Objekt mit 12 Linien & >300 Geräten angegriffen; 70% der Geräte kaputtprogrammiert
  • henfri
    Wow. Thanks for sharing!
  • ziceva
    Hello KNX Community,
    First of all, sorry for posting in English on a Geman forum (if this breaks some rule of the forum, mods can delete this post easily).
    I want to share my (complete amateurish) take on this problem; I have a friend that knows someone that faced the exact same problem described in this topic: sometime at the end of December an attacker gained access to the system and locked all devices with a BCU-password and there was no way to take back control of the system.
    What I would like to mention from the start is that I am a complete amateur when it comes to hardware (my skills are mostly software), so some of my methods are .. amateur-level at best .. Anyway, I like hacking circuits together and reverse engineering stuff, so this seamed like a nice challenge given that I never worked with KNX before.
    After spending days taking things apart (Gira 5133/5131/5142 buttons, Gira 8 and 16 channel actuators and even a Gira weather station) it became clear that, in this case, the method that Limes used could not be applied since I only had Gira devices, and although they are all powered by Atmel micros (with which I am quite familiar and comfortable probing and poking), all of the devices have the lock-fuses set so there is no way to access the flash/eeprom areas and get a more limited space for a bruteforce attack.
    Indeed, trying to bruteforce the complete 32-bit space seems like impossible at first sight and it would take multiple years to complete on a single device at the low speed of 9600bps of the KNX bus. But having tens or hundreds of devices with (what it is assumed to be!) the same password, gives a glimmer of hope, even more so if some way of speeding up the process, even a little bit, can be found.
    When probing for the flash/eeprom contents it became apparent that the buttons could be of help when in comes to the speed of the attack: the buttons (bear with me here, I knew nothing of the knx-system at the time) are not directly connected to the bus, but use the bus coupler 3 and the communication here actually uses a 115200bps UART: there is a microcontroller in bus coupler 3 that communicates with the KNX bus at the limited 9600 baudrate and with the buttons themselves at the much higher 115200 baudrate. Even better, the microcontroller in the bus coupler acts only as a gateway and the actual password is in the buttons microcontroller. Probing this 115200 bus (easily done with any logic analyzer, or in my case with a Rygol scope) revealed that the protocol used is knx-like; It is not all the way knx (and packed a nasty surprise for me because of my amateur-level probing), but the manual of serial transmission in KNX can be used to identify what it is sent to ask for authorization and the relevant reply).
    So, at this point I kind of decided that sending multiple auth-requests to multiple devices in parallel over this faster bus could help. The next step would be to decide on the host (or hosts) that are to be used to format and send the packets to the devices. The first idea (as usual, the one that doesn't work) was to use a bunch of inexpensive esp32 dev boards since they have 2 (maybe even 3, if I can get around the bootloader log on UART0) hardware UARTs (at 115200 baudrate, I correctly assumed that only hardware UARTs are usable). Also, the WiFi can be used for higher level orchestration of the attack.
    I already knew that even though at 115200 baudrate, the bus has some timing requirements: the host cannot send as fast as possible, and the device will delay quite some time before responding, so maybe some multiplexing could be done in software (some hardware considerations must be taken into account when connecting more devices on a UART, but in the end I never got that far with this idea) in order to connect two devices per esp32 UART port. This would require some 10 esps to connect 60 devices (10 esp x 3 UART x 2 devices) ... and at a speed of 30 tries per second (yeah, it was wishful thinking at this point), the total time for the complete 32 bit space would be no more than 30 days; while not great, this amount of time seems something that could work, doesn't it?.
    Unfortunately, this proved to not work, because when I was probing the 115200 baudrate bus I completely missed the fact that the bus was actually using a 9E1 serial frame format which I assume is just a quirk of the Atmel implementation since this is not at all a standard frame format (9N1 is the closest standard I could find that was maybe-kinda used sometime far in the past on non-Atmel devices via the weird space/mark parity that in turn is not really standard). Anyway, this format is definitely not supported by the esp32 hardware UARTs. After fiddling a few more days with some SoftwareSerial libraries for the esp32 that supported the required frame format, this was definitely a dead-end (it's exactly what you would expect from multiple software serials running on a single micro-controller).
    What was required, was an Atmel-based host for the frame-formatting, sending and receiving; Arduino Mega2560 (I did promise you amateur solutions, didn't I?) has 4 nice hardware UARTs just waiting to be used. A professional approach would be to maybe use one (or maybe more) FPGAs to implement more than 4 UARTs per host, but I had none of those, so Arduino it was (ended up having 23!! Arduinos working toghether ... I borrowed every Arduino I could find from all my friends and then also bought quite a few of them .. luckily, if you are buying non-branded ones - long live open-hardware! - they are quite cheap at ~10Eur here in Romania).
    The setup that ended up working was hooking up 3 devices on 3 of the UART ports of the Arduino (I gave up on the multiplexing rubbish also) having the fourth UART connected to an esp32 for orchestration. This 4th port could have been a software serial since I decided that 9600bps is enough to just receive tasks and report statuses, but I knew for a fact that software serials mess up the timing interrupts in the Arduino and I was already more then fed-up with the software implementation, so I decided to just use one of the hardware ones for this purpose. In the esp32 I did use software implemented serials since I had no timing requirements (but I did end up using checksums for my task/status frames, because it was somewhat unreliable, but not enough to be a problem) because I wanted to connect four Arduinos to a single esp32 (I could have connected more, but I already had the esps to spare). I ended up also 3d-printing small racks to hold the devices and their Arduino together; even so, the wiring was an absolute mess ... This setup gave me ~18 tries per second per device (some devices - 5133/5131 were actually faster at ~19+ tries per second, and some were slower - the 5142s only replied fast enough for 8-9 tries/second; I guess the micro-controller was loaded more with the management of the small display, and that is why its replies were delayed more).
