2014-03-22 10:53:32,764 INFO Main Start SmartHome.py 1.0-32-gfd0043e -- smarthome.py:__init__:231
2014-03-22 10:53:32,769 DEBUG Main Python 3.2.3 -- smarthome.py:__init__:232
2014-03-22 10:53:32,776 INFO Main Init Scheduler -- scheduler.py:__init__:86
2014-03-22 10:53:32,783 INFO Main Init Plugins -- smarthome.py:start:274
2014-03-22 10:53:32,798 DEBUG Scheduler creating 5 workers -- scheduler.py:run:93
2014-03-22 10:53:32,806 DEBUG Main Plugin: knx -- plugin.py:__init__:43
2014-03-22 10:53:32,831 DEBUG Main Plugin: visu -- plugin.py:__init__:43
2014-03-22 10:53:32,925 DEBUG Main Plugin: cli -- plugin.py:__init__:43
2014-03-22 10:53:32,938 DEBUG Main Plugin: sql -- plugin.py:__init__:43
2014-03-22 10:53:32,970 DEBUG Main SQLite 3.7.13 -- __init__.py:__init__:62
2014-03-22 10:53:36,237 DEBUG Main SQLite: database integrity ok -- __init__.py:__init__:78
2014-03-22 10:53:36,264 DEBUG Main SQLite pack next time: 2014-03-23 03:02:00+01:00 -- scheduler.py:_next_time:289
2014-03-22 10:53:36,271 INFO Main Init Items -- smarthome.py:start:280
2014-03-22 10:53:36,504 ERROR Main Problem parsing '/usr/smarthome/items/smartvisu.conf' invalid character in line 510: [[[[Kreis A]]]]. Valid characters are: abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789_ -- config.py:parse:66
2014-03-22 10:53:36,893 DEBUG Main Item env.core.memory = 15949824.0 via SQLite None None -- item.py:set:457
2014-03-22 10:53:37,263 DEBUG Main Item env.core.threads = 7.0 via SQLite None None -- item.py:set:457
2014-03-22 10:53:37,623 DEBUG Main Item env.core.garbage = 0.0 via SQLite None None -- item.py:set:457
2014-03-22 10:53:37,629 DEBUG Main Item env.core: no type specified. -- item.py:__init__:242
2014-03-22 10:53:37,673 DEBUG Main Item env.location: no type specified. -- item.py:__init__:242
2014-03-22 10:53:38,036 DEBUG Main Item env.system.load = 0.13 via SQLite None None -- item.py:set:457
2014-03-22 10:53:38,047 DEBUG Main Item env.system: no type specified. -- item.py:__init__:242
2014-03-22 10:53:38,051 DEBUG Main Item env: no type specified. -- item.py:__init__:242
2014-03-22 10:53:38,071 DEBUG Main KNX: EG.Flur.Deckenlicht.Schalten listen on 1/1/2 -- __init__.py:parse_item:235
2014-03-22 10:53:38,075 DEBUG Main KNX: EG.Flur.Deckenlicht.Schalten listen on and init with 1/1/1 -- __init__.py:parse_item:244
2014-03-22 10:53:38,084 DEBUG Main KNX: EG.Flur.Deckenlicht.Dimmen listen on and init with 1/1/4 -- __init__.py:parse_item:244
2014-03-22 10:53:38,089 DEBUG Main Item EG.Flur.Deckenlicht: no type specified. -- item.py:__init__:242
2014-03-22 10:53:38,102 DEBUG Main KNX: EG.Flur.Steckdose.Schalten listen on 4/1/81 -- __init__.py:parse_item:235
2014-03-22 10:53:38,107 DEBUG Main KNX: EG.Flur.Steckdose.Schalten listen on and init with 4/1/80 -- __init__.py:parse_item:244
2014-03-22 10:53:38,112 DEBUG Main KNX: EG.Flur.Steckdose listen on 1/1/2 -- __init__.py:parse_item:235
2014-03-22 10:53:38,119 DEBUG Main KNX: EG.Flur.Steckdose listen on and init with 1/1/1 -- __init__.py:parse_item:244
2014-03-22 10:53:38,128 DEBUG Main KNX: EG.Flur.Tueroeffner listen on and init with 4/1/1 -- __init__.py:parse_item:244
2014-03-22 10:53:38,137 DEBUG Main KNX: EG.Flur.Eingangsbeleuchtung listen on 1/5/2 -- __init__.py:parse_item:235
2014-03-22 10:53:38,142 DEBUG Main KNX: EG.Flur.Eingangsbeleuchtung listen on and init with 1/5/1 -- __init__.py:parse_item:244
2014-03-22 10:53:38,147 DEBUG Main Item EG.Flur: no type specified. -- item.py:__init__:242
2014-03-22 10:53:38,163 DEBUG Main KNX: EG.Arbeiten.Deckenlicht.Schalten listen on 1/1/20 -- __init__.py:parse_item:235
2014-03-22 10:53:38,167 DEBUG Main KNX: EG.Arbeiten.Deckenlicht.Schalten listen on and init with 1/1/20 -- __init__.py:parse_item:244
2014-03-22 10:53:38,172 DEBUG Main Item EG.Arbeiten.Deckenlicht: no type specified. -- item.py:__init__:242
2014-03-22 10:53:38,188 DEBUG Main KNX: EG.Arbeiten.Rollo.Move listen on and init with 2/1/1 -- __init__.py:parse_item:244
2014-03-22 10:53:38,197 DEBUG Main KNX: EG.Arbeiten.Rollo.Stop listen on and init with 2/1/2 -- __init__.py:parse_item:244
2014-03-22 10:53:38,206 DEBUG Main KNX: EG.Arbeiten.Rollo.PosFahren listen on and init with 2/1/4 -- __init__.py:parse_item:244
2014-03-22 10:53:38,212 DEBUG Main Item EG.Arbeiten.Rollo: no type specified. -- item.py:__init__:242
2014-03-22 10:53:38,220 DEBUG Main KNX: EG.Arbeiten.Temperatur listen on 15/5/18 -- __init__.py:parse_item:235
2014-03-22 10:53:38,227 DEBUG Main Item EG.Arbeiten: no type specified. -- item.py:__init__:242
2014-03-22 10:53:38,243 DEBUG Main KNX: EG.GaesteWC.Deckenlicht.Schalten listen on 1/1/26 -- __init__.py:parse_item:235
2014-03-22 10:53:38,248 DEBUG Main KNX: EG.GaesteWC.Deckenlicht.Schalten listen on and init with 1/1/26 -- __init__.py:parse_item:244
2014-03-22 10:53:38,253 DEBUG Main Item EG.GaesteWC.Deckenlicht: no type specified. -- item.py:__init__:242
2014-03-22 10:53:38,265 DEBUG Main KNX: EG.GaesteWC.Spiegellicht.Schalten listen on 1/1/29 -- __init__.py:parse_item:235
2014-03-22 10:53:38,270 DEBUG Main KNX: EG.GaesteWC.Spiegellicht.Schalten listen on and init with 1/1/28 -- __init__.py:parse_item:244
2014-03-22 10:53:38,275 DEBUG Main Item EG.GaesteWC.Spiegellicht: no type specified. -- item.py:__init__:242
2014-03-22 10:53:38,287 DEBUG Main KNX: EG.GaesteWC.Rollo.Move listen on and init with 2/1/11 -- __init__.py:parse_item:244
2014-03-22 10:53:38,296 DEBUG Main KNX: EG.GaesteWC.Rollo.Stop listen on and init with 2/1/12 -- __init__.py:parse_item:244
2014-03-22 10:53:38,302 DEBUG Main Item EG.GaesteWC.Rollo: no type specified. -- item.py:__init__:242
2014-03-22 10:53:38,310 DEBUG Main KNX: EG.GaesteWC.Temperatur listen on 15/5/19 -- __init__.py:parse_item:235
2014-03-22 10:53:38,317 DEBUG Main Item EG.GaesteWC: no type specified. -- item.py:__init__:242
2014-03-22 10:53:38,333 DEBUG Main KNX: EG.Wohnen.Deckenlicht.Schalten listen on 1/1/35 -- __init__.py:parse_item:235
2014-03-22 10:53:38,338 DEBUG Main KNX: EG.Wohnen.Deckenlicht.Schalten listen on and init with 1/1/34 -- __init__.py:parse_item:244
2014-03-22 10:53:38,347 DEBUG Main KNX: EG.Wohnen.Deckenlicht.Dimmen listen on and init with 1/1/37 -- __init__.py:parse_item:244
2014-03-22 10:53:38,352 DEBUG Main Item EG.Wohnen.Deckenlicht: no type specified. -- item.py:__init__:242
2014-03-22 10:53:38,365 DEBUG Main KNX: EG.Wohnen.Wandlicht.Schalten listen on 1/1/45 -- __init__.py:parse_item:235
2014-03-22 10:53:38,370 DEBUG Main KNX: EG.Wohnen.Wandlicht.Schalten listen on and init with 1/1/44 -- __init__.py:parse_item:244
2014-03-22 10:53:38,379 DEBUG Main KNX: EG.Wohnen.Wandlicht.Dimmen listen on 1/1/47 -- __init__.py:parse_item:235
2014-03-22 10:53:38,384 DEBUG Main KNX: EG.Wohnen.Wandlicht.Dimmen listen on and init with 1/1/47 -- __init__.py:parse_item:244
2014-03-22 10:53:38,389 DEBUG Main Item EG.Wohnen.Wandlicht: no type specified. -- item.py:__init__:242
2014-03-22 10:53:38,401 DEBUG Main KNX: EG.Wohnen.Rollo.Move listen on and init with 2/1/21 -- __init__.py:parse_item:244
