"errorMessage": "RequestId: a744feea-12fa-11e7-94db-71bf9c646eac Process exited before completing request"
START RequestId: a744feea-12fa-11e7-94db-71bf9c646eac Version: $LATEST 2017-03-27T14:35:41.796Z a744feea-12fa-11e7-94db-71bf9c646eac requesting {"key3":"value3","key2":"value2","key1":"value1"} 2017-03-27T14:35:42.096Z a744feea-12fa-11e7-94db-71bf9c646eac HTTP 401 2017-03-27T14:35:42.098Z a744feea-12fa-11e7-94db-71bf9c646eac raw response: <html> <head><title>401 Authorization Required</title></head> <body bgcolor="white"> <center><h1>401 Authorization Required</h1></center> <hr><center>nginx</center> </body> </html> 2017-03-27T14:35:42.100Z a744feea-12fa-11e7-94db-71bf9c646eac SyntaxError: Unexpected token < at Object.parse (native) at IncomingMessage.<anonymous> (/var/task/index.js:39:24) at emitNone (events.js:72:20) at IncomingMessage.emit (events.js:166:7) at endReadableNT (_stream_readable.js:905:12) at nextTickCallbackWith2Args (node.js:437:9) at process._tickDomainCallback (node.js:392:17) END RequestId: a744feea-12fa-11e7-94db-71bf9c646eac REPORT RequestId: a744feea-12fa-11e7-94db-71bf9c646eac Duration: 433.88 ms Billed Duration: 500 ms Memory Size: 512 MB Max Memory Used: 13 MB RequestId: a744feea-12fa-11e7-94db-71bf9c646eac Process exited before completing request
server {
server_tokens off;
listen 443 ssl default_server;
server_name myname.myds.me;
# SSL
ssl on;
ssl_certificate /etc/letsencrypt/live/myname.myds.me/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/myname.myds.me/privkey.pem;
ssl_session_cache builtin:1000 shared:SSL:10m;
ssl_ciphers HIGH:!aNULL:!eNULL:!LOW:!3DES:!MD5:!RC4;
# HSTS
add_header Strict-Transport-Security "max-age 31536000; includeSubDomains";
# global
root /var/www/myname.myds.me;
index index.php index.htm index.html;
location / {
#try_files $uri $uri/ =404;
return 403;
# weitere Location Angaben
location /alexa {
auth_basic "Restricted Area: Alexa";
auth_basic_user_file /etc/nginx/.alexa;
if ($allowed_country = no) {
return 403;
proxy_pass http://192.168.178.100:9000/;
proxy_set_header Host $host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forwarded-Proto $scheme;
# SSL-Redirect & LetsEncrypt Endpoint
server {
listen 80 default_server;
# redirect every requested $host (any, even invalid ones) to its SSL URL
location / {
return 301 https://$host$request_uri:8089;
# LetsEncrypt Endpoint
location /.well-known {
allow all;
alias /var/www/.well-known;
# Sitemap
server {
listen 8089 ssl default_server;
access_log /var/log/nginx/sitemap.log combined;
auth_basic "alexa";
auth_basic_user_file /etc/nginx/htpasswd;
include /etc/nginx/include.d/common;
#add_header Strict-Transport-Security "max-age=31536000; includeSubDomains" always;
location / {
root /var/www/sitemap;
index index.html;
# Alexa
server {
listen 8089 ssl;
server_name xxxx.ddns.net;
access_log /var/log/nginx/alexa.log combined;
auth_basic "alexa";
auth_basic_user_file /etc/nginx/htpasswd.alexa;
location / {
proxy_pass http://192.168.178.168:9000/;
# ANOTHER-SERVICE.YOUR-HOME.DYNDNS.TLD
{ "errorMessage": "write EPROTO", "errorType": "Error", "stackTrace": [ "Object.exports._errnoException (util.js:870:11)", "exports._exceptionWithHostPort (util.js:893:20)", "WriteWrap.afterWrite (net.js:763:14)" ] }
Fehler: Gesicherte Verbindung fehlgeschlagen
Ein Fehler ist während einer Verbindung mit xxxx.ddns.net:8089 aufgetreten. SSL hat einen Eintrag erhalten, der die maximal erlaubte Länge überschritten hat. Fehlercode: SSL_ERROR_RX_RECORD_TOO_LONG
Die Website kann nicht angezeigt werden, da die Authentizität der erhaltenen Daten nicht verifiziert werden konnte.
Kontaktieren Sie bitte den Inhaber der Website, um ihn über dieses Problem zu informieren.
