lichtmessung in der Sonne sein. Der Temp. Sensor allerdings nicht. Wie soll das gehen ?
    Das ist auch bei der Elsner der Fall, Es ist eben ein Gerät. Der Temp Sensor ist aber unten angebracht. Der Licht Sensor eben oben.
    Ich habe zwei Temp. Sensoren am Haus, 1.) von der Heizung auf der Nordwand im Schatten und 2.) auf dem Dach in der Elsner Wetterstation.
    Im Sommer kann es schon sein, dass auf dem Dach 1-2 Grad mehr gemessen wird. Das ist aber immer noch genau genug für Smarte Logiken.
    Wir wollen ja keine Meßstation sein, sondern unser Haus Smart machen. Dafür reicht das allemal. Andere Wetterstation sind dann eben doch einiges teurer.
    Gruß Tbi
  • DaFlori
    wir setzen immer die Wetterstationen von Elsner ein.
    KNX Wettersensoren Elsner Elektronik
    am meisten die Suntracer GPS
    Wenn man z.B. nur Regen und Wind benötigt für die Markiessen oder Jalousien dann hat Elsner auch keliene im Programm mit eben nur Regen/Wind.
    Habe schon sehr viele davon verbaut und bis jetzt noch nie Probleme oder Ausfälle gehabt.
  • moudi
    Hoi asl berlin
    das Frage ich mich ja. Anscheinend hat das Teil von Gira den Temp. Sensor im Gehäuse. Und das Gehäuse muss ja zwecks Regen und Lichtmessung in der Sonne sein. Der Temp. Sensor allerdings nicht. Wie soll das gehen ?
    Gruss moudi
  • ASL_Berlin
    Also um mal auf bereits lieferbare Wetterstationen zurück zu kommen...
    Ich finde bei Gira nur folgenden Hinweis:
    Montageort muss geeignet sein. Das Gerät darf auf keiner Seite von Hindernissen oder
    Abschattungen beeinflusst werden.
    Wie sollte ein Helligkeitssensor nicht in die Sonne gesetzt werden? Bei einem Temperatursensor ist es klar...
