Leider bekomme ich auch nicht das Licht eingeschaltet.
Browser: Firefox
WINSCP
Meine item sieht wie folgt aus.
[EG]
[[Wohnzimmer]]
[[[Decke]]]
type = bool
visu_acl = rw
knx_dpt = 1
knx_listen = 1/1/37
knx_send = 1/1/36
knx_init = 1/1/36
[[Wohnzimmer]]
[[[Decke]]]
type = bool
visu_acl = rw
knx_dpt = 1
knx_listen = 1/1/37
knx_send = 1/1/36
knx_init = 1/1/36
* @package smartVISU
* @author Martin Gleiß
* @copyright 2012
* @license GPL [http://www.gnu.de]
{% extends "rooms.html" %}
{% block content %}
<div class="block">
<div class="set-2" data-role="collapsible-set" data-theme="c" data-content-theme="a" data-mini="true">
<div data-role="collapsible" data-collapsed="false">
<h3>Wohnzimmer</h3>
<table width=100%>
<tr>
<td align=left>
{{ basic.switch('S1', 'EG.Wohnzimmer.Decke', icon1~'light_light.png', icon0~'light_light.png') }} Deckenlicht
</td>
</tr>
</table>
</div>
</div>
</div>
{% endblock %}
2014-04-28 19:51:46,097 INFO Main Start SmartHome.py 1.0-32-gfd0043e -- smarthome.py:__init__:231 2014-04-28 19:51:46,101 DEBUG Main Python 3.2.3 -- smarthome.py:__init__:232 2014-04-28 19:51:46,107 INFO Main Init Scheduler -- scheduler.py:__init__:86 2014-04-28 19:51:46,113 INFO Main Init Plugins -- smarthome.py:start:274 2014-04-28 19:51:46,125 DEBUG Scheduler creating 5 workers -- scheduler.py:run:93 2014-04-28 19:51:46,135 DEBUG Main Plugin: knx -- plugin.py:__init__:43 2014-04-28 19:51:46,164 DEBUG Main Plugin: visu -- plugin.py:__init__:43 2014-04-28 19:51:46,257 DEBUG Main Plugin: cli -- plugin.py:__init__:43 2014-04-28 19:51:46,269 DEBUG Main Plugin: sql -- plugin.py:__init__:43 2014-04-28 19:51:46,302 DEBUG Main SQLite 3.7.13 -- __init__.py:__init__:62 2014-04-28 19:51:46,538 DEBUG Main SQLite: database integrity ok -- __inits__.py:__init__:78 2014-04-28 19:51:46,579 DEBUG Main SQLite pack next time: 2014-04-29 03:02:00+02:00 -- scheduler.py:_next_time:289 2014-04-28 19:51:46,585 INFO Main Init Items -- smarthome.py:start:280 2014-04-28 19:51:46,708 DEBUG Main Item env.core.memory = 13402112.0 via SQLite None None -- item.py:set:457 2014-04-28 19:51:46,778 DEBUG Main Item env.core.threads = 7.0 via SQLite None None -- item.py:set:457 2014-04-28 19:51:46,844 DEBUG Main Item env.core.garbage = 0.0 via SQLite None None -- item.py:set:457 2014-04-28 19:51:46,851 DEBUG Main Item env.core: no type specified. -- item.py:__init__:242 2014-04-28 19:51:46,907 DEBUG Main Item env.location: no type specified. -- item.py:__init__:242 2014-04-28 19:51:46,979 DEBUG Main Item env.system.load = 0.27 via SQLite None None -- item.py:set:457 2014-04-28 19:51:46,991 DEBUG Main Item env.system: no type specified. -- item.py:__init__:242 2014-04-28 19:51:46,995 DEBUG Main Item env: no type specified. -- item.py:__init__:242 2014-04-28 19:51:47,015 DEBUG Main KNX: EG.Wohnzimmer.Decke listen on 1/1/37 -- __init__.py:parse_item:235 2014-04-28 19:51:47,019 DEBUG Main KNX: EG.Wohnzimmer.Decke listen on and init with 1/1/36 -- __init__.py:parse_item:244 2014-04-28 19:51:47,023 DEBUG Main Item EG.Wohnzimmer: no type specified. -- item.py:__init__:242 2014-04-28 19:51:47,027 DEBUG Main Item EG: no type specified. -- item.py:__init__:242 2014-04-28 19:51:47,034 INFO Main Start Plugins -- plugin.py:start:65 2014-04-28 19:51:47,081 INFO Main Start Logics -- logic.py:__init__:33 2014-04-28 19:51:47,085 DEBUG Main Reading Logics from /usr/smarthome/lib/env/logic_conf -- logic.py:_read_logics:64 2014-04-28 19:51:47,118 DEBUG Main Reading Logics from /usr/smarthome/etc/logic.conf -- logic.py:_read_logics:64 2014-04-28 19:51:47,136 DEBUG Main Logic: hello -- logic.py:__init__:44 2014-04-28 19:51:47,195 DEBUG Main Logic: env_init -- logic.py:__init__:44 2014-04-28 19:51:47,207 DEBUG Main Logic: