Timer application
  • EPIX
    try a switch-actuator with an application called "Treppenhauslicht" which means that there is a constant time where the output is ON after you send a short signal.
    As you can use a multi-chanel-switch the costs would be lower if you can use the other chanels as well...
  • Taylor-Made
    here is an Application-Modul from ABB. It´s about 125€
    Taylor
  • elof
    hat ein Thema erstellt Timer application.
    Timer application
    Hello
    I need a product cheap as possible
    I have a towel dryer in the bathroom and i want to some extra heat for ex 2hours i have a pusch buttom with termostat its a Rumsregulator Trend Flex Schneider Electric (MG)
    and a theben heat actuator hmg4
    for ex i have 21 degress C in the room and i want extra heat for fast towel dryer and take away moisture i push the buttom for forced heat and a timer to go back to normal
    the toweldryer works even four room heat 1270w water heat its a large one 1690mmx750mm
    And now the ask a nedd a timer for this appl
    //Olov