    Having now 6 esp32s each having 4 racks (the sixth ended up having only three, because I was getting diminishing returns from the slower 5142s that I had available) each rack having in turn one Arduino and 3 devices, I split the entire 32 bit domain in 8192 "chunks" of 524288 keys each (2^13 chunks x 2^19 keys for easy management). Each device would then be assigned one random (this ended up helping a lot!) chunk and it would try each key in the chunk (one chunk is a number from 0-8191: shift the number 19bits to the left and start incrementing 2^19 times; then repeat, and repeat, and repeat ... quite an easy task to implement into the Arduino, after I figured out what frames to send to the device and how to parse the replies). The esp32s would then forward data to and from the Arduinos to a php script with a small sqlite database in order to keep track of the progress. With this setup one 5133/5131 would finish its assigned chunk in about 7h30-8h00; one 5142 would finish in about double that time.
    The worst-case computed time ended up being closer to 45 days, but in the end the key was found after ~15days; The system had only checked ~37% of the complete 32bit space and the key, if taken in sequential order form 0x00000000 to 0xFFFFFFFF was at ~73% of the space (so by taking the search randomly, I got a 2x speedup, although this of course was no guarantee at the start ... I do not know enough statistics to conclude that random is better then sequential, but in my case it helped a lot).
    Anyways, that is what I wanted to share with you about my first experience with KNX devices.
    If reviving this old thread was a bad idea (or it is somehow considered thread hijacking), a mod of the forum should delete or move my post as appropriate.
    Best regards,
    John
    Zuletzt geändert von ziceva; 12.02.2022, 23:29.
  • thewhobox
    Ich weiß nicht ob die ETS es zulässt weniger Zeichen einzugeben.
    Aber so oder so werden die restlichen Zeichen aufgefüllt, dass es wieder 8 Zeichen sind. (Wie in deinem Beispiel zu 0000ABCD).
    Im AuthorizeRequest müssen 4 Bytes übergeben werden.
    Die einzige Kombination die nicht geht als Passwort ist 0xFFFFFFFF. Das ist nämlich das Standard Passwort, auch wenn keins gesetzt oder das vorhandene gelöscht wurde.
  • Opfer 1
    Zitat von proggerKA Beitrag anzeigen
    Das ist normal. Das BAU Passwort besteht aus 4 Bytes. In Hex schreibweise sind das 8 Zeichen(0-9 und A-F)
    Aber kann man auch einfach weniger Zeichen verwenden? z.B. nur ABCD oder müsste es dann 0000ABCD sein? Die Nullen werden bei Hex automatisch aufgefüllt oder? 🤔
  • MGK
    Auch von mir danke für den Hinweis mit den PCBites. Gleich bestellt, letzte Woche noch gebastelt mit Modellbauklemmen…
    Immer wieder cool was man hier im Forum so findet und lernt!
  • Hennessy
    Danke für die Infos und Bäume habe ich genug im Garten. Da braucht es nicht auch noch einen drinnen.
  • concept
    Zitat von Hennessy Beitrag anzeigen
    Muss ich mir auch für Weihnachten unter den Baum legen.
    Bei mir gibts keinen Baum, das geht bei mir direkt auf den Labortisch ich hab mein Set soeben bestellt.
    Gibt ein paar YT Videos dazu. Dave, der verrückte Aussi, hat das auch getestet, guckst Du hier
  • Hennessy
    Yep, das schaut echt cool aus. Muss ich mir auch für Weihnachten unter den Baum legen.
  • EC665
    Wow, geiles Produkt! PCBite kannte ich auch noch nicht - kommt auf meinen Wunschzettel für Weihnachten...
  • concept
    PCBite: sehr cooles produkt, das ich noch nicht kannte!
    und erst noch verblüffend preiswert! ich glaub, das muss ich auch haben
  • fidelio
    WOW ist das cool! Respekt.
    Ich für meinen Teil würde mich freuen, wenn wir das IoT thema an anderer Stelle mal weiter führen. Es gab hier schon sehr aufschlussreiche Posts dazu. Und es ist beängstigend, was da Leute mit shellys machen (andere Firmware flashen) nur damit sie diese "smart home" devices vom Handy bedienen können. Ich denke, Cybersecurity in smart homes wird uns noch mehr beschäftigen.
  • Limes
    Zitat von delija999 Beitrag anzeigen
    und wie wurde das PW ausgelesen?
    so:
  • ueknx
    Auch meine Steinel True Presence wurden von Limes Security ausgelesen. Nochmals danke an Limes hat alles super und innerhalb einer Woche geklappt. Leider wurden für die MDT Aktoren andere PW verwendet. Mein Glück ignorieren sie den Bau-Schlüssel
  • Klaus Gütter
    https://knx-user-forum.de/forum/%C3%...01#post1703501
    EDIT: Mike war schneller
  • thewhobox
    delija999 Das wurde schon von Limes in Post #226 genau erklärt.
