ist es richtig, dass ich vom DWD-Plugin die Luftfeuchte nicht bekomme?
Hendrik
Hendrik
#!/usr/bin/python
from xml.dom import minidom
import urllib2
def get_current_weather_data(xml, name):
for node in xml.getElementsByTagName(name):
return node.childNodes[0].nodeValue
response= urllib2.urlopen('http://api.wunderground.com/weatherstation/WXCurrentObXML.asp?ID=INIEDERS60')
xml=response.read()
xml=minidom.parseString(xml)
#xml=minidom.parse("wetter.xml")
for item in sh.aktuelles_wetter:
#print item.name
item(get_current_weather_data(xml,item.name))
#relative_humidity=get_current_weather_data(xml,'relative_humidity')
#print(relative_humidity)
/usr/local/smarthome/items# cat wetter.conf
[aktuelles_wetter]
[[windrichtung]]
type=num
name=wind_degrees
[[temperatur]]
type=num
name=temp_c
for item in sh.aktuelles_wetter: print item.name
for item in sh.aktuelles_wetter: logger.debug(item.id) item(get_current_weather_data(xml,item.id)) logger.debug(get_current_weather_data(xml,item.id))
2013-08-01 22:33:01,293 wunderground DEBUG <bound method Item.id of Item: 0> -- wunderground.py:<module>:23 2013-08-01 22:33:01,296 wunderground DEBUG None -- wunderground.py:<module>:25 2013-08-01 22:33:01,297 wunderground DEBUG <bound method Item.id of Item: 0> -- wunderground.py:<module>:23 2013-08-01 22:33:01,300 wunderground DEBUG None -- wunderground.py:<module>:25 2013-08-01 22:33:01,300 wunderground DEBUG <bound method Item.id of Item: 0> -- wunderground.py:<module>:23 2013-08-01 22:33:01,303 wunderground DEBUG None -- wunderground.py:<module>:25 2013-08-01 22:33:01,303 wunderground DEBUG <bound method Item.id of Item: 0> -- wunderground.py:<module>:23 2013-08-01 22:33:01,306 wunderground DEBUG None -- wunderground.py:<module>:25 2013-08-01 22:33:01,307 wunderground DEBUG <bound method Item.id of Item: 0> -- wunderground.py:<module>:23 2013-08-01 22:33:01,310 wunderground DEBUG None -- wunderground.py:<module>:25
[[Niederschlag_Heute]]
type=num
name=percip_today_metric
knx_send=7/7/17
knx_dpt=9
[test] type = num wg = percip_today_metric # oder wunderground = percip_today_metric
sh.test.conf['wg']
2013-08-02 22:53:01,266 wunderground DEBUG wind_degrees -- wunderground.py:<module>:23 2013-08-02 22:53:01,267 wunderground DEBUG aktuelles_wetter.windrichtung = 110 via Logic None -- item.py:_update:219 2013-08-02 22:53:01,274 wunderground ERROR Item 'aktuelles_wetter.relative_luftfeuchte': value (39%) does not match type (num). Via Logic None -- item.py:__call__:197
[[relative_luftfeuchte_perc]]
type=num
xmlstring=relative_humidity
[[relative_luftfeuchte]]
type=num
rrd=1
visu=yes
eval=sh.aktuelles_wetter.relative_luftfeuchte_perc() * 0.01
eval_trigger=aktuelles_wetter.relative_luftfeuchte_perc
sv_widget="{{ plot.period('item', 'item', 'avg', 24h) }}"
knx_send=7/7/251
knx_listen=7/7/251
knx_dpt=5
