Thank you for the reply.
Zitat von IBFS
Zitat von IBFS
Hi Makki,
Zitat von makki
My config: Vitola 200 VB2, Vitocell-H 100, Vitotronic 300 KW3, Vitocom 200 type EIB
At first sight, I'm a bit confused:
On one hand: I think my system uses the Viessmann "2 wire Bus"
On the other hand: the web site doesn't mention this bus.
Also, the photo shows a special cable plugged into the left corner of the Vitotronic. The Vitotronic 300 KW3 doesn't have a connector.
CORRECTION: no connector needed !
It looks like that the status LEDs are used for the Optolink Schnittstelle, so the link is infra-red
I have to check it more seriously and let you know.... unless someone comes up with more detailed info
Thank you for the info.
