eib.log Einträge A_DeviceDescriptor_Response ...
Dieses Thema ist geschlossen.
    [wiregate] eib.log Einträge A_DeviceDescriptor_Response ...
    ich habe Einträge in der eib.log, die ich mir nicht erklären kann. Es gibt sicher Experten die mir da weiter helfen können.
    Zunächst einmal ein Ausschnitt aus der Datei.
    2016-05-31 18:02:35.223,A_OTHER,2.0.249,2.0.0,,,,,0,system,5, T_DATA_CONNECTED_REQ,1
    2016-05-31 18:02:35.242,,2.0.0,2.0.249,,,,,0,system,6,T_ACK,1
    2016-05-31 18:02:35.268,A_OTHER,2.0.0,2.0.249,,,,,0,system,6, T_DATA_CONNECTED_REQ,1
    2016-05-31 18:02:35.303,,2.0.249,2.0.0,,,,,0,system,5,T_ACK,1
    2016-05-31 18:02:35.330,,2.0.249,2.0.0,,,,,0,system,5,T_DISCO NNECT_REQ,0
    2016-06-01 12:53:47.763,,2.0.255,2.0.0,,,,,0,system,6,T_CONNE CT_REQ,0
    2016-06-01 12:53:47.823,A_DeviceDescriptor_Read,2.0.255,2.0.0 ,,,,,0,system,6,T_DATA_CONNECTED_REQ,0
    2016-06-01 12:53:50.958,A_DeviceDescriptor_Read,2.0.255,2.0.0 ,,,,,0,system,6,T_DATA_CONNECTED_REQ,0
    2016-06-01 12:53:54.093,A_DeviceDescriptor_Read,2.0.255,2.0.0 ,,,,,0,system,6,T_DATA_CONNECTED_REQ,0
    2016-06-01 12:53:57.229,A_DeviceDescriptor_Read,2.0.255,2.0.0 ,,,,,0,system,6,T_DATA_CONNECTED_REQ,0
    2016-06-01 12:54:00.365,A_DeviceDescriptor_Read,2.0.255,2.0.0 ,,,,,0,system,6,T_DATA_CONNECTED_REQ,0
    2016-06-01 12:54:03.498,,2.0.255,2.0.0,,,,,0,system,6,T_DISCO NNECT_REQ,0
    2016-06-01 12:54:24.135,,2.0.255,2.0.0,,,,,0,system,6,T_CONNE CT_REQ,0
    2016-06-01 12:54:24.208,A_DeviceDescriptor_Read,2.0.255,2.0.0 ,,,,,0,system,6,T_DATA_CONNECTED_REQ,0
    2016-06-01 12:54:27.343,A_DeviceDescriptor_Read,2.0.255,2.0.0 ,,,,,0,system,6,T_DATA_CONNECTED_REQ,0
    2016-06-01 12:54:30.479,A_DeviceDescriptor_Read,2.0.255,2.0.0 ,,,,,0,system,6,T_DATA_CONNECTED_REQ,0
    2016-06-01 12:54:33.613,A_DeviceDescriptor_Read,2.0.255,2.0.0 ,,,,,0,system,6,T_DATA_CONNECTED_REQ,0
    2016-06-01 12:54:36.750,A_DeviceDescriptor_Read,2.0.255,2.0.0 ,,,,,0,system,6,T_DATA_CONNECTED_REQ,0
    2016-06-01 12:54:39.883,,2.0.255,2.0.0,,,,,0,system,6,T_DISCO NNECT_REQ,0
    2016-06-01 12:56:52.507,,2.0.255,2.0.0,,,,,0,system,6,T_CONNE CT_REQ,0
    2.0.0/2.0.255 ist ein IP-Router.
