Merten DALI gateway 680191 produktdatenbank???
  • MarkusL
    Zitat von dietereddb Beitrag anzeigen
    Try the same with www.merten.com !
    There has to be some bug in their website.
    Right, merten.com behaves differently...they need to check their CMS.
    BR,
    Markus
  • dietereddb
    MarkusL,
    Anyway, I found the database file, and it is working in ETS. But as Merten is taken over by Schneider, the device came in a Schneider box with Schneider labels on the device. When commissioning, ETS says the manufacturers application program and device do not match...
    Meanwhile i have found the ets file on the schneider website (thanks to my wholesaler), and now i have to try import this one, see if this works.
  • MarkusL
    Hi Dieter,
    I have no idea how you got there. Surfing to www.merten.de , clicking downloads, clicking software gives exactly the same page, but without the ets3 and ETS4 submenus...
    1. Visit www.merten.de
    2. From TOP menu: Select 'DOWNLOADS', then 'SOFTWARE'
    => On the left hand vertical menu you'll see:
    APPLIKATIONEN ETS3D (VD4)
    APPLIKATIONEN ETS4 (KNXPROD)
    Wasn't that easy?
    Thanks a lot!
    You're welcome!
    Regards,
    Markus
    PS: I forgot to welcome you in this forum: "Welcome!!"
    PPS: Please mark this thread as solved.
  • dietereddb
    Thanks a lot!
  • MarkusL
    Hello Dieter,
    well, the Merten home isn't really this bad!
    You could find the downloads here.
    For your convenience I've attached the requested vd4 as well to this post. Pls. remove the postfix ".zip" (just needed for Forumupload.
    BR,
    Markus
  • dietereddb
    hat ein Thema erstellt KNX/EIB Merten DALI gateway 680191 produktdatenbank???.
    I'm rather new here, but following the forum for a while.
    I recently bought a Merten 680191 dali gateway, not knowing what a terrible website Merten has! (Schneider's website is even worse). There is no working link to the ETS database files.
    So i'm rather urgently looking for the ETS database file for this device.
    Can someone help me?
