alexa4p3: Plugin Definition ohne class_name und class_path
    Wenn ich das Alexa Plugin in der plugin.yaml wie folg definiere:
    alexa4p3:
      service_port: 9001
      plugin_name: alexa4p3
    bekomme ich beim starten:
    2019-11-23 20:21:09 INFO lib.shyaml Loading '/home/smarthome/smarthome_1.6.1/plugins/alexa4p3/plugin.yaml' to 'OrderedDict'
    2019-11-23 20:21:09 INFO lib.metadata plugin 'alexa4p3': Metadata paramlist = '['service_port']'
    2019-11-23 20:21:09 INFO lib.metadata plugin 'alexa4p3': Metadata itemdeflist = '['alexa_name', 'alexa_description', 'alexa_device', 'alexa_icon', 'alexa_actions', 'alexa_retrievable', 'alexa_proactivelyReported', 'alexa_types', 'alexa_item_range', 'alexa_item_turn_on', 'alexa_color_value_type', 'alexa_thermo_config', 'alexastream(1)1(2)(3)', 'alexa_csc_uri', 'alexa_auth_cred', 'alexa_camera_imageUri']'
    2019-11-23 20:21:09 ERROR lib.plugin Plugin 'alexa4p3' exception during execution of plugin: module 'plugins.alexa4p3' has no attribute 'alexap3'
    Traceback (most recent call last):
    File "/home/smarthome/smarthome_1.6.1/lib/plugin.py", line 553, in init
    exec("self.plugin = {0}.{1}.new({0}.{1})".format(classpath, classname))
    File "<string>", line 1, in <module>
    AttributeError: module 'plugins.alexa4p3' has no attribute 'alexap3'
    2019-11-23 20:21:09 INFO lib.shyaml Loading '/home/smarthome/smarthome_1.6.1/plugins/alexa4p3/locale.yaml' to 'dict'
    2019-11-23 20:21:09 ERROR lib.plugin Plugin 'alexa4p3' from section 'alexa4p3' exception: 'PluginWrapper' object has no attribute 'plugin'
    File "/home/smarthome/smarthome_1.6.1/lib/plugin.py", line 145, in init
    plugin_thread = PluginWrapper(smarthome, plugin, classname, classpath, args, instance, self.meta, self._gtrans)
    File "/home/smarthome/smarthome_1.6.1/lib/plugin.py", line 571, in init
    if isinstance(self.get_implementation(), SmartPlugin):
    File "/home/smarthome/smarthome_1.6.1/lib/plugin.py", line 715, in get_implementation
    return self.plugin
    AttributeError: 'PluginWrapper' object has no attribute 'plugin'
    2019-11-23 20:21:09 INFO lib.plugin Load of plugins finished
    Mit class_name und class_path funktioniert es:
    alexa4p3:
      class_name: Alexa4P3
      class_path: plugins.alexa4p3
      service_port: 9001
    Mache ich was falsch oder gibt es da einen Bug im Alexa Plugin?
    LG
    mode
    PS: SmarthomeNG und plugins sind auf dem aktuellen MASTER Branch...
    Zuletzt geändert von mode; 23.11.2019, 21:26.
    Da ist ein Fehler im Plugin. In den Metadaten (plugin.yaml des Plugins) steht:
    # Metadata for the Smart-Plugin
    plugin:
        # Global plugin attributes
        type: web                       # plugin type (gateway, interface, protocol, system, web)
        classname: alexa4p3    # class containing the plugin
    Der classname ist aber Case-Sensitiv. Das muss
         classname: Alexa4P3   # class containing the plugin
    heissen.
    Martin
      habs mal gefixt in den dev gepusht..
