Dump Ets parameters/groupobjects to a CSV or xls
    Weiß jemand wie man Parameters/Group Objects von ein Type Device kan exportieren nach Excel ? Ich möchte gern die config von 20 Sentido's vergleichen.
    Danke !
    Joris
    PS : bot exactly a native German speaker but I try so do not flame me
    Hello Joris,
    which ETS version do you use?
    Would XML be OK, too?
    Klaus
      Hello Klaus,
      ETS 5
      xml would sure be helpfull. I can always look for a programmer to convert the xml file to something an ignorant like me could use.
      Thanks,
      Joris
        Hello Klaus,
        seems ms excel can import xml )
        Joris
          Hello Joris,
          You might try the following:
          • export the project als knxproj, rename the knxproj to zip and pick the file P-xxxx\0.xml from there - it contains all project data.
          • for a more accessible format, you can use the ETS App "Project Data Exchange"
          • or, create a report and export it to a file
          Klaus
