[QUOTE=TBBW;n1667530]Hi all,
xxAPI2 running on firmware 4.11 !!
I do not use the xstart, so NO LOAD from github
and also the stationclock js files are on the machine.
grusse,
ger[/QUOTE
use enclosed files. all files you need local.
HS3 to HS4
Hi all,
grusse,
ger
….. is it possible that xxapi2 is not “started” if there is no secure connection?
any help would be nice
grusse
oke status so far loaded the xxapi2 manually.
but for some reason the xxapi2 part is not started
any suggestions?
grusse,
Have been digging several days now.
unable to load the xxapi2 part.
anybody willing to help me out.
replies can be in German, danke.
grusse,
ger
Did a port from the hs3 to the hs4.
Do get some errors on the xxapi2-loader.
so xxapi2 is not "started"
Is it possible to start xxapi2 without the loader-logic, so without an upload from github?
regards,
Ger
HS3 to HS4
Dear xxAPI2 friend,
As the life cycle of my HS3 is running to an end, I do not want to implement a new server head over heels.
So I want to put a HS4 on standby.
On the HS3 a lot could be done using http on the HS4 (4.11) most of com. is via https.
This is new territory for me.
Also is the xxAPI2 compatible with firmware 4.11, partly/fully?
Would it be possible to post a step by step procedure to port xxAPI to the HS4.
Any info is welcome.
regards,
Ger
Stichworte: -