env_stat -- logic.py:__init__:44 2014-04-28 19:51:47,247 DEBUG Main env_stat next time: 2014-04-28 19:52:00+02:00 -- scheduler.py:_next_time:289 2014-04-28 19:51:47,266 DEBUG Main Logic: env_loc -- logic.py:__init__:44 2014-04-28 19:51:47,346 DEBUG Connections KNX: connected to 127.0.0.1:6720 -- connection.py:connect:386 2014-04-28 19:51:47,351 DEBUG Connections KNX: enable group monitor -- __init__.py:handle_connect:117 2014-04-28 19:51:47,354 DEBUG Connections KNX: init read -- __init__.py:handle_connect:123 2014-04-28 19:51:47,361 DEBUG Connections WebSocket: binding to 0.0.0.0:2424 (TCP) -- connection.py:connect:161 2014-04-28 19:51:47,367 DEBUG Connections CLI: binding to 0.0.0.0:2323 (TCP) -- connection.py:connect:161 2014-04-28 19:51:48,333 DEBUG Main KNX: 0.0.0 read 1/1/36 -- __init__.py:parse_telegram:203 2014-04-28 19:51:51,271 DEBUG Main knx: 1.1.15 set 3/1/4 to 076c -- __init__.py:parse_telegram:181 2014-04-28 19:51:52,248 INFO hello Hello World! -- hello.py:<module>:3 2014-04-28 19:51:52,253 DEBUG env_init Item env.core.version = 1.0-32-gfd0043e via Logic None None -- item.py:__update:363 2014-04-28 19:51:52,265 DEBUG env_init Item env.core.start = 2014-04-28 19:51:52.260940+02:00 via Logic None None -- item.py:__update:363 2014-04-28 19:51:52,274 DEBUG env_init Item env.system.name = smarthome.local via Logic None None -- item.py:__update:363 2014-04-28 19:51:52,286 DEBUG env_init Item env.system.start = 2014-04-28 19:50:53.281922+02:00 via Logic None None -- item.py:__update:363 2014-04-28 19:51:52,834 DEBUG env_loc Item env.location.sunrise = 2014-04-29 05:54:56.120459+02:00 via Logic None None -- item.py:__update:363 2014-04-28 19:51:52,836 DEBUG sh.gc Garbage collector: collected 0 objects. -- smarthome.py:_garbage_collection:498 2014-04-28 19:51:52,879 DEBUG env_loc Item env.location.sunset = 2014-04-28 20:35:38.225778+02:00 via Logic None None -- item.py:__update:363 2014-04-28 19:51:52,963 DEBUG env_loc Item env.location.moonrise = 2014-04-29 06:04:49.214095+02:00 via Logic None None -- item.py:__update:363 2014-04-28 19:51:53,043 DEBUG env_loc Item env.location.moonset = 2014-04-29 21:01:01.387769+02:00 via Logic None None -- item.py:__update:363 2014-04-28 19:51:53,081 DEBUG env_loc Item env.location.moonphase = 8 via Logic None None -- item.py:__update:363 2014-04-28 19:51:53,151 DEBUG sh.gc Object references: 8957 -- smarthome.py:_maintenance:490 2014-04-28 19:51:53,160 DEBUG env_loc Item env.location.day = True via Logic None None -- item.py:__update:363 2014-04-28 19:51:53,337 DEBUG Scheduler env_loc next time: 2014-04-28 20:21:53+02:00 -- scheduler.py:_next_time:289 2014-04-28 19:51:53,359 DEBUG Scheduler sh.gc next time: 2014-04-29 02:04:00+02:00 -- scheduler.py:_next_time:289 2014-04-28 19:52:00,461 DEBUG env_stat Item env.core.memory = 13406208 via Logic None None -- item.py:__update:363 2014-04-28 19:52:00,471 DEBUG env_stat Item env.system.load = 0.31 via Logic None None -- item.py:__update:363 2014-04-28 19:52:00,916 DEBUG Scheduler env_stat next time: 2014-04-28 19:57:00+02:00 -- scheduler.py:_next_time:289 2014-04-28 19:52:09,675 DEBUG Main knx: 1.1.14 set 3/1/2 to 00 -- __init__.py:parse_telegram:181 2014-04-28 19:52:11,388 DEBUG Main knx: 1.1.50 set 3/2/1 to 00 -- __init__.py:parse_telegram:181 2014-04-28 19:52:51,266 DEBUG Main knx: 1.1.15 set 3/1/4 to 076c -- __init__.py:parse_telegram:181
WINSCP setzt folgende Fehlermeldung "Der Server sendete den Befehlsbeendigungsstatus 2"
Starte ich smarthome.py -d kann ich nichts mehr machen, bis die Applikation auf einen Timeout läuft ? Das Debug habe ich nachträglich aus dem Log Ordner kopiert, nachdem ich mich neu verbinden musste.
Danke für die Unterstützung
Hans M.