2014-03-22 10:53:38,411 DEBUG Main KNX: EG.Wohnen.Rollo.Stop listen on and init with 2/1/22 -- __init__.py:parse_item:244
2014-03-22 10:53:38,421 DEBUG Main Item EG.Wohnen.Rollo.PosFahren: no type specified. -- item.py:__init__:242
2014-03-22 10:53:38,425 DEBUG Main Item EG.Wohnen.Rollo: no type specified. -- item.py:__init__:242
2014-03-22 10:53:38,434 DEBUG Main KNX: EG.Wohnen.Temperatur listen on 15/5/20 -- __init__.py:parse_item:235
2014-03-22 10:53:38,441 DEBUG Main Item EG.Wohnen: no type specified. -- item.py:__init__:242
2014-03-22 10:53:38,457 DEBUG Main KNX: EG.Erker.Deckenlicht.Schalten listen on and init with 1/1/104 -- __init__.py:parse_item:244
2014-03-22 10:53:38,467 DEBUG Main KNX: EG.Erker.Deckenlicht.Dimmen listen on and init with 1/1/106 -- __init__.py:parse_item:244
2014-03-22 10:53:38,472 DEBUG Main Item EG.Erker.Deckenlicht: no type specified. -- item.py:__init__:242
2014-03-22 10:53:38,484 DEBUG Main KNX: EG.Erker.Steckdose.Schalten listen on 4/1/104 -- __init__.py:parse_item:235
2014-03-22 10:53:38,488 DEBUG Main KNX: EG.Erker.Steckdose.Schalten listen on and init with 4/1/104 -- __init__.py:parse_item:244
2014-03-22 10:53:38,494 DEBUG Main Item EG.Erker.Steckdose: no type specified. -- item.py:__init__:242
2014-03-22 10:53:38,506 DEBUG Main KNX: EG.Erker.Rollo2.Move listen on and init with 2/1/31 -- __init__.py:parse_item:244
2014-03-22 10:53:38,518 DEBUG Main KNX: EG.Erker.Rollo2.Stop listen on and init with 2/1/32 -- __init__.py:parse_item:244
2014-03-22 10:53:38,527 DEBUG Main Item EG.Erker.Rollo2.PosFahren: no type specified. -- item.py:__init__:242
2014-03-22 10:53:38,531 DEBUG Main Item EG.Erker.Rollo2: no type specified. -- item.py:__init__:242
2014-03-22 10:53:38,544 DEBUG Main KNX: EG.Erker.Rollo3.Move listen on and init with 2/1/41 -- __init__.py:parse_item:244
2014-03-22 10:53:38,553 DEBUG Main KNX: EG.Erker.Rollo3.Stop listen on and init with 2/1/42 -- __init__.py:parse_item:244
2014-03-22 10:53:38,561 DEBUG Main Item EG.Erker.Rollo3.PosFahren: no type specified. -- item.py:__init__:242
2014-03-22 10:53:38,566 DEBUG Main Item EG.Erker.Rollo3: no type specified. -- item.py:__init__:242
2014-03-22 10:53:38,579 DEBUG Main KNX: EG.Erker.Rollo4.Move listen on and init with 2/1/51 -- __init__.py:parse_item:244
2014-03-22 10:53:38,588 DEBUG Main KNX: EG.Erker.Rollo4.Stop listen on and init with 2/1/52 -- __init__.py:parse_item:244
2014-03-22 10:53:38,596 DEBUG Main Item EG.Erker.Rollo4.PosFahren: no type specified. -- item.py:__init__:242
2014-03-22 10:53:38,601 DEBUG Main Item EG.Erker.Rollo4: no type specified. -- item.py:__init__:242
2014-03-22 10:53:38,610 DEBUG Main KNX: EG.Erker.Temperatur listen on 15/5/20 -- __init__.py:parse_item:235
2014-03-22 10:53:38,615 DEBUG Main Item EG.Erker: no type specified. -- item.py:__init__:242
2014-03-22 10:53:38,620 DEBUG Main Item EG: no type specified. -- item.py:__init__:242
2014-03-22 10:53:38,639 DEBUG Main KNX: OG.Flur.DeckenlichtAlle.Schalten listen on 1/2/2 -- __init__.py:parse_item:235
2014-03-22 10:53:38,644 DEBUG Main KNX: OG.Flur.DeckenlichtAlle.Schalten listen on and init with 1/2/2 -- __init__.py:parse_item:244
2014-03-22 10:53:38,653 DEBUG Main KNX: OG.Flur.DeckenlichtAlle.Dimmen listen on 1/2/3 -- __init__.py:parse_item:235
2014-03-22 10:53:38,658 DEBUG Main KNX: OG.Flur.DeckenlichtAlle.Dimmen listen on and init with 1/2/3 -- __init__.py:parse_item:244
2014-03-22 10:53:38,666 DEBUG Main Item OG.Flur.DeckenlichtAlle.Dimmert: no type specified. -- item.py:__init__:242
2014-03-22 10:53:38,671 DEBUG Main Item OG.Flur.DeckenlichtAlle: no type specified. -- item.py:__init__:242
2014-03-22 10:53:38,683 DEBUG Main KNX: OG.Flur.DeckenlichtSchlafen.Schalten listen on 1/2/4 -- __init__.py:parse_item:235
2014-03-22 10:53:38,688 DEBUG Main KNX: OG.Flur.DeckenlichtSchlafen.Schalten listen on and init with 1/2/4 -- __init__.py:parse_item:244
2014-03-22 10:53:38,697 DEBUG Main KNX: OG.Flur.DeckenlichtSchlafen.Dimmen listen on 1/2/5 -- __init__.py:parse_item:235
2014-03-22 10:53:38,702 DEBUG Main KNX: OG.Flur.DeckenlichtSchlafen.Dimmen listen on and init with 1/2/5 -- __init__.py:parse_item:244
2014-03-22 10:53:38,707 DEBUG Main Item OG.Flur.DeckenlichtSchlafen: no type specified. -- item.py:__init__:242
2014-03-22 10:53:38,715 DEBUG Main Item OG.Flur.Temperatur: no type specified. -- item.py:__init__:242
2014-03-22 10:53:38,727 DEBUG Main Item OG.Flur.Steckdose.Schalten: no type specified. -- item.py:__init__:242
2014-03-22 10:53:38,732 DEBUG Main Item OG.Flur.Steckdose: no type specified. -- item.py:__init__:242
2014-03-22 10:53:38,737 DEBUG Main Item OG.Flur: no type specified. -- item.py:__init__:242
2014-03-22 10:53:38,753 DEBUG Main KNX: OG.Eltern.Deckenlicht.Schalten listen on 1/2/22 -- __init__.py:parse_item:235
2014-03-22 10:53:38,758 DEBUG Main KNX: OG.Eltern.Deckenlicht.Schalten listen on and init with 1/2/22 -- __init__.py:parse_item:244
2014-03-22 10:53:38,763 DEBUG Main Item OG.Eltern.Deckenlicht: no type specified. -- item.py:__init__:242
2014-03-22 10:53:38,775 DEBUG Main KNX: OG.Eltern.Rollo.Move listen on and init with 2/2/1 -- __init__.py:parse_item:244
2014-03-22 10:53:38,785 DEBUG Main KNX: OG.Eltern.Rollo.Stop listen on and init with 2/2/2 -- __init__.py:parse_item:244
2014-03-22 10:53:38,793 DEBUG Main Item OG.Eltern.Rollo.PosFahren: no type specified. -- item.py:__init__:242
2014-03-22 10:53:38,798 DEBUG Main Item OG.Eltern.Rollo: no type specified. -- item.py:__init__:242
2014-03-22 10:53:38,807 DEBUG Main KNX: OG.Eltern.Temperatur listen on 7/1/50 -- __init__.py:parse_item:235
2014-03-22 10:53:38,814 DEBUG Main Item OG.Eltern: no type specified. -- item.py:__init__:242
2014-03-22 10:53:38,831 DEBUG Main KNX: OG.Elias.Deckenlicht.Schalten listen on 1/2/38 -- __init__.py:parse_item:235
2014-03-22 10:53:38,836 DEBUG Main KNX: OG.Elias.Deckenlicht.Schalten listen on and init with 1/2/38 -- __init__.py:parse_item:244
2014-03-22 10:53:38,841 DEBUG Main Item OG.Elias.Deckenlicht: no type specified. -- item.py:__init__:242
2014-03-22 10:53:38,854 DEBUG Main KNX: OG.Elias.RolloLinks.Move listen on and init with 2/2/11 -- __init__.py:parse_item:244
2014-03-22 10:53:38,867 DEBUG Main KNX: OG.Elias.RolloLinks.Stop listen on and init with 2/2/12 -- __init__.py:parse_item:244
2014-03-22 10:53:38,876 DEBUG Main Item OG.Elias.RolloLinks.PosFahren: no type specified. -- item.py:__init__:242
2014-03-22 10:53:38,881 DEBUG Main Item OG.Elias.RolloLinks: no type specified. -- item.py:__init__:242
2014-03-22 10:53:38,894 DEBUG Main KNX: OG.Elias.RolloRechts.Move listen on and init with 2/2/21 -- __init__.py:parse_item:244
2014-03-22 10:53:38,904 DEBUG Main KNX: OG.Elias.RolloRechts.Stop listen on and init with 2/2/22 -- __init__.py:parse_item:244
2014-03-22 10:53:38,913 DEBUG Main Item OG.Elias.RolloRechts.PosFahren: no type specified. -- item.py:__init__:242
