[Gira Home Server] VoIP or Analog Line?
    Hi.
    Is it possible to have Gira's Home Server telephone features with an analog line or VoIP? Is there any modem hardware recognized by GHS?
    Regards,
    Mike
    U can only use the isdn gateway. But for example the fritzbox have one S0 input
    Ich muss an meiner Kommasetzung arbeiten...
      Hmmm.....I'll have a look at the Fritzbox models.
      Thanks!
        But...do you need to have Gira's USB ISDN adapter?
          yes u need this or a similar
            Thanks.
            What is a similar? Which chipset does the Gira one have?
            Regards,
              What you mean and what has to be used to connect Fritzbox to Homeserver is the S0 output of the Fritzbox ;-)
              Meine Installation...
              ...gehört mir jetzt leider nicht mehr!
              Aber wenn ich wieder baue, gibt es definitiv wieder KNX! Und aus den Fehlern beim ersten Haus kann man beim zweiten nur lernen!
                So... does anyone know which chipset does the Gira ISDN adapter uses?
