Hi everyone,
I have an ABB DG/S 1.64.5.1 that has been working fine until today. When I tried to connect to it using the ABB i-bus Tool, I noticed that the connection was extremely slow. After a while, the screen turned black and the device stopped responding.
At that point, it was no longer responding either to ETS or to KNX telegrams, so it was not possible to switch on the already programmed DALI devices. The only way to make it receive telegrams again was to disconnect and restore the power supply.
Has anyone experienced a similar issue or knows what could be causing this behavior?
