Hallo liebes Forum,
seit ein paar Tagen bekomm ich keine Verbindung mehr zum innogy Server. Im Log finde ich folgenden Fehler:
Hätte jemand eine Idee was das sein könnte ?
Frank
2020-03-24 22:36:29.818 [me.event.InboxRemovedEvent] - Discovery Result with UID 'hue:bridge:19216811100' has been removed. 2020-03-24 22:37:13.144 [hingStatusInfoChangedEvent] - 'innogysmarthome:bridge:4cda44d1' changed from UNINITIALIZED to INITIALIZING 2020-03-24 22:37:40.580 [hingStatusInfoChangedEvent] - 'innogysmarthome:bridge:4cda44d1' changed from INITIALIZING to OFFLINE (COMMUNICATION_ERROR): Read timed out ==> /var/log/openhab2/openhab.log <== 2020-03-24 22:38:01.364 [ERROR] [internal.handler.InnogyBridgeHandler] - Error initializing innogy SmartHome client. java.net.SocketTimeoutException: Read timed out at java.net.SocketInputStream.socketRead0(Native Method) ~[?:?] at java.net.SocketInputStream.socketRead(SocketInputS tream.java:116) ~[?:?] at java.net.SocketInputStream.read(SocketInputStream. java:171) ~[?:?] at java.net.SocketInputStream.read(SocketInputStream. java:141) ~[?:?] at sun.security.ssl.InputRecord.readFully(InputRecord .java:465) ~[?:?] at sun.security.ssl.InputRecord.read(InputRecord.java :503) ~[?:?] at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocke tImpl.java:975) ~[?:?] at sun.security.ssl.SSLSocketImpl.readDataRecord(SSLS ocketImpl.java:933) ~[?:?] at sun.security.ssl.AppInputStream.read(AppInputStrea m.java:105) ~[?:?] at java.io.BufferedInputStream.fill(BufferedInputStre am.java:246) ~[?:?] at java.io.BufferedInputStream.read1(BufferedInputStr eam.java:286) ~[?:?] at java.io.BufferedInputStream.read(BufferedInputStre am.java:345) ~[?:?] at sun.net.www.http.HttpClient.parseHTTPHeader(HttpCl ient.java:735) ~[?:?] at sun.net.www.http.HttpClient.parseHTTP(HttpClient.j ava:678) ~[?:?] at sun.net.www.protocol.http.HttpURLConnection.getInp utStream0(HttpURLConnection.java:1596) ~[?:?] at sun.net.www.protocol.http.HttpURLConnection.access $200(HttpURLConnection.java:94) ~[?:?] at sun.net.www.protocol.http.HttpURLConnection$9.run( HttpURLConnection.java:1493) ~[?:?] at sun.net.www.protocol.http.HttpURLConnection$9.run( HttpURLConnection.java:1491) ~[?:?] at java.security.AccessController.doPrivileged(Native Method) ~[?:?] at java.security.AccessController.doPrivilegedWithCom biner(AccessController.java:784) ~[?:?] at sun.net.www.protocol.http.HttpURLConnection.getInp utStream(HttpURLConnection.java:1490) ~[?:?] at java.net.HttpURLConnection.getResponseCode(HttpURL Connection.java:480) ~[?:?] at sun.net.www.protocol.https.HttpsURLConnectionImpl. getResponseCode(HttpsURLConnectionImpl.java:352) ~[?:?] at com.google.api.client.http.javanet.NetHttpResponse .<init>(NetHttpResponse.java:37) ~[214:org.openhab.binding.innogysmarthome:2.4.0] at com.google.api.client.http.javanet.NetHttpRequest. execute(NetHttpRequest.java:94) ~[214:org.openhab.binding.innogysmarthome:2.4.0] at com.google.api.client.http.HttpRequest.execute(Htt pRequest.java:981) ~[214:org.openhab.binding.innogysmarthome:2.4.0] at org.openhab.binding.innogysmarthome.internal.clien t.InnogyClient.executeGet(InnogyClient.java:283) ~[214:org.openhab.binding.innogysmarthome:2.4.0] at org.openhab.binding.innogysmarthome.internal.clien t.InnogyClient.initializeSession(InnogyClient.java :181) ~[214:org.openhab.binding.innogysmarthome:2.4.0] at org.openhab.binding.innogysmarthome.internal.clien t.InnogyClient.initialize(InnogyClient.java:134) ~[214:org.openhab.binding.innogysmarthome:2.4.0] at org.openhab.binding.innogysmarthome.internal.handl er.InnogyBridgeHandler$Initializer.run(InnogyBridg eHandler.java:107) [214:org.openhab.binding.innogysmarthome:2.4.0] at java.util.concurrent.Executors$RunnableAdapter.cal l(Executors.java:511) [?:?] at java.util.concurrent.FutureTask.run(FutureTask.jav a:266) [?:?] at java.util.concurrent.ScheduledThreadPoolExecutor$S cheduledFutureTask.access$201(ScheduledThreadPoolE xecutor.java:180) [?:?] at java.util.concurrent.ScheduledThreadPoolExecutor$S cheduledFutureTask.run(ScheduledThreadPoolExecutor .java:293) [?:?] at java.util.concurrent.ThreadPoolExecutor.runWorker( ThreadPoolExecutor.java:1149) [?:?] at java.util.concurrent.ThreadPoolExecutor$Worker.run (ThreadPoolExecutor.java:624) [?:?] at java.lang.Thread.run(Thread.java:748) [?:?]
Frank
