Query objects during startup
  • MikeMelga
    MatthiasS,
    I seem to found the problem. The actuator resets everything to zero when reprogrammed (I guess it is normal) but I also had a bad flag activated in HS.
    Now it seems to work ok
    Thanks.
  • MatthiasS
    What happens if you do the query by ETS on that group address?
  • MikeMelga
    Which object do you "query"?
    - shutter position or
    - shutter position status
    Sometimes it depends on the shutter actuator...
    Thanks for the reply.
    I query the 'shutter position status'.
    It's a Gira 103800 8x/16x actuator.
  • MatthiasS
  • MikeMelga
    hat ein Thema erstellt HS/FS Query objects during startup.
    Hi.
    I've set the 'query during startup' option in Gira Expert but it doesn't seem to work.
    I've also activated the read flag on the EIB object.
    What I would like to do is: when I restart Gira HS it should query the status position object of the blinds in the startup to see if they are open or closed.
    However... it never does. They are all marked as 'open' until I open and close them once.
    Any help?