2014-03-22 10:53:38,919 DEBUG Main Item OG.Elias.RolloRechts: no type specified. -- item.py:__init__:242
2014-03-22 10:53:38,928 DEBUG Main KNX: OG.Elias.Temperatur listen on 15/5/21 -- __init__.py:parse_item:235
2014-03-22 10:53:38,935 DEBUG Main Item OG.Elias: no type specified. -- item.py:__init__:242
2014-03-22 10:53:38,952 DEBUG Main KNX: OG.Lina.Deckenlicht.Schalten listen on 1/2/56 -- __init__.py:parse_item:235
2014-03-22 10:53:38,956 DEBUG Main KNX: OG.Lina.Deckenlicht.Schalten listen on and init with 1/2/56 -- __init__.py:parse_item:244
2014-03-22 10:53:38,961 DEBUG Main Item OG.Lina.Deckenlicht: no type specified. -- item.py:__init__:242
2014-03-22 10:53:38,974 DEBUG Main KNX: OG.Lina.RolloLinks.Move listen on and init with 2/2/31 -- __init__.py:parse_item:244
2014-03-22 10:53:38,983 DEBUG Main KNX: OG.Lina.RolloLinks.Stop listen on and init with 2/2/32 -- __init__.py:parse_item:244
2014-03-22 10:53:38,992 DEBUG Main Item OG.Lina.RolloLinks.PosFahren: no type specified. -- item.py:__init__:242
2014-03-22 10:53:38,997 DEBUG Main Item OG.Lina.RolloLinks: no type specified. -- item.py:__init__:242
2014-03-22 10:53:39,010 DEBUG Main KNX: OG.Lina.RolloRechts.Move listen on and init with 2/2/41 -- __init__.py:parse_item:244
2014-03-22 10:53:39,020 DEBUG Main KNX: OG.Lina.RolloRechts.Stop listen on and init with 2/2/42 -- __init__.py:parse_item:244
2014-03-22 10:53:39,029 DEBUG Main Item OG.Lina.RolloRechts.PosFahren: no type specified. -- item.py:__init__:242
2014-03-22 10:53:39,033 DEBUG Main Item OG.Lina.RolloRechts: no type specified. -- item.py:__init__:242
2014-03-22 10:53:39,043 DEBUG Main KNX: OG.Lina.Temperatur listen on 15/5/22 -- __init__.py:parse_item:235
2014-03-22 10:53:39,050 DEBUG Main Item OG.Lina: no type specified. -- item.py:__init__:242
2014-03-22 10:53:39,067 DEBUG Main KNX: OG.Abstellraum.Deckenlicht.Schalten listen on 1/2/60 -- __init__.py:parse_item:235
2014-03-22 10:53:39,071 DEBUG Main KNX: OG.Abstellraum.Deckenlicht.Schalten listen on and init with 1/2/60 -- __init__.py:parse_item:244
2014-03-22 10:53:39,077 DEBUG Main Item OG.Abstellraum.Deckenlicht: no type specified. -- item.py:__init__:242
2014-03-22 10:53:39,081 DEBUG Main Item OG.Abstellraum: no type specified. -- item.py:__init__:242
2014-03-22 10:53:39,098 DEBUG Main KNX: OG.Bad.Deckenlicht.Schalten listen on 1/2/80 -- __init__.py:parse_item:235
2014-03-22 10:53:39,103 DEBUG Main KNX: OG.Bad.Deckenlicht.Schalten listen on and init with 1/2/80 -- __init__.py:parse_item:244
2014-03-22 10:53:39,113 DEBUG Main KNX: OG.Bad.Deckenlicht.Dimmen listen on 1/2/81 -- __init__.py:parse_item:235
2014-03-22 10:53:39,117 DEBUG Main KNX: OG.Bad.Deckenlicht.Dimmen listen on and init with 1/2/81 -- __init__.py:parse_item:244
2014-03-22 10:53:39,122 DEBUG Main Item OG.Bad.Deckenlicht: no type specified. -- item.py:__init__:242
2014-03-22 10:53:39,136 DEBUG Main KNX: OG.Bad.Rollo.Move listen on and init with 2/2/51 -- __init__.py:parse_item:244
2014-03-22 10:53:39,145 DEBUG Main KNX: OG.Bad.Rollo.Stop listen on and init with 2/2/52 -- __init__.py:parse_item:244
2014-03-22 10:53:39,154 DEBUG Main Item OG.Bad.Rollo.PosFahren: no type specified. -- item.py:__init__:242
2014-03-22 10:53:39,159 DEBUG Main Item OG.Bad.Rollo: no type specified. -- item.py:__init__:242
2014-03-22 10:53:39,172 DEBUG Main Item OG.Bad.Steckdose.Schalten: no type specified. -- item.py:__init__:242
2014-03-22 10:53:39,177 DEBUG Main KNX: OG.Bad.Steckdose listen on and init with 4/2/80 -- __init__.py:parse_item:244
2014-03-22 10:53:39,186 DEBUG Main KNX: OG.Bad.Temperatur listen on 7/1/30 -- __init__.py:parse_item:235
2014-03-22 10:53:39,191 DEBUG Main Item OG.Bad: no type specified. -- item.py:__init__:242
2014-03-22 10:53:39,208 DEBUG Main Item OG.Spitzboden.Deckenlicht.Schalten: no type specified. -- item.py:__init__:242
2014-03-22 10:53:39,213 DEBUG Main Item OG.Spitzboden.Deckenlicht: no type specified. -- item.py:__init__:242
2014-03-22 10:53:39,228 DEBUG Main KNX: OG.Spitzboden.Rollo.Move listen on and init with 2/2/61 -- __init__.py:parse_item:244
2014-03-22 10:53:39,238 DEBUG Main KNX: OG.Spitzboden.Rollo.Stop listen on and init with 2/2/62 -- __init__.py:parse_item:244
2014-03-22 10:53:39,246 DEBUG Main Item OG.Spitzboden.Rollo.PosFahren: no type specified. -- item.py:__init__:242
2014-03-22 10:53:39,251 DEBUG Main Item OG.Spitzboden.Rollo: no type specified. -- item.py:__init__:242
2014-03-22 10:53:39,260 DEBUG Main KNX: OG.Spitzboden.Temperatur listen on 15/5/13 -- __init__.py:parse_item:235
2014-03-22 10:53:39,265 DEBUG Main Item OG.Spitzboden: no type specified. -- item.py:__init__:242
2014-03-22 10:53:39,270 DEBUG Main Item OG: no type specified. -- item.py:__init__:242
2014-03-22 10:53:39,289 DEBUG Main KNX: Aussen.Garage.Deckenlicht.Schalten listen on 1/7/0 -- __init__.py:parse_item:235
2014-03-22 10:53:39,294 DEBUG Main KNX: Aussen.Garage.Deckenlicht.Schalten listen on and init with 1/7/0 -- __init__.py:parse_item:244
2014-03-22 10:53:39,299 DEBUG Main Item Aussen.Garage.Deckenlicht: no type specified. -- item.py:__init__:242
2014-03-22 10:53:39,311 DEBUG Main KNX: Aussen.Garage.Torlicht.Schalten listen on 1/7/2 -- __init__.py:parse_item:235
2014-03-22 10:53:39,316 DEBUG Main KNX: Aussen.Garage.Torlicht.Schalten listen on and init with 1/7/1 -- __init__.py:parse_item:244
2014-03-22 10:53:39,321 DEBUG Main Item Aussen.Garage.Torlicht: no type specified. -- item.py:__init__:242
2014-03-22 10:53:39,333 DEBUG Main Item Aussen.Garage.Tor.Auf: no type specified. -- item.py:__init__:242
2014-03-22 10:53:39,337 DEBUG Main Item Aussen.Garage.Tor: no type specified. -- item.py:__init__:242
2014-03-22 10:53:39,350 DEBUG Main KNX: Aussen.Garage.Einfahrtbeleuchtung.Schalten listen on 1/5/10 -- __init__.py:parse_item:235
2014-03-22 10:53:39,355 DEBUG Main KNX: Aussen.Garage.Einfahrtbeleuchtung.Schalten listen on and init with 1/5/10 -- __init__.py:parse_item:244
2014-03-22 10:53:39,360 DEBUG Main Item Aussen.Garage.Einfahrtbeleuchtung: no type specified. -- item.py:__init__:242
2014-03-22 10:53:39,364 DEBUG Main Item Aussen.Garage: no type specified. -- item.py:__init__:242
2014-03-22 10:53:39,380 DEBUG Main KNX: Aussen.Garten.Beleuchtung.Schalten listen on 4/5/15 -- __init__.py:parse_item:235
2014-03-22 10:53:39,385 DEBUG Main KNX: Aussen.Garten.Beleuchtung.Schalten listen on and init with 4/5/15 -- __init__.py:parse_item:244
2014-03-22 10:53:39,390 DEBUG Main Item Aussen.Garten.Beleuchtung: no type specified. -- item.py:__init__:242
2014-03-22 10:53:39,402 DEBUG Main Item Aussen.Garten.Steckdose.Schalten: no type specified. -- item.py:__init__:242
2014-03-22 10:53:39,407 DEBUG Main Item Aussen.Garten.Steckdose: no type specified. -- item.py:__init__:242
2014-03-22 10:53:39,415 DEBUG Main Item Aussen.Garten.Bewaesserung: no type specified. -- item.py:__init__:242
2014-03-22 10:53:39,421 DEBUG Main Item Aussen.Garten: no type specified. -- item.py:__init__:242
