Zitat von Warichet
You wrote earlier that the HS starts up, you get the three double beeps. You also write there is no contact to KNX. Does this mean that in the HS debug page you have plenty of entries under 'Scan-Fehler', and under 'EIB' the table shows nothing sent or received, or maybe high numbers under telegrams lost? If that is the case, it may help an Experte expert if you post a screenshot of the EIB section of the debug page to verify your HS indeed does not 'talk' to the bus.
Or do you think that the HS is working, and you cannot get HS-Monitor to work? The software you can download from the download pages of this forum. The settings need to match what you have set in Experte under Network--> Comminication object gateway. The topmost checkbox, and the bottom three checkboxes must be checked. Define a local IP port (mine is 50003), enter 0.0.0.0 for IP address and Net mask, enter a password, and check the checkbox for that line. On the HS-Monitor settings page enter the same port number and the same password (key).
