Webabfragen https
  • Warichet
    Answering my own question (partially..)
    > Anyone running 4.1 and the xxAPI ?
    As far as I can see, it runs fine :-)
    I've still no clue about https.
    It doesn't run under 4.1
    The Prowl Baustein seems a bit heavy for me.
  • Warichet
    HI,
    Don't like it, but I'm quoting myself ...
    Zitat von Warichet Beitrag anzeigen
    Does it work with newer release ?
    I'm running 2.8 and seems not to work.
    According to a friend, running 4.1, it works. At least a Webabfrage is running with https.
    If this is true, it's a good reason to upgrade to 4.1 although I'm always scared to break the nice xxAPI with an upgrade.
    Anyone running 4.1 and https ?
    Thank you for your comments.
  • Warichet
    Hi Nils,
    Nice to hear from you again https://knx-user-forum.de/images/icons/icon7.gif
    Zitat von NilsS Beitrag anzeigen
    you can have a look in the prowl Logikbaustein.
    OK, I'll have a look
    What do you need it for?
    I use it to monitor my own forum,
    https://groups.google.com/forum/?hl=.../domotique-eib
    and I'm kind of "forced" to use https.
    Even if I issue a http command, Google forces the answer on https.
    Although I don't fully understand the issue, because the XML reply is as before and my Webabfrage should run, but Debug says
    (Gesamt: 202) (Work: 2) (Typ: Liste) (OK: 0)
    PS: I'm still a happy user of the xxAPI, thanks again for that.
  • NilsS
    Hi Ray,
    you can have a look in the prowl Logikbaustein. That uses an ssl connection to the prowl api.
  • Warichet
    any news ?
    Hello,
    Re-opening an old topic.
    Any news about Webabfragen and https ?
  • MatthiasS
    Nein.
    https://knx-user-forum.de/knx-eib-fo...ps-prefix.html
  • ArchieSmith
    hat ein Thema erstellt HS/FS Webabfragen https.
    Webabfragen https
    Ist das mittlerweile schon möglich https-Seiten abzufragen ?