2014-03-22 10:53:39,426 DEBUG Main Item Aussen: no type specified. -- item.py:__init__:242
2014-03-22 10:53:39,439 INFO Main Start Plugins -- plugin.py:start:65
2014-03-22 10:53:39,488 INFO Main Start Logics -- logic.py:__init__:33
2014-03-22 10:53:39,493 DEBUG Main Reading Logics from /usr/smarthome/lib/env/logic_conf -- logic.py:_read_logics:64
2014-03-22 10:53:39,550 DEBUG Main Reading Logics from /usr/smarthome/etc/logic.conf -- logic.py:_read_logics:64
2014-03-22 10:53:39,560 DEBUG Main Logic: dummy -- logic.py:__init__:44
2014-03-22 10:53:39,575 WARNING Main dummy: No filename specified => ignoring. -- logic.py:generate_bytecode:123
2014-03-22 10:53:39,587 DEBUG Main Logic: hello -- logic.py:__init__:44
2014-03-22 10:53:39,644 DEBUG Main Logic: env_init -- logic.py:__init__:44
2014-03-22 10:53:39,663 DEBUG Main Logic: env_stat -- logic.py:__init__:44
2014-03-22 10:53:39,695 DEBUG Main env_stat next time: 2014-03-22 10:53:49+01:00 -- scheduler.py:_next_time:289
2014-03-22 10:53:39,705 DEBUG Main Logic: env_loc -- logic.py:__init__:44
2014-03-22 10:53:40,007 DEBUG Connections KNX: connected to 192.168.2.26:6720 -- connection.py:connect:386
2014-03-22 10:53:40,012 DEBUG Connections KNX: enable group monitor -- __init__.py:handle_connect:117
2014-03-22 10:53:40,017 DEBUG Connections KNX: init read -- __init__.py:handle_connect:123
2014-03-22 10:53:40,054 DEBUG Connections WebSocket: binding to 0.0.0.0:2424 (TCP) -- connection.py:connect:161
2014-03-22 10:53:40,060 DEBUG Connections CLI: binding to 0.0.0.0:2323 (TCP) -- connection.py:connect:161
2014-03-22 10:53:40,751 DEBUG Main KNX: 0.0.0 read 1/1/1 -- __init__.py:parse_telegram:203
2014-03-22 10:53:40,769 DEBUG Main KNX: 0.0.0 read 1/1/4 -- __init__.py:parse_telegram:203
2014-03-22 10:53:40,785 DEBUG Main KNX: 0.0.0 read 4/1/80 -- __init__.py:parse_telegram:203
2014-03-22 10:53:40,803 DEBUG Main KNX: 0.0.0 read 1/1/1 -- __init__.py:parse_telegram:203
2014-03-22 10:53:40,819 DEBUG Main KNX: 0.0.0 read 4/1/1 -- __init__.py:parse_telegram:203
2014-03-22 10:53:40,836 DEBUG Main KNX: 0.0.0 read 1/5/1 -- __init__.py:parse_telegram:203
2014-03-22 10:53:40,857 DEBUG Main KNX: 0.0.0 read 1/1/20 -- __init__.py:parse_telegram:203
2014-03-22 10:53:40,874 DEBUG Main KNX: 0.0.0 read 2/1/1 -- __init__.py:parse_telegram:203
2014-03-22 10:53:40,894 DEBUG Main KNX: 0.0.0 read 2/1/2 -- __init__.py:parse_telegram:203
2014-03-22 10:53:40,907 DEBUG Main KNX: 0.0.0 read 2/1/4 -- __init__.py:parse_telegram:203
2014-03-22 10:53:40,927 DEBUG Main KNX: 0.0.0 read 1/1/26 -- __init__.py:parse_telegram:203
2014-03-22 10:53:40,948 DEBUG Main KNX: 0.0.0 read 1/1/28 -- __init__.py:parse_telegram:203
2014-03-22 10:53:40,960 DEBUG Main KNX: 0.0.0 read 2/1/11 -- __init__.py:parse_telegram:203
2014-03-22 10:53:40,979 DEBUG Main KNX: 0.0.0 read 2/1/12 -- __init__.py:parse_telegram:203
2014-03-22 10:53:40,995 DEBUG Main KNX: 0.0.0 read 1/1/34 -- __init__.py:parse_telegram:203
2014-03-22 10:53:41,028 DEBUG Main KNX: 0.0.0 read 1/1/37 -- __init__.py:parse_telegram:203
2014-03-22 10:53:41,056 DEBUG Main KNX: 0.0.0 read 1/1/44 -- __init__.py:parse_telegram:203
2014-03-22 10:53:41,081 DEBUG Main KNX: 0.0.0 read 1/1/47 -- __init__.py:parse_telegram:203
2014-03-22 10:53:41,108 DEBUG Main KNX: 0.0.0 read 2/1/21 -- __init__.py:parse_telegram:203
2014-03-22 10:53:41,138 DEBUG Main KNX: 0.0.0 read 2/1/22 -- __init__.py:parse_telegram:203
2014-03-22 10:53:41,172 DEBUG Main KNX: 0.0.0 read 1/1/104 -- __init__.py:parse_telegram:203
2014-03-22 10:53:41,192 DEBUG Main KNX: 0.0.0 read 1/1/106 -- __init__.py:parse_telegram:203
2014-03-22 10:53:41,206 DEBUG Main KNX: 0.0.0 read 4/1/104 -- __init__.py:parse_telegram:203
2014-03-22 10:53:41,226 DEBUG Main KNX: 0.0.0 read 2/1/31 -- __init__.py:parse_telegram:203
2014-03-22 10:53:41,250 DEBUG Main knx: 1.1.1 set 2/1/1 to False -- __init__.py:parse_telegram:190
2014-03-22 10:53:41,272 DEBUG Main KNX: 0.0.0 read 2/1/32 -- __init__.py:parse_telegram:203
2014-03-22 10:53:41,282 DEBUG Main KNX: 0.0.0 read 2/1/41 -- __init__.py:parse_telegram:203
2014-03-22 10:53:41,308 DEBUG Main KNX: 0.0.0 read 2/1/42 -- __init__.py:parse_telegram:203
2014-03-22 10:53:41,327 DEBUG Main KNX: 0.0.0 read 2/1/51 -- __init__.py:parse_telegram:203
2014-03-22 10:53:41,343 DEBUG Main KNX: 0.0.0 read 2/1/52 -- __init__.py:parse_telegram:203
2014-03-22 10:53:41,375 DEBUG Main knx: 1.1.1 set 2/1/4 to 0 -- __init__.py:parse_telegram:190
2014-03-22 10:53:41,382 DEBUG Main KNX: 0.0.0 read 1/2/2 -- __init__.py:parse_telegram:203
2014-03-22 10:53:41,401 DEBUG Main KNX: 0.0.0 read 1/2/3 -- __init__.py:parse_telegram:203
2014-03-22 10:53:41,424 DEBUG Main KNX: 0.0.0 read 1/2/4 -- __init__.py:parse_telegram:203
2014-03-22 10:53:41,438 DEBUG Main KNX: 0.0.0 read 1/2/5 -- __init__.py:parse_telegram:203
2014-03-22 10:53:41,458 DEBUG Main KNX: 0.0.0 read 1/2/22 -- __init__.py:parse_telegram:203
2014-03-22 10:53:41,475 DEBUG Main KNX: 0.0.0 read 2/2/1 -- __init__.py:parse_telegram:203
2014-03-22 10:53:41,494 DEBUG Main KNX: 0.0.0 read 2/2/2 -- __init__.py:parse_telegram:203
2014-03-22 10:53:41,514 DEBUG Main KNX: 0.0.0 read 1/2/38 -- __init__.py:parse_telegram:203
2014-03-22 10:53:41,530 DEBUG Main KNX: 0.0.0 read 2/2/11 -- __init__.py:parse_telegram:203
2014-03-22 10:53:41,546 DEBUG Main KNX: 0.0.0 read 2/2/12 -- __init__.py:parse_telegram:203
2014-03-22 10:53:41,564 DEBUG Main KNX: 0.0.0 read 2/2/21 -- __init__.py:parse_telegram:203
2014-03-22 10:53:41,583 DEBUG Main KNX: 0.0.0 read 2/2/22 -- __init__.py:parse_telegram:203
2014-03-22 10:53:41,601 DEBUG Main KNX: 0.0.0 read 1/2/56 -- __init__.py:parse_telegram:203
2014-03-22 10:53:41,616 DEBUG Main KNX: 0.0.0 read 2/2/31 -- __init__.py:parse_telegram:203
2014-03-22 10:53:41,630 DEBUG Main KNX: 0.0.0 read 2/2/32 -- __init__.py:parse_telegram:203
2014-03-22 10:53:41,651 DEBUG Main KNX: 0.0.0 read 2/2/41 -- __init__.py:parse_telegram:203
2014-03-22 10:53:41,670 DEBUG Main KNX: 0.0.0 read 2/2/42 -- __init__.py:parse_telegram:203
2014-03-22 10:53:41,698 DEBUG Main KNX: 0.0.0 read 1/2/60 -- __init__.py:parse_telegram:203
2014-03-22 10:53:41,720 DEBUG Main KNX: 0.0.0 read 1/2/80 -- __init__.py:parse_telegram:203
2014-03-22 10:53:41,751 DEBUG Main KNX: 0.0.0 read 1/2/81 -- __init__.py:parse_telegram:203
2014-03-22 10:53:41,779 DEBUG Main KNX: 0.0.0 read 2/2/51 -- __init__.py:parse_telegram:203
2014-03-22 10:53:41,806 DEBUG Main KNX: 0.0.0 read 2/2/52 -- __init__.py:parse_telegram:203
2014-03-22 10:53:41,833 DEBUG Main KNX: 0.0.0 read 4/2/80 -- __init__.py:parse_telegram:203
2014-03-22 10:53:41,849 DEBUG Main KNX: 0.0.0 read 2/2/61 -- __init__.py:parse_telegram:203
2014-03-22 10:53:41,867 DEBUG Main KNX: 0.0.0 read 2/2/62 -- __init__.py:parse_telegram:203
2014-03-22 10:53:41,881 DEBUG Main KNX: 0.0.0 read 1/7/0 -- __init__.py:parse_telegram:203
2014-03-22 10:53:41,899 DEBUG Main KNX: 0.0.0 read 1/7/1 -- __init__.py:parse_telegram:203
2014-03-22 10:53:41,921 DEBUG Main KNX: 0.0.0 read 1/5/10 -- __init__.py:parse_telegram:203
