Zitat von jonah64
offline
sh.autoblind_plugin_functions.manual_item_update_eval('<item.id>', caller, source)
not sh.<item.id>()
Ist es möglich, bei einzelnen Bedingungen auch eine ODER Abfrage zu machen? Mit eval wird das vermutlich nicht gehen oder doch? [[[[[['enter']]]]]]
type = foo
as_value_nachtlock = False
[COLOR=#FF0000]as_value_modus = 1 | 4 | 6 | 7[/COLOR]
as_value_a_bett = True
as_value_b_bett = True
as_min_time = item:licht.modus.automatik.settings.night.min_time_off
as_max_time = item:licht.modus.automatik.settings.night.max_time_off
as_negate_time = True
as_agemin_a_bett = eval:autoblind_eval.get_relative_itemvalue('..settings.night.delay_on') * 60
as_agemin_b_bett = eval:autoblind_eval.get_relative_itemvalue('..settings.night.delay_on') * 60
[['kg']]
type = foo
[[['technik_server']]]
type=foo
[[[['automatik']]]]
type = foo
[[[[['autostate_id']]]]]
type = str
visu_acl = ro
cache = on
[[[[['autostate_name']]]]]
type = str
visu_acl = ro
cache = on
[[[[['autostate_suspend_end']]]]]
type = str
visu_acl = ro
cache = on
[[[[['lock']]]]]
type = bool
knx_dpt = 1
knx_listen = 4/5/2
visu_acl = rw
cache = on
[[[[['suspend']]]]]
type = bool
knx_dpt = 1
visu_acl = rw
[[[[['manuell']]]]]
type = bool
name = Manuelle Bedienung
eval_trigger = steckdosen.kg.technik_server.SA
as_manual_invert = True
as_manual_exclude = Init:* | Database:* | KNX:1.1.1
[[[[['settings']]]]]
type = foo
[[[[[['suspendduration']]]]]]
type = num
visu_acl = rw
cache = True
enforce_updates = no
# value = 6
[[[[['rules']]]]]
type = bool
as_plugin = active
as_laststate_item_id = ..autostate_id
as_laststate_item_name = ..autostate_name
as_item_suspend_end = ..autostate_suspend_end
as_suspend_time = eval:autoblind_eval.get_relative_itemvalue('..settings.suspendduration') * 60
eval_trigger = steckdosen.autoblind.steckdosentrigger
2016-08-07 00:51:09.350791 Check if state 'licht.og.terrasse.screens.automatik.rules.arbeiten' ('Arbeiten') can be entered:
2016-08-07 00:51:09.353048 Check condition set 'enter':
2016-08-07 00:51:09.355986 Condition 'lichtmodus': value=1 negate=False current=1.0
2016-08-07 00:51:09.358409 not OK -> not matching
[[[[['enter']]]]]
type = foo
as_value_urlaub = 1
[[[[['enter_float']]]]]
type = foo
as_value_urlaub = 1.0
2016-08-07 01:10:57.651539 Check if state 'steckdosen.kg.technik_server.automatik.rules.urlaub' ('Urlaub') can be entered:
2016-08-07 01:10:57.651999 Check condition set 'enter':
2016-08-07 01:10:57.652594 Condition 'urlaub': value=True negate=False current=False
2016-08-07 01:10:57.653089 not OK -> not matching
2016-08-07 01:10:57.653562 Check condition set 'enter_float':
2016-08-07 01:10:57.654185 Condition 'urlaub': min=None max=None negate=False current=False
2016-08-07 01:10:57.655040 no limit given -> matching
2016-08-07 01:10:57.655538 Age of 'urlaub': No limits given
2016-08-07 01:10:57.655988 State can be entered
[B]as_[/B]suspend_time = <Sekunden>
suspend_time_default = <Sekunden>
[autoblind]
type=foo
[[trigger]]
[[[rollladen]]]
type = bool
name = Gemeinsamer Trigger für alle Raffstores
enforce_updates = yes
cycle = 300 = 1
[[default]]
[[[rollladen]]]
as_plugin = active
as_startup_delay = 30
as_repeat_actions = true
suspend_time = 3600
as_item_brightness = dg.diele.helligkeit # Item für Helligkeit
as_item_temperature = Wetter.Temperatur # Item für Temperatur außen
as_item_luftdruck = Wetter.Luftdruck # Item für Luftdruck aussen
as_item_zentral_to_0 = zentral.rollladen.rollladenautomatik
