Hi, mit den Thinks stehe ich noch auf Kriegsfuß
Hier meine Dateien:
AM2302sensor.sh (Hat mit OH1 immer funktioniert)
ThingsDatei:
items:
Log:
Also wie man im Log sieht, kommt ein Wert zurück... Aber
Hier meine Dateien:
#!/bin/bash
INPUT22=$(/home/openhabian/Adafruit_Python_DHT/examples/AdafruitDHT.py 22 22)
TEMP22=$(echo $INPUT22|cut -d " " -f1 | sed 's/[^0-9.]*//g')
HUM22=$(echo $INPUT22|cut -d " " -f2 | sed 's/[^0-9.]*//g')
INPUT4=$(/home/openhabian/Adafruit_Python_DHT/examples/AdafruitDHT.py 22 4)
TEMP4=$(echo $INPUT4|cut -d " " -f1 | sed 's/[^0-9.]*//g')
HUM4=$(echo $INPUT4|cut -d " " -f2 | sed 's/[^0-9.]*//g')
ADDW=5.00
if [ "$1" = "HUM22" ]; then
echo $HUM22 $ADDW | awk '{print $1 + $2}'
fi
if [ "$1" = "TEMP22" ]; then
echo $TEMP22
fi
if [ "$1" = "HUM4" ]; then
echo $HUM4 $ADDW | awk '{print $1 + $2}'
fi
if [ "$1" = "TEMP4" ]; then
echo $TEMP4
fi
exec:command:dht22 [command="/srv/openhab2-conf/scripts/AM2302sensor.sh TEMP4", interval=30, timeout=20]
Number TEMP_Keller4 "Temp 4 Keller [%.1f °C]" <temperature> (gTemp) {channel="exec:command:dht22"}
String LUFT_Keller4 "Luftf. 4 Keller [%s]" <temperature> (gTemp) { channel="exec:command:dht22:output"}
2017-06-23 14:58:54.043 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update '22.6 /usr/lib/python2.7/dist-packages/pkg_resources.py:1049: UserWarning: /var/lib/openhab2/.python-eggs is writable by group/others and vulnerable to attack when used with get_resource_filename. Consider a more secure location (set with .set_extraction_path or the PYTHON_EGG_CACHE environment variable). warnings.warn(msg, UserWarning) /usr/lib/python2.7/dist-packages/pkg_resources.py:1049: UserWarning: /var/lib/openhab2/.python-eggs is writable by group/others and vulnerable to attack when used with get_resource_filename. Consider a more secure location (set with .set_extraction_path or the PYTHON_EGG_CACHE environment variable). warnings.warn(msg, UserWarning) /usr/lib/python2.7/dist-packages/pkg_resources.py:1049: UserWarning: /var/lib/openhab2/.python-eggs is writable by group/others and vulnerable to attack when used with get_resource_filename. Consider a more secure location (set with .set_extraction_path or the PYTHON_EGG_CACHE environment variable). warnings.warn(msg, UserWarning) /usr/lib/python2.7/dist-packages/pkg_resources.py:1049: UserWarning: /var/lib/openhab2/.python-eggs is writable by group/others and vulnerable to attack when used with get_resource_filename. Consider a more secure location (set with .set_extraction_path or the PYTHON_EGG_CACHE environment variable). warnings.warn(msg, UserWarning)' for item 'LUFT_Keller4' to handler for channel 'exec:command:gude:TEMP4', because no thing with the UID 'exec:command:gude' could be found. 2017-06-23 15:00:19.726 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update '22.5 /usr/lib/python2.7/dist-packages/pkg_resources.py:1049: UserWarning: /var/lib/openhab2/.python-eggs is writable by group/others and vulnerable to attack when used with get_resource_filename. Consider a more secure location (set with .set_extraction_path or the PYTHON_EGG_CACHE environment variable). warnings.warn(msg, UserWarning) /usr/lib/python2.7/dist-packages/pkg_resources.py:1049: UserWarning: /var/lib/openhab2/.python-eggs is writable by group/others and vulnerable to attack when used with get_resource_filename. Consider a more secure location (set with .set_extraction_path or the PYTHON_EGG_CACHE environment variable). warnings.warn(msg, UserWarning) /usr/lib/python2.7/dist-packages/pkg_resources.py:1049: UserWarning: /var/lib/openhab2/.python-eggs is writable by group/others and vulnerable to attack when used with get_resource_filename. Consider a more secure location (set with .set_extraction_path or the PYTHON_EGG_CACHE environment variable). warnings.warn(msg, UserWarning) /usr/lib/python2.7/dist-packages/pkg_resources.py:1049: UserWarning: /var/lib/openhab2/.python-eggs is writable by group/others and vulnerable to attack when used with get_resource_filename. Consider a more secure location (set with .set_extraction_path or the PYTHON_EGG_CACHE environment variable). warnings.warn(msg, UserWarning)' for item 'LUFT_Keller4' to handler for channel 'exec:command:gude:TEMP4', because no thing with the UID 'exec:command:gude' could be found.
- Was muss ich noch ändern, damit der Wert auch übergeben werden kann?
- Was genau muss ich gegen die SecurityWarnung machen
- Wie kann ich das Think so einstellen, dass ich TEMP4 mit dem item übergeben kann?