2014-03-22 10:53:41,933 DEBUG Main KNX: 0.0.0 read 4/5/15 -- __init__.py:parse_telegram:203
2014-03-22 10:53:41,956 DEBUG Main knx: 1.1.19 set 1/1/106 to 0 -- __init__.py:parse_telegram:190
2014-03-22 10:53:41,974 DEBUG Main knx: 1.1.8 set 0/6/2 to 00 -- __init__.py:parse_telegram:181
2014-03-22 10:53:41,988 DEBUG Main knx: 1.1.1 set 2/1/31 to False -- __init__.py:parse_telegram:190
2014-03-22 10:53:42,012 DEBUG Main knx: 1.1.1 set 2/1/41 to False -- __init__.py:parse_telegram:190
2014-03-22 10:53:42,506 DEBUG Main knx: 1.1.7 set 0/6/2 to 00 -- __init__.py:parse_telegram:181
2014-03-22 10:53:42,630 DEBUG Main knx: 1.1.46 set 1/7/1 to False -- __init__.py:parse_telegram:190
2014-03-22 10:53:42,697 DEBUG Main knx: 1.1.31 set 1/7/2 to False -- __init__.py:parse_telegram:190
2014-03-22 10:53:42,854 DEBUG Main knx: 1.1.47 set 1/7/3 to 00 -- __init__.py:parse_telegram:181
2014-03-22 10:53:45,030 DEBUG env_loc Item env.location.sunrise = 2014-03-23 06:14:17.263136+01:00 via Logic None None -- item.py:__update:363
2014-03-22 10:53:45,033 INFO hello Hello World! -- hello.py:<module>:3
2014-03-22 10:53:45,037 DEBUG sh.gc Garbage collector: collected 0 objects. -- smarthome.py:_garbage_collection:498
2014-03-22 10:53:45,036 DEBUG env_init Item env.core.version = 1.0-32-gfd0043e via Logic None None -- item.py:__update:363
2014-03-22 10:53:45,068 DEBUG env_init Item env.core.start = 2014-03-22 10:53:45.064436+01:00 via Logic None None -- item.py:__update:363
2014-03-22 10:53:45,096 DEBUG env_loc Item env.location.sunset = 2014-03-22 18:34:38.601167+01:00 via Logic None None -- item.py:__update:363
2014-03-22 10:53:45,104 DEBUG env_init Item env.system.name = smarthome.local via Logic None None -- item.py:__update:363
2014-03-22 10:53:45,163 DEBUG env_init Item env.system.start = 2014-02-27 21:51:57.159702+01:00 via Logic None None -- item.py:__update:363
2014-03-22 10:53:45,193 DEBUG env_loc Item env.location.moonrise = 2014-03-23 01:09:28.581577+01:00 via Logic None None -- item.py:__update:363
2014-03-22 10:53:45,273 DEBUG env_loc Item env.location.moonset = 2014-03-23 10:06:21.066407+01:00 via Logic None None -- item.py:__update:363
2014-03-22 10:53:45,317 DEBUG env_loc Item env.location.moonphase = 6 via Logic None None -- item.py:__update:363
2014-03-22 10:53:45,385 DEBUG env_loc Item env.location.day = True via Logic None None -- item.py:__update:363
2014-03-22 10:53:45,414 DEBUG sh.gc Object references: 9221 -- smarthome.py:_maintenance:490
2014-03-22 10:53:45,590 DEBUG Scheduler env_loc next time: 2014-03-22 11:23:45+01:00 -- scheduler.py:_next_time:289
2014-03-22 10:53:45,612 DEBUG Scheduler sh.gc next time: 2014-03-23 02:04:00+01:00 -- scheduler.py:_next_time:289
2014-03-22 10:53:49,198 DEBUG env_stat Item env.core.memory = 15945728 via Logic None None -- item.py:__update:363
2014-03-22 10:53:49,207 DEBUG env_stat Item env.system.load = 0.2 via Logic None None -- item.py:__update:363
2014-03-22 10:53:49,217 DEBUG env_stat Item env.location.moonlight = 68 via Logic None None -- item.py:__update:363
2014-03-22 10:53:49,646 DEBUG Scheduler env_stat next time: 2014-03-22 10:58:49+01:00 -- scheduler.py:_next_time:289
2014-03-22 10:54:05,266 DEBUG Main knx: 0.0.0 set 15/5/21 to 21.0 -- __init__.py:parse_telegram:190
2014-03-22 10:54:05,272 DEBUG Main Item OG.Elias.Temperatur = 21.0 via KNX 0.0.0 15/5/21 -- item.py:__update:363
2014-03-22 10:54:08,276 DEBUG Main knx: 0.0.0 set 14/7/51 to 465da012 -- __init__.py:parse_telegram:181
2014-03-22 10:54:08,310 DEBUG Main knx: 0.0.0 set 14/7/50 to 2d08 -- __init__.py:parse_telegram:181
2014-03-22 10:54:55,511 DEBUG Main knx: 1.1.54 set 6/2/0 to 03ab -- __init__.py:parse_telegram:181
2014-03-22 10:55:06,625 DEBUG Main knx: 0.0.0 set 14/7/51 to 465da01a -- __init__.py:parse_telegram:181
2014-03-22 10:55:06,647 DEBUG Main knx: 0.0.0 set 14/7/50 to 2e78 -- __init__.py:parse_telegram:181
2014-03-22 10:55:24,254 DEBUG Main knx: 0.0.0 set 15/5/20 to 21.24 -- __init__.py:parse_telegram:190
2014-03-22 10:55:24,260 DEBUG Main Item EG.Wohnen.Temperatur = 21.24 via KNX 0.0.0 15/5/20 -- item.py:__update:363
2014-03-22 10:55:24,268 DEBUG Main Item EG.Erker.Temperatur = 21.24 via KNX 0.0.0 15/5/20 -- item.py:__update:363
2014-03-22 10:55:25,901 DEBUG Main knx: 0.0.0 set 15/5/23 to 0401 -- __init__.py:parse_telegram:181
2014-03-22 10:55:27,248 DEBUG Main knx: 0.0.0 set 15/5/19 to 20.25 -- __init__.py:parse_telegram:190
2014-03-22 10:55:27,254 DEBUG Main Item EG.GaesteWC.Temperatur = 20.25 via KNX 0.0.0 15/5/19 -- item.py:__update:363
2014-03-22 10:55:29,238 DEBUG Main knx: 0.0.0 set 15/5/18 to 21.24 -- __init__.py:parse_telegram:190
2014-03-22 10:55:29,244 DEBUG Main Item EG.Arbeiten.Temperatur = 21.24 via KNX 0.0.0 15/5/18 -- item.py:__update:363
2014-03-22 10:56:08,312 DEBUG Main knx: 0.0.0 set 14/7/51 to 465da022 -- __init__.py:parse_telegram:181
2014-03-22 10:56:08,330 DEBUG Main knx: 0.0.0 set 14/7/50 to 2c9a -- __init__.py:parse_telegram:181
2014-03-22 10:56:35,461 DEBUG Main knx: 0.0.0 set 15/5/24 to 0507 -- __init__.py:parse_telegram:181
2014-03-22 10:56:37,814 DEBUG Main knx: 0.0.0 set 15/5/22 to 21.24 -- __init__.py:parse_telegram:190
2014-03-22 10:56:37,820 DEBUG Main Item OG.Lina.Temperatur = 21.24 via KNX 0.0.0 15/5/22 -- item.py:__update:363
2014-03-22 10:57:07,791 DEBUG Main knx: 0.0.0 set 14/7/51 to 465da029 -- __init__.py:parse_telegram:181
2014-03-22 10:57:07,811 DEBUG Main knx: 0.0.0 set 14/7/50 to 2d0a -- __init__.py:parse_telegram:181
2014-03-22 10:57:14,935 DEBUG Main knx: 1.1.54 set 6/2/6 to 1471 -- __init__.py:parse_telegram:181
2014-03-22 10:57:33,129 DEBUG Main knx: 1.1.54 set 6/2/0 to 03b6 -- __init__.py:parse_telegram:181
2014-03-22 10:57:34,326 DEBUG Main knx: 1.1.54 set 6/2/6 to 146f -- __init__.py:parse_telegram:181
2014-03-22 10:58:07,689 DEBUG Main knx: 0.0.0 set 14/7/51 to 465da030 -- __init__.py:parse_telegram:181
2014-03-22 10:58:07,711 DEBUG Main knx: 0.0.0 set 14/7/50 to 2ddc -- __init__.py:parse_telegram:181
2014-03-22 10:58:14,320 DEBUG Main knx: 1.1.54 set 6/2/6 to 146c -- __init__.py:parse_telegram:181
2014-03-22 10:58:34,776 DEBUG Main knx: 1.1.54 set 6/2/6 to 146a -- __init__.py:parse_telegram:181
2014-03-22 10:58:34,983 DEBUG Main knx: 1.1.54 set 6/2/7 to 1456 -- __init__.py:parse_telegram:181
2014-03-22 10:58:49,519 DEBUG env_stat Item env.core.memory = 15998976 via Logic None None -- item.py:__update:363
2014-03-22 10:58:49,528 DEBUG env_stat Item env.system.load = 0.12 via Logic None None -- item.py:__update:363
2014-03-22 10:58:49,966 DEBUG Scheduler env_stat next time: 2014-03-22 11:03:49+01:00 -- scheduler.py:_next_time:289
2014-03-22 10:58:55,134 DEBUG Main knx: 1.1.54 set 6/2/6 to 1462 -- __init__.py:parse_telegram:181
2014-03-22 10:59:07,880 DEBUG Main knx: 0.0.0 set 15/5/21 to 20.74 -- __init__.py:parse_telegram:190
2014-03-22 10:59:07,886 DEBUG Main Item OG.Elias.Temperatur = 20.74 via KNX 0.0.0 15/5/21 -- item.py:__update:363
