You may then use the Status object in zthe HS as central address for the actual switching object to keep it in sync with central commands.
Suppose we have an actuator with no status feedback, say: 1.1.101
In ETS, following GA are defined
0/0/101 Spot L5A. On/Off (linked to port #H of the actuator 1.1.101, flags: K L E T)
0/0/102 Spot L5A. Status (linked to nothing, will be used in the HS)
Those GA are imported/created in the HS.
So, in the HS, under 0/0/102, I've created a CENTRAL address pointing to 0/0/101, which is the only one "knowing" the status of the actuator for sure.
In the HS, Visu, a dynamic icon points to 0/0/102, supposed to reflect the current status of the actuator.
It works.
Oh well .....
