[Gira Home Server] VoIP or Analog Line?
  • MikeMelga
    So... does anyone know which chipset does the Gira ISDN adapter uses?
  • Hightech
    Zitat von ets3-user Beitrag anzeigen
    But for example the fritzbox have one S0 input
    What you mean and what has to be used to connect Fritzbox to Homeserver is the S0 output of the Fritzbox ;-)
  • MikeMelga
    yes u need this or a similar
    Thanks.
    What is a similar? Which chipset does the Gira one have?
    Regards,
  • ets3-user
  • MikeMelga
    But...do you need to have Gira's USB ISDN adapter?
  • MikeMelga
    U can only use the isdn gateway. But for example the fritzbox have one S0 input
    Hmmm.....I'll have a look at the Fritzbox models.
    Thanks!
  • ets3-user
  • MikeMelga
    hat ein Thema erstellt [Gira Home Server] VoIP or Analog Line?
    Hi.
    Is it possible to have Gira's Home Server telephone features with an analog line or VoIP? Is there any modem hardware recognized by GHS?
    Regards,
    Mike