2014-03-22 10:59:08,324 DEBUG Main knx: 0.0.0 set 14/7/51 to 465da038 -- __init__.py:parse_telegram:181
2014-03-22 10:59:08,363 DEBUG Main knx: 0.0.0 set 14/7/50 to 2d3d -- __init__.py:parse_telegram:181
2014-03-22 10:59:14,524 DEBUG Main knx: 1.1.54 set 6/2/6 to 145d -- __init__.py:parse_telegram:181
2014-03-22 10:59:33,914 DEBUG Main knx: 1.1.54 set 6/2/6 to 145b -- __init__.py:parse_telegram:181
2014-03-22 10:59:52,679 DEBUG Main knx: 1.1.54 set 6/2/1 to 0c92 -- __init__.py:parse_telegram:181
2014-03-22 10:59:53,718 DEBUG Main knx: 1.1.54 set 6/2/6 to 1453 -- __init__.py:parse_telegram:181
2014-03-22 10:59:53,922 DEBUG Main knx: 1.1.54 set 6/2/7 to 1453 -- __init__.py:parse_telegram:181
2014-03-22 11:00:01,926 DEBUG Main WebSocket: incoming connection from 192.168.2.31:43446 to 0.0.0.0:2424 -- connection.py:accept:188
2014-03-22 11:00:02,705 DEBUG Main 192.168.2.31:43446 sent '{"cmd":"proto","ver":3}' -- __init__.py:json_parse:270
2014-03-22 11:00:02,752 DEBUG Main 192.168.2.31:43446 sent '{"cmd":"monitor","items":["Aussen.Terrasse.Beleuchtung.Schalten","Aussen.Garten.Beleuchtung.Schalten","Aussen.Terrasse.Steckdose.Schalten","Aussen.Teich.Filter","eg.essen.temperatur.luft","eg.essen.humidity","eg.kueche.rm.alarm","eg.wohnen.rm.alarm","eg.kueche.rm.stoerung","eg.wohnen.rm.stoerung","eg.koch-wohn.praesenz","eg.kueche.rollladen.position.status","eg.kueche.rollladen.fahren","eg.kueche.fenster","eg.essen.fenster","eg.wohnen.fenster.sued","eg.wohnen.fenster.west","EG.Arbeiten.Temperatur","eg.buero.rollladen.west.position","eg.buero.rollladen.west.fahren","eg.buero.fenster.west","eg.buero.fenster.nord","EG.GaesteWC.Temperatur","eg.gaeste-wc.praesenz","eg.gaeste-wc.rollladen.position","eg.gaeste-wc.rollladen.fahren","eg.gaeste-wc.fenster","eg.hwr.temperatur.luft","eg.hwr.rm.alarm","eg.hwr.rm.stoerung","eg.hwr.praesenz","eg.hwr.rollladen.position","eg.hwr.rollladen.fahren","eg.hwr.fenster","eg.diele.temperatur.luft","eg.diele.rm.alarm","eg.diele.rm.stoerung","eg.diele.praesenz","eg.diele.rollladen.position.status","eg.diele.rollladen.fahren","eg.diele.fenster","dg.flur.temperatur.luft","dg.flur.rm.alarm","dg.flur.rm.stoerung","dg.flur.praesenz","dg.schlafen.temperatur.luft","dg.schlafen.rm.alarm","dg.schlafen.rm.stoerung","dg.schlafen.praesenz","dg.schlafen.rollladen.position","dg.schlafen.rollladen.fahren","dg.schlafen.fenster","OG.Elias.Temperatur","dg.kind1.rm.alarm","dg.kind1.rm.stoerung","dg.kind1.praesenz","dg.kind1.rollladen.position","dg.kind1.rollladen.fahren","dg.kind1.fenster","OG.Lina.Temperatur","dg.kind2.rm.alarm","dg.kind2.rm.stoerung","dg.kind2.praesenz","dg.kind2.rollladen.position","dg.kind2.rollladen.fahren","dg.kind2.fenster","dg.gast.temperatur.luft","dg.gast.rm.alarm","dg.gast.rm.stoerung","dg.gast.praesenz","dg.gast.rollladen.links.position","dg.gast.rollladen.links.fahren","dg.gast1.fenster","dg.gast2.fenster","dg.gast3.fenster","dg.bad-eltern.temperatur.luft","dg.bad-eltern.praesenz","dg.bad-eltern.rollladen.position","dg.bad-eltern.rollladen.fahren","dg.bad-eltern.fenster","aussen.temperatur"]}' -- __init__.py:json_parse:270
2014-03-22 11:00:02,761 WARNING Main Client 192.168.2.31:43446 requested invalid item: dg.schlafen.rm.alarm -- __init__.py:json_parse:294
2014-03-22 11:00:02,767 WARNING Main Client 192.168.2.31:43446 requested invalid item: eg.buero.fenster.nord -- __init__.py:json_parse:294
2014-03-22 11:00:02,773 WARNING Main Client 192.168.2.31:43446 requested invalid item: dg.kind1.fenster -- __init__.py:json_parse:294
2014-03-22 11:00:02,779 WARNING Main Client 192.168.2.31:43446 requested invalid item: dg.schlafen.temperatur.luft -- __init__.py:json_parse:294
2014-03-22 11:00:02,785 WARNING Main Client 192.168.2.31:43446 requested invalid item: dg.gast.temperatur.luft -- __init__.py:json_parse:294
2014-03-22 11:00:02,790 WARNING Main Client 192.168.2.31:43446 requested invalid item: Aussen.Terrasse.Beleuchtung.Schalten -- __init__.py:json_parse:294
2014-03-22 11:00:02,796 WARNING Main Client 192.168.2.31:43446 requested invalid item: eg.kueche.rollladen.position.status -- __init__.py:json_parse:294
2014-03-22 11:00:02,804 WARNING Main Client 192.168.2.31:43446 requested invalid item: dg.bad-eltern.fenster -- __init__.py:json_parse:294
2014-03-22 11:00:02,810 WARNING Main Client 192.168.2.31:43446 requested invalid item: eg.koch-wohn.praesenz -- __init__.py:json_parse:294
2014-03-22 11:00:02,816 WARNING Main Client 192.168.2.31:43446 requested invalid item: eg.diele.fenster -- __init__.py:json_parse:294
2014-03-22 11:00:02,822 WARNING Main Client 192.168.2.31:43446 requested invalid item: dg.kind1.rollladen.fahren -- __init__.py:json_parse:294
2014-03-22 11:00:02,828 WARNING Main Client 192.168.2.31:43446 requested invalid item: Aussen.Terrasse.Steckdose.Schalten -- __init__.py:json_parse:294
2014-03-22 11:00:02,834 WARNING Main Client 192.168.2.31:43446 requested invalid item: dg.schlafen.praesenz -- __init__.py:json_parse:294
2014-03-22 11:00:02,840 WARNING Main Client 192.168.2.31:43446 requested invalid item: dg.flur.temperatur.luft -- __init__.py:json_parse:294
2014-03-22 11:00:02,846 WARNING Main Client 192.168.2.31:43446 requested invalid item: eg.essen.fenster -- __init__.py:json_parse:294
2014-03-22 11:00:02,852 WARNING Main Client 192.168.2.31:43446 requested invalid item: Aussen.Teich.Filter -- __init__.py:json_parse:294
2014-03-22 11:00:02,858 WARNING Main Client 192.168.2.31:43446 requested invalid item: eg.buero.rollladen.west.fahren -- __init__.py:json_parse:294
2014-03-22 11:00:02,864 WARNING Main Client 192.168.2.31:43446 requested invalid item: dg.kind2.rm.alarm -- __init__.py:json_parse:294
2014-03-22 11:00:02,870 WARNING Main Client 192.168.2.31:43446 requested invalid item: eg.wohnen.fenster.west -- __init__.py:json_parse:294
2014-03-22 11:00:02,876 WARNING Main Client 192.168.2.31:43446 requested invalid item: eg.hwr.rollladen.position -- __init__.py:json_parse:294
2014-03-22 11:00:02,881 WARNING Main Client 192.168.2.31:43446 requested invalid item: eg.diele.rollladen.position.status -- __init__.py:json_parse:294
2014-03-22 11:00:02,887 WARNING Main Client 192.168.2.31:43446 requested invalid item: eg.hwr.fenster -- __init__.py:json_parse:294
2014-03-22 11:00:02,893 WARNING Main Client 192.168.2.31:43446 requested invalid item: eg.kueche.fenster -- __init__.py:json_parse:294
2014-03-22 11:00:02,899 WARNING Main Client 192.168.2.31:43446 requested invalid item: dg.gast1.fenster -- __init__.py:json_parse:294
2014-03-22 11:00:02,905 WARNING Main Client 192.168.2.31:43446 requested invalid item: eg.wohnen.rm.alarm -- __init__.py:json_parse:294
2014-03-22 11:00:02,911 WARNING Main Client 192.168.2.31:43446 requested invalid item: dg.bad-eltern.praesenz -- __init__.py:json_parse:294
2014-03-22 11:00:02,917 WARNING Main Client 192.168.2.31:43446 requested invalid item: dg.kind1.praesenz -- __init__.py:json_parse:294
