9039 Datum+Uhrzeit Logikbaustein
  • Warichet
    Zitat von TRex Beitrag anzeigen
    je la faite pour tois.
    Merci
  • TRex
    pour mon ami Warichet
    tu le trouve sous logic\Hoegg\Wochentag
    Peter
  • Warichet
    do you have an Array in the Group-Adress from 0-128?
    the value today (17.2.2011) have to be 3
    I'm using Baustein 9039
    I think I got it right now, by just adding 1.
  • TRex
    If you have an GA with legth of 1-Bit it will be always 1
  • Warichet
    Thank you for the hint
    A7 is Day of Week from 0 to 6
    0 ist Monday, 6 is sunday ...
    I've added 1 to the output A7, and have the week start with 1 on monday
  • michel38
    Hey Warichet,
    I had sent you but xxAPI the demo project. So it's mentioned.
    Uwe
  • TRex
    like in Python the Time(6)
    Now you have the counter and you make an object with Text to select the day. (dynamic text)
    then take the 0 to monday, 1 to tuesday...
  • Warichet
    alors WArichet,
    voie ici...
    DaCom - Database Computing GmbH
    I must be blind (and the search also)
    no track of "Wochentage"
    could it be the 17775 Textselektor ???
  • TRex
    alors WArichet,
    voie ici...
  • Warichet
    Zitat von EPIX Beitrag anzeigen
    I use the dynamic Text "14-Byte Textanzeige Wochentage" to transfer the numeric Value into a Text...
    By modifying the dy.Text you could realise any language to be displayed instead of "Montag!
    Thank you for the hint, sounds good.
    Where can I find this module ? I looked in the Download .... no luck
    Maybe it has another name ?
  • EPIX
  • Warichet
    Zitat von Wasserkocher Beitrag anzeigen
    Ich nutze den Baustein 9039 Datum+Uhrzeit (wochentag 0-6) um in meinem Visu header den Tag und das Datum generieren zu lassen
    I would also display the day-of-the-week in the Visu.
    So far, I can display date and time, but not the day-of-the-week.
    I cannot find Baustein 9039, looks like an internal ?
    I've seen a hint to the Baustein of Tilo, but I'm unable to make it work.
    The only KO I can see is the numeric value for day-of-the-week , I'd like to display Monday instead of 1.
    Thanks
  • marlan99
    Zeugt nur von eigener Erfahrung zu diesem Thema ;-)
  • Wasserkocher
    ahh verdammt sofort ins schwarze! Der Variablen Bereich wars!!!
    vielen Dank Marcel!!!
  • marlan99
    Hallo Fabian,
    hab den Baustein auch in Betrieb und funktioniert einwandfrei.
    Hast im HS eventuell die Werte limitiert? min=1 oder so?
    Marcel
