Vermutlich weil ichs beim Copy&Paste vergessen habe.. Spielt keine Rolle, man kann da auch 18x return oder exit oder die reinschreiben..
Makki
$plugin_info{$plugname.'_cycle'} = $wg_config{''}{'rrd_interval'};
update_rrd("MeinRegler1Name","",knx_read("1/2/3",0,"5.010"));
update_rrd("MeinRegler2Name","",knx_read("1/2/4",0,"5.010"));
.# Demo-Plugin Grafiken in RRD speichern
# Eigenen Aufruf-Zyklus auf 300 Sekunden (Default globales RRD-Intervall) setzen
update_rrd("Zennio","",knx_read(""3/5/4"",0,9));
return;
2013-01-13 14:33:31.511,A_GroupValue_Write,10.10.23,3/7/2,07 80,19.2,DPT_Value_Temp,9.001,0,low,6,T_DATA_XXX_REQ,0 2013-01-13 14:33:39.589,A_GroupValue_Write,10.10.14,3/5/4,07 B2,7,DPT_Switch,1.001,0,low,6,T_DATA_XXX_REQ,0 2013-01-13 14:33:41.522,A_GroupValue_Write,10.10.23,3/7/2,07 80,19.2,DPT_Value_Temp,9.001,0,low,6,T_DATA_XXX_REQ,0 2013-01-13 14:33:49.585,A_GroupValue_Write,10.10.14,3/5/4,07 B2,7,DPT_Switch,1.001,0,low,6,T_DATA_XXX_REQ,0 2013-01-13 14:33:51.508,A_GroupValue_Write,10.10.23,3/7/2,07 80,19.2,DPT_Value_Temp,9.001,0,low,6,T_DATA_XXX_REQ,0 2013-01-13 14:33:59.590,A_GroupValue_Write,10.10.14,3/5/4,07 B2,7,DPT_Switch,1.001,0,low,6,T_DATA_XXX_REQ,0 2013-01-13 14:34:00.512,A_GroupValue_Write,10.10.23,3/7/3,40 BC 91 F5,,,,0,low,6,T_DATA_XXX_REQ,0 2013-01-13 14:34:00.554,A_GroupValue_Write,10.10.23,3/7/4,40 E2 E0 35,,,,0,low,6,T_DATA_XXX_REQ,0 2013-01-13 14:34:01.501,A_GroupValue_Write,10.10.23,3/7/2,07 80,19.2,DPT_Value_Temp,9.001,0,low,6,T_DATA_XXX_REQ,0 2013-01-13 14:34:09.591,A_GroupValue_Write,10.10.14,3/5/4,07 B2,7,DPT_Switch,1.001,0,low,6,T_DATA_XXX_REQ,0 2013-01-13 14:34:11.499,A_GroupValue_Write,10.10.23,3/7/2,07 80,19.2,DPT_Value_Temp,9.001,0,low,6,T_DATA_XXX_REQ,0