017-03-26 13:54:37 WARNING Main -------------------- Init smarthomeNG 1.2.451 --------------------
2017-03-26 13:54:37 INFO Main Init Scheduler
2017-03-26 13:54:37 INFO Main Init Plugins
2017-03-26 13:54:39 INFO Main Init UZSU
2017-03-26 13:54:39 INFO Main OperationLog MeldelisteConfigPuffer: logging to file /usr/local/smarthome/var/log/operationlog/{name}-{year:04}.log, keeping 100 entries in memory, caching active
2017-03-26 13:54:39 INFO Main OperationLog Meldeliste_IPCAM: logging to file /usr/local/smarthome/var/log/operationlog/{name}-{year:04}.log, keeping 100 entries in memory, caching active
2017-03-26 13:54:39 INFO Main OperationLog Meldeliste: logging to file /usr/local/smarthome/var/log/operationlog/{name}-{year:04}.log, keeping 100 entries in memory, caching active
2017-03-26 13:54:40 INFO Main Init AVM Plugin
2017-03-26 13:54:40 INFO Main Alexa: service setup at 192.168.178.168:8089
2017-03-26 13:54:40 ERROR Main Plugin alexa exception: [Errno 98] Die Adresse wird bereits verwendet
Traceback (most recent call last):
File "/usr/local/smarthome/lib/plugin.py", line 63, in __init__
plugin_thread = PluginWrapper(smarthome, plugin, classname, classpath, args, instance)
File "/usr/local/smarthome/lib/plugin.py", line 108, in __init__
exec("self.plugin.__init__(smarthome{0})".format(args))
File "<string>", line 1, in <module>
File "/usr/local/smarthome/plugins/alexa/__init__.py", line 43, in __init__
service_host, int(service_port), service_https_certfile, service_https_keyfile)
File "/usr/local/smarthome/plugins/alexa/service.py", line 19, in __init__
self.server = HTTPServer((host, port), handler_factory)
File "/usr/lib/python3.4/socketserver.py", line 429, in __init__
self.server_bind()
File "/usr/lib/python3.4/http/server.py", line 133, in server_bind
socketserver.TCPServer.server_bind(self)
File "/usr/lib/python3.4/socketserver.py", line 440, in server_bind
self.socket.bind(self.server_address)
OSError: [Errno 98] Die Adresse wird bereits verwendet
2017-03-26 13:54:40 INFO Main Init Items
- The following errors were reported by the server: Domain: xxxx.ddns.net Type: unauthorized Detail: Invalid response from http://xxxx.ddns.net/.well-known/acme-challenge/0mw_Hd04mUcOuo8n2dij-TuwbWb1cj5Yypba0-P1OQw: "<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN"> <html><head> <title>404 Not Found</title> </head><body> <h1>Not Found</h1> <p" To fix these errors, please make sure that your domain name was entered correctly and the DNS A record(s) for that domain contain(s) the right IP address.
[alexa]
class_name = Alexa
class_path = plugins.alexa
# service_host = "0.0.0.0"
service_port = 8089
fehlt da die Freigabe des well-known dirs für das letsencrypt Challenge response Verfahrens?
Could not connect to xxx.ddns.net" doch sehr deutlich?
Failed authorization procedure. xxx.ddns.net (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Could not connect to xxx.ddns.net IMPORTANT NOTES: - The following errors were reported by the server: Domain: xxx.ddns.net Type: connection Detail: Could not connect to xxxx.ddns.net To fix these errors, please make sure that your domain name was entered correctly and the DNS A record(s) for that domain contain(s) the right IP address. Additionally, please check that your computer has a publicly routable IP address and that no firewalls are preventing the server from communicating with the client. If you're using the webroot plugin, you should also verify that you are serving files from the webroot path you provided.
user www-data; worker_processes 2; pid /run/nginx.pid; events { worker_connections 768; # multi_accept on; } http { sendfile on; tcp_nopush on; tcp_nodelay on; keepalive_timeout 65; types_hash_max_size 2048; server_tokens off; # server_names_hash_bucket_size 64; # server_name_in_redirect off; include /etc/nginx/mime.types; default_type application/octet-stream; ssl_protocols TLSv1 TLSv1.1 TLSv1.2; # Dropping SSLv3, ref: POODLE ssl_prefer_server_ciphers on; access_log /var/log/nginx/access.log; error_log /var/log/nginx/error.log; gzip on; gzip_disable "msie6"; # gzip_vary on; # gzip_proxied any; # gzip_comp_level 6; # gzip_buffers 16 8k; # gzip_http_version 1.1; # gzip_types text/plain text/css application/json application/javascript text/xml application/xml application/xml+rss text/javascript; # include /etc/nginx/conf.d/*.conf; include /etc/nginx/sites-enabled/*; }
# letsencrypt shizzle
ssl_certificate /etc/letsencrypt/live/xxx.ddns.net/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/xxx.ddns.net/privkey.pem;
ssl_stapling on;
ssl_stapling_verify on;
# maintain the .well-known directory alias for letsencrypt & renewals
auth_basic off;
server {
listen 8089 default_server;
location / {
return 301 https://$host$request_uri;
allow all;
# Sitemap
server {
auth_basic "Alexa";
location / {
index index.html;
# Alexa
server {
listen 8089 ssl;
server_name xxx.ddns.net;
auth_basic "Alexa";
location / {
proxy_pass http://192.168.178.168:8089/;