2014-03-22 11:00:02,923 WARNING Main Client 192.168.2.31:43446 requested invalid item: dg.schlafen.rollladen.fahren -- __init__.py:json_parse:294
2014-03-22 11:00:02,929 WARNING Main Client 192.168.2.31:43446 requested invalid item: aussen.temperatur -- __init__.py:json_parse:294
2014-03-22 11:00:02,935 WARNING Main Client 192.168.2.31:43446 requested invalid item: dg.schlafen.rm.stoerung -- __init__.py:json_parse:294
2014-03-22 11:00:02,941 WARNING Main Client 192.168.2.31:43446 requested invalid item: dg.gast.rm.stoerung -- __init__.py:json_parse:294
2014-03-22 11:00:02,948 WARNING Main Client 192.168.2.31:43446 requested invalid item: eg.diele.temperatur.luft -- __init__.py:json_parse:294
2014-03-22 11:00:02,953 WARNING Main Client 192.168.2.31:43446 requested invalid item: eg.kueche.rollladen.fahren -- __init__.py:json_parse:294
2014-03-22 11:00:02,959 WARNING Main Client 192.168.2.31:43446 requested invalid item: dg.bad-eltern.rollladen.position -- __init__.py:json_parse:294
2014-03-22 11:00:02,965 WARNING Main Client 192.168.2.31:43446 requested invalid item: dg.gast.rollladen.links.fahren -- __init__.py:json_parse:294
2014-03-22 11:00:02,971 WARNING Main Client 192.168.2.31:43446 requested invalid item: eg.gaeste-wc.praesenz -- __init__.py:json_parse:294
2014-03-22 11:00:02,977 WARNING Main Client 192.168.2.31:43446 requested invalid item: dg.gast2.fenster -- __init__.py:json_parse:294
2014-03-22 11:00:02,983 WARNING Main Client 192.168.2.31:43446 requested invalid item: eg.wohnen.rm.stoerung -- __init__.py:json_parse:294
2014-03-22 11:00:02,989 WARNING Main Client 192.168.2.31:43446 requested invalid item: eg.gaeste-wc.rollladen.fahren -- __init__.py:json_parse:294
2014-03-22 11:00:02,995 WARNING Main Client 192.168.2.31:43446 requested invalid item: dg.kind1.rm.stoerung -- __init__.py:json_parse:294
2014-03-22 11:00:03,001 WARNING Main Client 192.168.2.31:43446 requested invalid item: eg.hwr.rollladen.fahren -- __init__.py:json_parse:294
2014-03-22 11:00:03,008 WARNING Main Client 192.168.2.31:43446 requested invalid item: dg.flur.rm.alarm -- __init__.py:json_parse:294
2014-03-22 11:00:03,013 WARNING Main Client 192.168.2.31:43446 requested invalid item: eg.buero.fenster.west -- __init__.py:json_parse:294
2014-03-22 11:00:03,019 WARNING Main Client 192.168.2.31:43446 requested invalid item: dg.kind2.rollladen.position -- __init__.py:json_parse:294
2014-03-22 11:00:03,025 WARNING Main Client 192.168.2.31:43446 requested invalid item: dg.kind2.rm.stoerung -- __init__.py:json_parse:294
2014-03-22 11:00:03,031 WARNING Main Client 192.168.2.31:43446 requested invalid item: eg.wohnen.fenster.sued -- __init__.py:json_parse:294
2014-03-22 11:00:03,037 WARNING Main Client 192.168.2.31:43446 requested invalid item: dg.kind2.praesenz -- __init__.py:json_parse:294
2014-03-22 11:00:03,043 WARNING Main Client 192.168.2.31:43446 requested invalid item: dg.gast.rm.alarm -- __init__.py:json_parse:294
2014-03-22 11:00:03,049 WARNING Main Client 192.168.2.31:43446 requested invalid item: dg.kind2.rollladen.fahren -- __init__.py:json_parse:294
2014-03-22 11:00:03,055 WARNING Main Client 192.168.2.31:43446 requested invalid item: eg.kueche.rm.alarm -- __init__.py:json_parse:294
2014-03-22 11:00:03,061 WARNING Main Client 192.168.2.31:43446 requested invalid item: eg.essen.temperatur.luft -- __init__.py:json_parse:294
2014-03-22 11:00:03,067 WARNING Main Client 192.168.2.31:43446 requested invalid item: dg.flur.praesenz -- __init__.py:json_parse:294
2014-03-22 11:00:03,073 WARNING Main Client 192.168.2.31:43446 requested invalid item: eg.diele.rm.stoerung -- __init__.py:json_parse:294
2014-03-22 11:00:03,079 WARNING Main Client 192.168.2.31:43446 requested invalid item: dg.bad-eltern.rollladen.fahren -- __init__.py:json_parse:294
2014-03-22 11:00:03,086 WARNING Main Client 192.168.2.31:43446 requested invalid item: eg.essen.humidity -- __init__.py:json_parse:294
2014-03-22 11:00:03,093 WARNING Main Client 192.168.2.31:43446 requested invalid item: eg.gaeste-wc.rollladen.position -- __init__.py:json_parse:294
2014-03-22 11:00:03,098 WARNING Main Client 192.168.2.31:43446 requested invalid item: dg.schlafen.rollladen.position -- __init__.py:json_parse:294
2014-03-22 11:00:03,104 WARNING Main Client 192.168.2.31:43446 requested invalid item: eg.hwr.rm.stoerung -- __init__.py:json_parse:294
2014-03-22 11:00:03,110 WARNING Main Client 192.168.2.31:43446 requested invalid item: dg.bad-eltern.temperatur.luft -- __init__.py:json_parse:294
2014-03-22 11:00:03,116 WARNING Main Client 192.168.2.31:43446 requested invalid item: dg.kind1.rm.alarm -- __init__.py:json_parse:294
2014-03-22 11:00:03,122 WARNING Main Client 192.168.2.31:43446 requested invalid item: dg.flur.rm.stoerung -- __init__.py:json_parse:294
2014-03-22 11:00:03,128 WARNING Main Client 192.168.2.31:43446 requested invalid item: eg.buero.rollladen.west.position -- __init__.py:json_parse:294
2014-03-22 11:00:03,134 WARNING Main Client 192.168.2.31:43446 requested invalid item: eg.gaeste-wc.fenster -- __init__.py:json_parse:294
2014-03-22 11:00:03,140 WARNING Main Client 192.168.2.31:43446 requested invalid item: eg.hwr.praesenz -- __init__.py:json_parse:294
2014-03-22 11:00:03,146 WARNING Main Client 192.168.2.31:43446 requested invalid item: eg.kueche.rm.stoerung -- __init__.py:json_parse:294
2014-03-22 11:00:03,152 WARNING Main Client 192.168.2.31:43446 requested invalid item: dg.gast.praesenz -- __init__.py:json_parse:294
2014-03-22 11:00:03,158 WARNING Main Client 192.168.2.31:43446 requested invalid item: eg.diele.rollladen.fahren -- __init__.py:json_parse:294
2014-03-22 11:00:03,164 WARNING Main Client 192.168.2.31:43446 requested invalid item: eg.diele.rm.alarm -- __init__.py:json_parse:294
2014-03-22 11:00:03,169 WARNING Main Client 192.168.2.31:43446 requested invalid item: eg.diele.praesenz -- __init__.py:json_parse:294
2014-03-22 11:00:03,176 WARNING Main Client 192.168.2.31:43446 requested invalid item: eg.hwr.rm.alarm -- __init__.py:json_parse:294
2014-03-22 11:00:03,182 WARNING Main Client 192.168.2.31:43446 requested invalid item: dg.kind2.fenster -- __init__.py:json_parse:294
2014-03-22 11:00:03,188 WARNING Main Client 192.168.2.31:43446 requested invalid item: dg.gast.rollladen.links.position -- __init__.py:json_parse:294
2014-03-22 11:00:03,194 WARNING Main Client 192.168.2.31:43446 requested invalid item: eg.hwr.temperatur.luft -- __init__.py:json_parse:294
2014-03-22 11:00:03,200 WARNING Main Client 192.168.2.31:43446 requested invalid item: dg.gast3.fenster -- __init__.py:json_parse:294
2014-03-22 11:00:03,206 WARNING Main Client 192.168.2.31:43446 requested invalid item: dg.schlafen.fenster -- __init__.py:json_parse:294
2014-03-22 11:00:03,213 WARNING Main Client 192.168.2.31:43446 requested invalid item: dg.kind1.rollladen.position -- __init__.py:json_parse:294
2014-03-22 11:00:06,225 DEBUG Main 192.168.2.31:43446 sent '{"cmd":"item","id":"Aussen.Garten.Beleuchtung.Schalten","val":"1"}' -- __init__.py:json_parse:270
