tolle Arbeit, habe es grade kurz getestet, funktioniert super.
Eine Fehlermeldung ist bei /list im Log zu finden:
2018-01-29 00:20:59 WARNING dispatcher A TelegramError was raised while processing the Update 2018-01-29 00:20:59 ERROR dispatcher No error handlers are registered, logging exception... Traceback (most recent call last): File "/usr/local/lib/python3.5/dist-packages/telegram/ext/dispatcher.py", line 279, in process_update handler.handle_update(update, self) File "/usr/local/lib/python3.5/dist-packages/telegram/ext/commandhandler.py", line 171, in handle_update return self.callback(dispatcher.bot, update, **optional_args) File "/usr/local/smarthome/plugins/telegram/__init__.py", line 231, in cHandler_list self.list_items(update.message.chat_id) File "/usr/local/smarthome/plugins/telegram/__init__.py", line 279, in list_items self._bot.sendMessage(chat_id=chat_id, text=text) File "/usr/local/lib/python3.5/dist-packages/telegram/bot.py", line 60, in decorator result = func(self, *args, **kwargs) File "/usr/local/lib/python3.5/dist-packages/telegram/bot.py", line 85, in decorator result = self._request.post(url, data, timeout=kwargs.get('timeout')) File "/usr/local/lib/python3.5/dist-packages/telegram/utils/request.py", line 272, in post **urlopen_kwargs) File "/usr/local/lib/python3.5/dist-packages/telegram/utils/request.py", line 210, in _request_wrapper raise BadRequest(message) telegram.error.BadRequest: Message text is empty
