Zitat von bkr
Mfg,
2015-05-19 14:53:28,568 INFO Thread-3 Starting new HTTP connection (1): 192.168.133.56 -- connectionpool.py:_new_conn:188
2015-05-19 14:53:28,809 DEBUG Thread-3 "POST /MediaRenderer/AVTransport/Control HTTP/1.1" 200 382 -- connectionpool.py:_make_request:362
2015-05-19 14:53:28,822 DEBUG Thread-3 Received {'CONTENT-LENGTH': '382', 'EXT': '', 'CONTENT-TYPE': 'text/xml; charset="utf-8"', 'Connection': 'close', 'Server': 'Linux UPnP/1.0 Sonos/28.1-86173 (ZP90)'}, <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:AddURIToQueueResponse xmlns:u="urn:schemas-upnp-org:service:AVTransport:1"><FirstTrackNumberEnqueued>18</FirstTrackNumberEnqueued><NumTracksAdded>1</NumTracksAdded><NewQueueLength>18</NewQueueLength></u:AddURIToQueueResponse></s:Body></s:Envelope> -- services.py:send_command:337
2015-05-19 14:53:28,829 INFO Thread-3 Received status 200 from 192.168.133.56 -- services.py:send_command:340
2015-05-19 14:53:28,845 INFO Thread-3 Sending AddURIToQueue [('InstanceID', 0), ('EnqueuedURI', 'x-sonos-spotify:spotify%3atrack%3a5ITnp8E1i4x3TVwVEX8cmZ?sid=9&flags=32'), ('EnqueuedURIMetaData', b'<DIDL-Lite xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/"><item id="Q:0/19" parentID="Q:0" restricted="true"><dc:title>x-sonos-spotify:spotify:track:5ITnp8E1i4x3TVwVEX8cmZ?sid=9&flags=32</dc:title><res protocolInfo="sonos.com-spotify:*:application/octet-stream:*">x-sonos-spotify:spotify%3atrack%3a5ITnp8E1i4x3TVwVEX8cmZ?sid=9&flags=32</res><upnp:albumArtURI>/getaa?s=1&u=x-sonos-spotify%3aspotify%253atrack%253a5ITnp8E1i4x3TVwVEX8cmZ%3fsid%3d9%26flags%3d32</upnp:albumArtURI><upnp:class>object.item</upnp:class><desc id="cdudn" nameSpace="urn:schemas-rinconnetworks-com:metadata-1-0/" /></item></DIDL-Lite>'), ('DesiredFirstTrackNumberEnqueued', 0), ('EnqueueAsNext', 1)] to 192.168.133.56 -- services.py:send_command:329
2015-05-19 14:53:28,866 DEBUG Thread-3 Sending {'SOAPACTION': 'urn:schemas-upnp-org:service:AVTransport:1#AddURIToQueue', 'Content-Type': 'text/xml; charset="utf-8"'}, <?xml version="1.0" ?>
<s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schemas.xmlsoap.org/soap/envelope/">
<s:Body>
<u:AddURIToQueue xmlns:u="urn:schemas-upnp-org:service:AVTransport:1">
<InstanceID>0</InstanceID>
<EnqueuedURI>x-sonos-spotify:spotify%3atrack%3a5ITnp8E1i4x3TVwVEX8cmZ?sid=9&flags=32</EnqueuedURI>
<EnqueuedURIMetaData>b'<DIDL-Lite xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/"><item id="Q:0/19" parentID="Q:0" restricted="true"><dc:title>x-sonos-spotify:spotify:track:5ITnp8E1i4x3TVwVEX8cmZ?sid=9&amp;flags=32</dc:title><res protocolInfo="sonos.com-spotify:*:application/octet-stream:*">x-sonos-spotify:spotify%3atrack%3a5ITnp8E1i4x3TVwVEX8cmZ?sid=9&amp;flags=32</res><upnp:albumArtURI>/getaa?s=1&amp;u=x-sonos-spotify%3aspotify%253atrack%253a5ITnp8E1i4x3TVwVEX8cmZ%3fsid%3d9%26flags%3d32</upnp:albumArtURI><upnp:class>object.item</upnp:class><desc id="cdudn" nameSpace="urn:schemas-rinconnetworks-com:metadata-1-0/" /></item></DIDL-Lite>'</EnqueuedURIMetaData>
<DesiredFirstTrackNumberEnqueued>0</DesiredFirstTrackNumberEnqueued>
<EnqueueAsNext>1</EnqueueAsNext>
</u:AddURIToQueue>
</s:Body>
</s:Envelope>
-- services.py:send_command:330
echo Meine Oma faehrt im Huehnerstall Motorrad brumm brumm rrrrr 127.0.0.1 10234
sonos]
class_name = Sonos
class_path = plugins.sonos
broker_url = 192.168.101.45:12900 #optional
#refresh = 120 #optional
<div class="block"> <div class="set-1" data-role="collapsible-set" data-theme="c" data-content-theme="a" data-mini="true"> <div data-role="collapsible" data-collapsed="false"> <h3>Music </h3> {% import "sonos.html" as sonos %} {{ sonos.music('sonos', 'Sonos.KuecheLautsprecher.play', 'Sonos.KuecheLautsprecher.stop', 'Sonos.KuecheLautsprecher.prev', 'Sonos.KuecheLautsprecher.next', 'Sonos.KuecheLautsprecher.vol_up', 'Sonos.KuecheLautsprecher.vol_down', 'Sonos.KuecheLautsprecher.volume', 'Sonos.KuecheLautsprecher.mute', 'Sonos.KuecheLautsprecher.album_art', 'Sonos.KuecheLautsprecher.artist', 'Sonos.KuecheLautsprecher.title') }} </div> </div> </div> </div>
Init SmartHome.py 1.0-41-g0c41302 2015-04-21 21:50:34 ERROR Connections KNX: could not connect to 192.168.101.45:6720 (TCP): [Errno 111] Verbindungsaufbau abgelehnt 2015-04-21 21:50:47 WARNING Main Item Sonos.KuecheLautsprecher.is_coordinator: value normal does not match type bool. Via Sonos
http://workupload.com/file/JlbSsoEp