2014-03-22 11:00:06,232 DEBUG Main Item Aussen.Garten.Beleuchtung.Schalten = True via Visu 192.168.2.31:43446 None -- item.py:__update:363
2014-03-22 11:00:06,273 DEBUG Main knx: 0.0.0 set 4/5/15 to True -- __init__.py:parse_telegram:190
2014-03-22 11:00:07,395 DEBUG Main 192.168.2.31:43446 sent '{"cmd":"item","id":"Aussen.Garten.Beleuchtung.Schalten","val":"0"}' -- __init__.py:json_parse:270
2014-03-22 11:00:07,401 DEBUG Main Item Aussen.Garten.Beleuchtung.Schalten = False via Visu 192.168.2.31:43446 None -- item.py:__update:363
2014-03-22 11:00:07,439 DEBUG Main knx: 0.0.0 set 4/5/15 to False -- __init__.py:parse_telegram:190
2014-03-22 11:00:07,667 DEBUG Main knx: 0.0.0 set 14/7/51 to 465da040 -- __init__.py:parse_telegram:181
2014-03-22 11:00:07,687 DEBUG Main knx: 0.0.0 set 14/7/50 to 2e26 -- __init__.py:parse_telegram:181
2014-03-22 11:00:08,825 DEBUG Main 192.168.2.31:43446 sent '{"cmd":"item","id":"Aussen.Terrasse.Beleuchtung.Schalten","val":"1"}' -- __init__.py:json_parse:270
2014-03-22 11:00:08,830 WARNING Main Client 192.168.2.31:43446 want to update invalid item: Aussen.Terrasse.Beleuchtung.Schalten -- __init__.py:json_parse:286
2014-03-22 11:00:09,480 DEBUG Main 192.168.2.31:43446 sent '{"cmd":"item","id":"Aussen.Garten.Beleuchtung.Schalten","val":"1"}' -- __init__.py:json_parse:270
2014-03-22 11:00:09,486 DEBUG Main Item Aussen.Garten.Beleuchtung.Schalten = True via Visu 192.168.2.31:43446 None -- item.py:__update:363
2014-03-22 11:00:09,524 DEBUG Main knx: 0.0.0 set 4/5/15 to True -- __init__.py:parse_telegram:190
2014-03-22 11:00:10,195 DEBUG Main 192.168.2.31:43446 sent '{"cmd":"item","id":"Aussen.Terrasse.Steckdose.Schalten","val":"1"}' -- __init__.py:json_parse:270
2014-03-22 11:00:10,200 WARNING Main Client 192.168.2.31:43446 want to update invalid item: Aussen.Terrasse.Steckdose.Schalten -- __init__.py:json_parse:286
2014-03-22 11:00:11,015 DEBUG Main 192.168.2.31:43446 sent '{"cmd":"item","id":"Aussen.Teich.Filter","val":"1"}' -- __init__.py:json_parse:270
2014-03-22 11:00:11,020 WARNING Main Client 192.168.2.31:43446 want to update invalid item: Aussen.Teich.Filter -- __init__.py:json_parse:286
2014-03-22 11:00:12,376 DEBUG Main knx: 1.1.54 set 6/2/1 to 0c97 -- __init__.py:parse_telegram:181
2014-03-22 11:00:12,555 DEBUG Main 192.168.2.31:43446 sent '{"cmd":"item","id":"Aussen.Teich.Filter","val":"0"}' -- __init__.py:json_parse:270
2014-03-22 11:00:12,564 WARNING Main Client 192.168.2.31:43446 want to update invalid item: Aussen.Teich.Filter -- __init__.py:json_parse:286
2014-03-22 11:00:13,254 DEBUG Main 192.168.2.31:43446 sent '{"cmd":"item","id":"Aussen.Terrasse.Steckdose.Schalten","val":"0"}' -- __init__.py:json_parse:270
2014-03-22 11:00:13,258 WARNING Main Client 192.168.2.31:43446 want to update invalid item: Aussen.Terrasse.Steckdose.Schalten -- __init__.py:json_parse:286
2014-03-22 11:00:13,419 DEBUG Main knx: 1.1.54 set 6/2/6 to 144e -- __init__.py:parse_telegram:181
2014-03-22 11:00:13,960 DEBUG Main 192.168.2.31:43446 sent '{"cmd":"item","id":"Aussen.Garten.Beleuchtung.Schalten","val":"0"}' -- __init__.py:json_parse:270
2014-03-22 11:00:13,966 DEBUG Main Item Aussen.Garten.Beleuchtung.Schalten = False via Visu 192.168.2.31:43446 None -- item.py:__update:363
2014-03-22 11:00:14,007 DEBUG Main knx: 0.0.0 set 4/5/15 to False -- __init__.py:parse_telegram:190
2014-03-22 11:00:14,695 DEBUG Main 192.168.2.31:43446 sent '{"cmd":"item","id":"Aussen.Terrasse.Beleuchtung.Schalten","val":"0"}' -- __init__.py:json_parse:270
2014-03-22 11:00:14,700 WARNING Main Client 192.168.2.31:43446 want to update invalid item: Aussen.Terrasse.Beleuchtung.Schalten -- __init__.py:json_parse:286
2014-03-22 11:00:15,954 DEBUG Main 192.168.2.31:43446 sent '{"cmd":"item","id":"Aussen.Terrasse.Beleuchtung.Schalten","val":"1"}' -- __init__.py:json_parse:270
2014-03-22 11:00:15,959 WARNING Main Client 192.168.2.31:43446 want to update invalid item: Aussen.Terrasse.Beleuchtung.Schalten -- __init__.py:json_parse:286
2014-03-22 11:00:17,244 DEBUG Main 192.168.2.31:43446 sent '{"cmd":"item","id":"Aussen.Terrasse.Beleuchtung.Schalten","val":"0"}' -- __init__.py:json_parse:270
2014-03-22 11:00:17,249 WARNING Main Client 192.168.2.31:43446 want to update invalid item: Aussen.Terrasse.Beleuchtung.Schalten -- __init__.py:json_parse:286
2014-03-22 11:00:18,875 DEBUG Main 192.168.2.31:43446 sent '{"cmd":"item","id":"Aussen.Garten.Beleuchtung.Schalten","val":"1"}' -- __init__.py:json_parse:270
2014-03-22 11:00:18,882 DEBUG Main Item Aussen.Garten.Beleuchtung.Schalten = True via Visu 192.168.2.31:43446 None -- item.py:__update:363
2014-03-22 11:00:18,927 DEBUG Main knx: 0.0.0 set 4/5/15 to True -- __init__.py:parse_telegram:190
2014-03-22 11:00:19,555 DEBUG Main 192.168.2.31:43446 sent '{"cmd":"item","id":"Aussen.Garten.Beleuchtung.Schalten","val":"0"}' -- __init__.py:json_parse:270
2014-03-22 11:00:19,561 DEBUG Main Item Aussen.Garten.Beleuchtung.Schalten = False via Visu 192.168.2.31:43446 None -- item.py:__update:363
2014-03-22 11:00:19,600 DEBUG Main knx: 0.0.0 set 4/5/15 to False -- __init__.py:parse_telegram:190
2014-03-22 11:00:25,447 DEBUG Main knx: 0.0.0 set 15/5/20 to 21.24 -- __init__.py:parse_telegram:190
2014-03-22 11:00:26,528 DEBUG Main knx: 0.0.0 set 15/5/23 to 0401 -- __init__.py:parse_telegram:181
2014-03-22 11:00:29,293 DEBUG Main knx: 0.0.0 set 15/5/18 to 21.24 -- __init__.py:parse_telegram:190
2014-03-22 11:00:32,421 DEBUG Main knx: 1.1.54 set 6/2/1 to 0c92 -- __init__.py:parse_telegram:181
2014-03-22 11:00:33,468 DEBUG Main knx: 1.1.54 set 6/2/6 to 1449 -- __init__.py:parse_telegram:181
2014-03-22 11:00:52,683 DEBUG Main knx: 1.1.54 set 6/2/0 to 03c0 -- __init__.py:parse_telegram:181
2014-03-22 11:00:52,889 DEBUG Main knx: 1.1.54 set 6/2/1 to 0c97 -- __init__.py:parse_telegram:181
2014-03-22 11:00:53,929 DEBUG Main knx: 1.1.54 set 6/2/6 to 1442 -- __init__.py:parse_telegram:181
2014-03-22 11:00:54,177 DEBUG Main knx: 1.1.54 set 6/2/7 to 1451 -- __init__.py:parse_telegram:181
2014-03-22 11:00:58,007 INFO Main Number of Threads: 7 -- smarthome.py:stop:348
2014-03-22 11:00:58,014 INFO Main Stop Plugins -- plugin.py:stop:70
2014-03-22 11:00:58,019 DEBUG Main WebSocketHandler: closing socket 192.168.2.31:43446 -- connection.py:close:303
2014-03-22 11:00:59,358 DEBUG Main KNX: closing socket 192.168.2.26:6720 -- connection.py:close:303
2014-03-22 11:00:59,363 INFO Main SmartHome.py stopped -- smarthome.py:stop:372
Das Wesentliche:
Bzw in den ersten Zeilen:
WICHTIG:
Ich habe die Visu "Otterstätter" übernommen. Es sind noch nicht alle Pages angepasst. Fokus daher bitte nur auf die
ITEMS "Aussen.Terrasse." und "Aussen.Teich."
Mit CLI komme ich nicht wirklich weiter. Hoffe das ist nicht nötig.
ich habe nun mehrere Item, die zwar über KNX-Gruppenadresse geschaltet werden, aber über die Visu/Smarthome nicht.
Könnte sein, dass ich Tomaten auf den Augen habe, aber mir fällt nichts auf.
