HS Watch Address
  • Warichet
    Is that really true?
    Yes, Sir
    Your status is triggered by the actuator port???
    Please pardon my ignorance, but that is what I've understood from the help.
    This is compleytely wrong, imho. Normally it is the other way round: Actuator port has status object as watch adress!
    In my case, I've a Merten actuator, that has a status object, only for channel 1 . I've understood that I could "fake" a status object via the watch address, by monitoring the actual state of the actuator port. The funny thing, it works for a dimmer (seems not to work for 1 bit object)
    Thank you for putting me right
  • MatthiasS
    Zitat von Warichet Beitrag anzeigen
    GA 0/6/21 the actual actuator port (1.1.155#A)
    GA 0/6/22 status, watch address triggered by 0/6/21
    This is completely wrong, imho. Normally it is the other way round: Actuator port has status object as watch adress!
  • Warichet
    Would someone be so kind to check if a Watch Address on a 1bit object can be seen in the HS Monitor ?
    No one has a HS and the HS Monitor and a Watch address and 5 min to help a desperate newbee ?
    I would be very happy if someone could do the test. I'm reaching the "end of the road" due to my lack of experience and no other system to compare with.
    Thank you in advance
  • Warichet
    Thank you
  • Warichet
    Hi Gaston,
    Nice to hear from you again
    Zitat von Gaston Beitrag anzeigen
    But anyway I am asking myself why you need watch addresses for Aktuator status objects.
    Ouups, pardon, I didn't make myself very clear and forgot to mention that this crummy actuator has no status object, hence the usefullness of the watch address
    You may then use the Status object in zthe HS as central address for the actual switching object to keep it in sync with central commands.
    OK, thanks. I haven't explored the central address function yet (still so many things to learn )
  • Gaston
    Hi Raymond,
    My first thought would be that the read flag is not set on the status object. But anyway I am asking myself why you need watch addresses for Aktuator status objects. Usually these get transmitted (assuming the T flag is set) at least when the state of the port changes. So there is no need to explicitely read them.
    Cheers,
    Gaston
  • Warichet
    hat ein Thema erstellt HS Watch Address.
    HS Watch Address
    I've defined several "watch address", and they work fine, except one.
    So, on the same actuator, I've defined following:
    When looking in the MS Monitor: it works, both GA are toggled together
    GA 0/6/23 the actual actuator port (1.1.155#B)
    GA 0/6/24 status, watch address triggered by 0/6/23
    When looking in the MS Monitor: I see that only GA 0/6/23 is toggled. GA 0/6/24 doesn't move, seems to be dead.
    I realize that the above statement might look crazy, but hélas, that's what I see.
    NB: port 1.1.155#B *IS WORKING*, I hear it clicking.
    NB: when I link GA 0/6/24 to 0/6/21 (it doesn't make sense, just for test) it doesn't work either.
    How could I debug this problem ? Are there any known restrictions ? (didn't find any in the help).
    Thank you for your hints
