Merten MTN680329 and Somfy animeo KNX 4 AC Motor Controller WM 220-240V V2.0
    KNX/EIB Merten MTN680329 and Somfy animeo KNX 4 AC Motor Controller WM 220-240V V2.0
    I have installed ETS5.5.2 on Windows 10 with 6GB RAM and high end laptop.
    I have 10 installed devices, of Which I have full access using MTN680329 IP router but I can not communicate with Somfy controller using the same IP router.
    Firstly I have contacted KNX Org and then Somfy to realize, dass die trouble is only with the IP router.
    The communication Could be established with USB interface (test Conducted at Somfy). NB I can download the physical address on Somfy controller only once after reset. After did no communication "device info: failed The device does not respond in time Appropriate Connection: KNX / IP router REG-K (192.168.1.70:3671) Start: 10:45:05 AM End: 10:45:30 AM" If anyone have an idea I appreciate. Thank you.
