How does a push button work? / Wie funktioniert ein Druckknopf?
  • TheOlli
    Zitat von McNulty Beitrag anzeigen
    Thank you very much for the help
    De nada ;-)
  • McNulty
    Hello everyone,
    I have verified with the ETS, that it is possible to do what I describe above, so I will be able to control with a 2-phase F10, 1 blind and 1 light, to activate them ON / OFF and regulating them.
    Thank you very much for the help.
    Ich habe mit dem ETS überprüft, dass es möglich ist, das zu tun, was ich oben beschrieben habe, damit ich mit einem 2-Phasen-F10, 1 Jalousie und 1 Licht steuern kann, um sie EIN / AUS zu aktivieren und zu regulieren.
    Vielen Dank für die Hilfe.
  • mumpf
    Hi Florian,
    you are right, I mixed up "long press" with "press and hold". So I correct my above statement:
    The standard blind control in knx works the way:
    • Long press up: raise blind
    • Long press down: lower blind
    • press once (up or down): stop blind
    As Florian already mentioned, long press means "press and hold for 0.5 seconds".
    Regards,
    Waldemar
  • Beleuchtfix
    this is slightly incorrect for blind control. The standard blind control in knx works the way:
    Waldemar is in my opinion also incorrect in his wording, standard KNX Blind Control works press long (about more than half a second) will start a full up or down movement, short press will stop or make slight tilt changes with the blinds.
    So basically you can do, what you want.
    Regards Florian
  • McNulty
    Sorry to speak again, but I'm a newbie and the language doesn't help me either.
    I show a photo of a pushbutton from the F10 series as an example. I want to confirm that this is possible with a button like the one in the photo.
    • left rocker: light on / off (do not hold down) + light intensity regulation (hold down)
    • right rocker: blind up / down (do not hold down) + blind adjustment (hold down)
    For the blinds it is very confortable to press "up" once and they go up or down without waiting.
    For the lights, according to the KNXsmart explanation, I feel I am correct, that is, with a single rocker, I get four functions (ON / OFF + Dimming)
    Thank you so much again.
    Es tut mir leid, wieder zu sprechen, aber ich bin ein Neuling und die Sprache hilft mir auch nicht.
    Als Beispiel zeige ich ein Foto eines Druckknopfs aus der F10-Serie. Ich möchte bestätigen, dass dies mit einer Schaltfläche wie der auf dem Foto möglich ist.
    linke Wippe: Licht ein / aus (nicht gedrückt halten) + Lichtintensitätsregulierung (gedrückt halten)
    rechte Wippe: Blind hoch / runter (nicht gedrückt halten) + Blindeinstellung (gedrückt halten)
    Für die Jalousien ist es sehr bequem, einmal "hoch" zu drücken und sie gehen ohne zu warten auf oder ab.
    Bei den Lichtern fühle ich mich laut KNXsmart-Erklärung richtig, dh mit einer einzelnen Wippe bekomme ich vier Funktionen (EIN / AUS + Dimmen).
    Nochmal vielen Dank.
    This gallery has 1 photos.
  • KNXsmart
    I don't use Jung buttons but assume that all of them work quite the same as on my Feller ones. Some functions (like sending a value) require 1 button (one half of the rocker), others like the blind contro require both buttons of the rocker (up and down). Other functions like switching/dimming, can be done with either one or two buttons. In the example of light swithing:
    1-Button Control:
    • press up: Light 1 - alternate between on/off
    • press down: Light 2 - alternate between on/off
    2-Button Control:
    • press up: Light 1 - on
    • press down - Light 1 - off
    Same works with dimming while short press is on/off, long press dim up/down.
    It's always a good idea to load the application of a device to ETS before actually deciding for it. Then you can check the settings, this device actually provides.
  • TheOlli
    shame on me ;-) Waldemar is right.
    Im also unsing the F40 and it also works with this series of course.
    Look for the "universal" version of the F40 instead the standard.
    If its necesarry, universal could be extended by using this module https://www.jung.de/de/online-katalog/360251577/
  • mumpf
    Zitat von TheOlli Beitrag anzeigen
    What you describe is the regular function of "dimming" and"blind control".
    • press and hold up: raise blind
    • press and hold down: lower blind
    Regards,
    Waldemar
  • McNulty
    First: I'm impressed by the google result...
    So that are two standard funtions wich are supported by every KNX-button. Wich Jung button do you want to use?
    I am thinking to use the F10 series and the F40 series. As an example the following:
    F40: 4192TSM
    https://www.jung.de/de/online-katalog/360251568/
    F10: LS CD 10921 ST
    https://www.jung.de/de/online-katalog/11558
    Ich denke an die Verwendung der F10-Serie und der F40-Serie. Als Beispiel folgendes:
    F40: 4192TSM
    F10: LS CD 10921 ST
    https://www.jung.de/de/online-katalog/1155820506/
  • TheOlli
  • How does a push button work? / Wie funktioniert ein Druckknopf?
    Hello everyone,
    I will ask a question, I try it in English which is better than my Google German,
    I have a question that is important to be able to design the system I want to install. How do Jung pushbuttons work? I assume that all manufacturers work in a similar way. For example one of two phases and two rockers. Is it possible to do this?
    • Left rocker
      • Press once up: turn on light
      • Press once down: turn off light
      • Press and hold up: regulate more light until releasing
      • Press and hold down: regulate less light until released
    • Right rocker
      • Press once up: raise blind
      • Press once down: lower blind
      • Press and hold up: raise blind until release
      • Press and hold down: lower blind until release
    That is, each phase and each rocker can have 4 functions. I'm right?
    German Google translate
    Ich werde eine Frage stellen, ich versuche es auf Englisch, was besser ist als mein Google Deutsch,
    Ich habe eine wichtige Frage, um das System entwerfen zu können, das ich installieren möchte. Wie funktionieren Jung-Drucktasten? Ich gehe davon aus, dass alle Hersteller ähnlich arbeiten. Zum Beispiel eine von zwei Phasen und zwei Wippen. Ist das möglich?
    • Linke Wippe
      • Einmal drücken: Licht einschalten
      • Einmal drücken: Licht ausschalten
      • Gedrückt halten: Mehr Licht regulieren, bis es loslässt
      • Halten Sie gedrückt: Regulieren Sie weniger Licht, bis es freigesetzt wird
    • Rechter Rocker
      • Einmal drücken: Blind anheben
      • Einmal nach unten drücken: Jalousie senken
      • Drücken und halten: Blind bis zum Loslassen anheben
      • Halten Sie gedrückt: Senken Sie die Jalousie bis zur Freigabe
    Das heißt, jede Phase und jede Wippe kann 4 Funktionen haben. Ich habe recht?