    In der Anlage sind zunächst zwei Häuser über IP Verbunden. Wir hatten gemeinsam mit dem IT Mann die Verbindung geprüft. KNX-Telegramme kamen an. Aufzeichnung auf dem Wiregate gestartet. Das zweite Haus hat den Router 5.0.0. Es sollen Telegramme von der Wetterstation ankommen. Das tun sie sporadisch auch. Ich hätte jedoch folgendes erwartet:
    2016-06-01 14:56:46.027,A_GroupValue_Write,5.0.2,15/0/54,00 C8,,,,0,low,4,T_DATA_XXX_REQ,0
    2016-06-01 14:56:47.156,A_GroupValue_Write,5.0.2,15/0/52,6C C4,,,,0,low,4,T_DATA_XXX_REQ,0
    2016-06-01 14:56:48.309,A_GroupValue_Write,5.0.2,15/0/55,D3,,,,0,low,4,T_DATA_XXX_REQ,0
    2016-06-01 14:56:51.053,A_GroupValue_Write,5.0.2,15/0/54,00 C8,,,,0,low,4,T_DATA_XXX_REQ,0
    2016-06-01 14:56:51.118,A_GroupValue_Write,5.0.2,15/0/53,5C 01,,,,0,low,4,T_DATA_XXX_REQ,0
    2016-06-01 14:56:53.334,A_GroupValue_Write,5.0.2,15/0/55,D3,,,,0,low,4,T_DATA_XXX_REQ,0
    2016-06-01 14:56:56.082,A_GroupValue_Write,5.0.2,15/0/54,00 C8,,,,0,low,4,T_DATA_XXX_REQ,0
    2016-06-01 14:56:56.723,A_GroupValue_Write,5.0.2,15/0/56,0C 4C,,,,0,low,4,T_DATA_XXX_REQ,0
    2016-06-01 14:56:58.369,A_GroupValue_Write,5.0.2,15/0/55,D3,,,,0,low,4,T_DATA_XXX_REQ,0
    2016-06-01 14:57:01.110,A_GroupValue_Write,5.0.2,15/0/54,00 96,,,,0,low,4,T_DATA_XXX_REQ,0
    2016-06-01 14:57:01.579,A_GroupValue_Write,5.0.2,15/0/59,00,,,,0,low,4,T_DATA_XXX_REQ,0
    2016-06-01 14:57:03.385,A_GroupValue_Write,5.0.2,15/0/55,D3,,,,0,low,4,T_DATA_XXX_REQ,0
    2016-06-01 14:57:13.440,A_GroupValue_Write,5.0.2,15/0/55,D3,,,,0,low,4,T_DATA_XXX_REQ,0
    2016-06-01 14:57:16.194,A_GroupValue_Write,5.0.2,15/0/54,00 64,,,,0,low,4,T_DATA_XXX_REQ,0
    2016-06-01 14:57:17.219,A_GroupValue_Write,5.0.2,15/0/52,6C C4,,,,0,low,4,T_DATA_XXX_REQ,0
    2016-06-01 14:57:18.475,A_GroupValue_Write,5.0.2,15/0/55,D3,,,,0,low,4,T_DATA_XXX_REQ,0
    2016-06-01 14:57:21.186,A_GroupValue_Write,5.0.2,15/0/53,5C 01,,,,0,low,4,T_DATA_XXX_REQ,0
    2016-06-01 14:57:21.220,A_GroupValue_Write,5.0.2,15/0/54,00 64,,,,0,low,4,T_DATA_XXX_REQ,0
    2016-06-01 14:57:23.498,A_GroupValue_Write,5.0.2,15/0/55,D3,,,,0,low,4,T_DATA_XXX_REQ,0
    2016-06-01 14:57:26.252,A_GroupValue_Write,5.0.2,15/0/54,00 C8,,,,0,low,4,T_DATA_XXX_REQ,0
    Das finde ich in den letzten 14 Tagen jedoch nur an wenigen Stellen.
    Jetzt zu meinen Fragen:
    1. Gibt es eine Erläuterung zu den Bezeichnungen A_DeviceDescriptor_Read ,... in der eib.log?
    2. Woran kann es liegen, das die Kommunikation über die IP-Router mal klappt und mal nicht ohne das wir KNX-seitig etwas ändern?
    Zum Netzwerk: Verbindung zwischen den Häuser über CU - Switch - LWL - SWITCH - CU. Genaueres müsste ich über die IT erfragen.
    Der Wiregate ist über USB/KNX in der Linie 2.0 (2.0.249) angebunden. IP Tunnel aktiviert Router deaktiviert.
    Vielen Dank!
    Arno Zietz
