I’m using KNX integration in Home Assistant with knxd addon to connect to KNX bus. HA server uses USB interface to connect to KNX.
Everything works fine until I remove network cable from HA server. In that moment knxd looses network connetion and shuts down and the connection to KNX bus is broken.
Any advice how to solve this issue?
I want to stay connected from Hme Assistant server to KNX bus even the network cable is not connected to the server.
thanks
thanks
