ich habe auch noch meine Probleme beim Suspend.
Im Logfile erscheint:
2016-07-19 23:41:36.094930 Check if state 'EG.Wohnz.Rollo.Rechts.automatik.rules_steuerung.Suspend' ('Ausgesetzt') can be entered:
2016-07-19 23:41:36.096642 Check condition set 'enter_manuell':
2016-07-19 23:41:36.097992 Executing method 'get_relative_itemid(..manuell)'
2016-07-19 23:41:36.099491 Condition 'trigger_source': value=EG.Wohnz.Rollo.Rechts.automatik.manuell negate=False current=Autoblind.trigger.Rollo.WZ
2016-07-19 23:41:36.100939 not OK -> not matching
2016-07-19 23:41:36.102197 Check condition set 'enter_stay':
2016-07-19 23:41:36.103480 Condition 'laststate': value=EG.Wohnz.Rollo.Rechts.automatik.rules_steuerung.Suspend negate=False current=EG.Wohnz.Rollo.Rechts.automatik.rules_steuerung.Suspend
2016-07-19 23:41:36.104786 OK -> matching
2016-07-19 23:41:36.106047 Age of 'laststate': No limits given
2016-07-19 23:41:36.107109 Condition 'manuell': min=None max=None negate=False current=True
2016-07-19 23:41:36.107957 no limit given -> matching
2016-07-19 23:41:36.110134 Age of 'manuell': min=None max=7200 negate=None current=266.342015
2016-07-19 23:41:36.111039 given age limits ok -> matching
2016-07-19 23:41:36.112257 Condition 'suspend': value=True negate=False current=True
2016-07-19 23:41:36.113107 OK -> matching
2016-07-19 23:41:36.114674 Age of 'suspend': No limits given
2016-07-19 23:41:36.115575 State can be entered
2016-07-19 23:41:36.117368 Executing method 'insert_suspend_time(..suspend, Automatik ausgesetzt bis %X)'
2016-07-19 23:41:36.118324 Suspend time is 3600
2016-07-19 23:41:36.119617 Suspend item is EG.Wohnz.Rollo.Rechts.automatik.suspend
2016-07-19 23:41:36.121137 Current suspend age: 2951.45847
2016-07-19 23:41:36.122331 Remaining suspend time: 648.54153
2016-07-19 23:41:36.124139 Suspend finished at 2016-07-19 23:52:24.664832+02:00
2016-07-19 23:41:36.125971 Staying at EG.Wohnz.Rollo.Rechts.automatik.rules_steuerung.Suspend ('Ausgesetzt')
2016-07-19 23:41:36.126907 Action 'suspend': Set 'EG.Wohnz.Rollo.Rechts.automatik.suspend' to 'True'
as_agemax_manuell = 7200 habe ich gesetzt.
Ich vermute die Zeile:
#suspend_time_default = 3600
Aber wie kann ich diesen Wert verändern? Da verstehe ich die Doku nicht.
Auch: wie ist das Verhältnis von suspend_time und as_agmax manuell? Das ist mir unklar.
Für Hilfe wäre ich dankbar....