# Zustand "Sperre über Sperr-Item"
[[[[lock]]]]
type = foo
name = Automatik manuell gesperrt
# Aktionen:
# - "Suspend"-Item ggf. zurücksetzen
as_set_suspend = False
# sonst nichts tun
[[[[[enter]]]]]
# Einstieg in "Lock": Wenn
# - das "Lock"-Item gesetzt ist
as_value_lock = True
[[[[suspend]]]]
type = foo
name = Ausgesetzt
# Namensermittlung über eval-Funktion
as_name = eval: autoblind_eval.insert_suspend_time("...suspend", "Automatik ausgesetzt bis %X")
# Aktionen:
# - "Suspend"-Item setzen
as_set_suspend = True
# sonst nichts tun
# Einstieg in "Suspend": Wenn
[[[[[enter_manuell]]]]]
# - die Zustandsermittlung über das "Manuell"-Item ausgelöst wurde
as_value_trigger_source = eval: autoblind_eval.get_relative_itemid("...manuell")
# Verbleib in "Suspend": Wenn
[[[[[enter_stay]]]]]
# - wir bereits in "Suspend" sind
as_value_laststate = var:current.state_id
# - die letzte Änderung des "Manuell"-Items höchstens 3600 Sekunden her ist
as_agemax_manuell = 3600
# - das "Suspend"-Item nicht von irgendwo anders auf "False" gesetzt wurde
as_value_suspend = True
schlafzimmer]
name = Schlafzimmer
sv_page = room
[[rollladen]]
name = rollladen
value = westen
[[[auto]]]
type = bool
value = 0
[[[fahren]]]
enforce_updates = On
type = bool
visu_acl = rw
knx_dpt = 1
knx_send = 2/1/13
[[[stop]]]
type = bool
visu_acl = rw
knx_dpt = 1
knx_send = 2/1/14
[[[status]]]
type = num
visu = yes
sqlite = true
cache = true
knx_dpt = 5
visu_acl = rw
knx_cache = 2/1/15
knx_listen = 2/1/15
knx_send = 2/1/15
[[[pos_speichern]]]
type = num
visu = yes
knx_dpt = 1
visu_acl = rw
knx_cache = 2/1/16
knx_listen = 2/1/16
knx_send = 2/1/16
[[[pos_abrufen]]]
type = num
visu = yes
knx_dpt = 1
visu_acl = rw
knx_cache = 2/1/17
knx_listen = 2/1/17
knx_send = 2/1/17
[[[automatik]]]
[[[[lock]]]]
type = bool
visu_acl = rw
cache = on
[[[[suspend]]]]
type = bool
visu_acl = rw
[[[[state_id]]]]
type = str
visu_acl = rw
cache = on
[[[[state_name]]]]
type = str
visu_acl = r
cache = on
[[[[manuell]]]]
type = bool
# Änderungen dieser Items sollen als manuelle Bedienung gewertet werden
eval_trigger = schlafzimmer.rollladen.fahren | schlafzimmer.rollladen.stop | schlafzimmer.rollladen.pos_abrufen | zentral.rollladen.fahren | zentral.rollladen.stop
# Änderungen, die ursprünglich von diesen Triggern (<caller>:<source>) ausgelöst wurden, sollen nicht als manuelle Bedienung gewertet werden
as_manual_exclude = KNX:0.0.0 | Init:* | schlafzimmer.rollladen.status
[[[[rules]]]]
type = bool
name = Automatik Schlafzimmer
as_plugin = active
#as_item_auto = ..auto
as_item_pos = ..pos_abrufen
as_item_fahren = ..fahren
as_laststate_item_id = .state_id
as_laststate_item_name = .state_name
as_item_lock = .lock
as_item_manuell = .manuell
as_item_suspend = .suspend
as_delay_fahren = autoblind_eval.get_random_int(2,250)
# Über diese Items soll die Statusermittlung ausgelöst werden
eval_trigger = autoblind.trigger.rollladen | schlafzimmer.rollladen.automatik.lock | schlafzimmer.rollladen.automatik.suspend | schlafzimmer.rollladen.fahren | schlafzimmer.rollladen.pos_abrufen | zentral.rollladen.fahren | zentral.rollladen.stop
# In dieses Item soll die Id des aktuellen Zustands geschrieben werden
[[[[[lock]]]]]
as_use = autoblind.default.rollladen.lock
[[[[[suspend]]]]]
as_use = autoblind.default.rollladen.suspend
# Achtung: Beim "suspend"-Item niemals "enforce_updates = yes" setzen! Das führt dazu dass das Setzen des
# suspend-Items bei der Initialisierung zu einem endlosen sofortigen Wiederaufruf der Statusermittlung führt!
