HomeServer passwords
    HS/FS HomeServer passwords
    Can someone help me, with the HS password, please ? (Experte 4.5, Ajax Visu)
    Sometimes I get the PW right on one side, but it doesn't work on an other
    So far I've identified the following
    Stammdaten, Benutzer
    User1 with PW1
    User2 with PW2
    User3 with PW3
    Login script
    User1 with PW bizarre, not found elsewhere ?!?
    Upload
    User1 with PW11 Used only for uploading a project ?
    The trick is to find which PW is used where and make sure they match
    Thanks for any help
    Nobody can help ?
    All I need to know is:
    where is a PW creted
    where is that PW used
      Either here (Quad Client), or there (Free Visu)
        Hello,
        Thanks for replying.
        I don't understand picture 1.
        Picture 2 is no problem. Username and password are well known, but I don't know how / where to use it
          Picture #1 is only of interest when you use the QuadClient.
          The user and associated password, as entered in the screen shown in picture #2, are needed:
          1. When you transfer a project from Experte to the HS;
          2. If you have a visu other than the QC, you will need the username and associated password to access the visu.
            Either you enter the information permanently in the '.htm' you use to call the visu,
            or you enter it in the pop-up screen if you do not have the information saved in the .htm file.
            The .htm file is stored in the hsupload subfolder you use for the the visu, for instance ...\hsupload\hspv-gira\start.htm.
          My guess is that you have used the credentials hundreds of times already, without realizing it...
            OK, not my case.
            OK, that's the standard User Management page
            are needed:[LIST=1][*]When you transfer a project from Experte to the HS;
            >[LIST=1]
            Is this a new System Liste ?
            So far, I understand that there is a PW needed when transfering a projekt from Experte to the PS.
            I guess this PC should not be misplaced , otherwise a transfer via RS232 is required.
            I guess a PW for Projekt can only be written, no read back from HS
            >[*]If you have a visu other than the QC, you will need the username and associated password to access the visu.
            I've a Ajax Visu, is that any special stuff ?
            OK
            I noticed a difference in the file structure
            On the Experte PC, I see \hsupload\hspv-gira\start.htm.
            On some places I see \hsupload\hspv\start.htm.
            Is that OK ?
            Thanks for your kind help
              If I get you right
              The PW used for the HS upload is the only system management PW
              The user PW belong to the user
              There is no PW change when doing the Exchage upload procedure
                Hello Raymond!
                I'll try to answer your questions one by one.
                I don't know what you mean by 'is this a new system list'. (Might be an issue with formatting the forum page on your browser - I used a bulleted list to mention the two separate uses of the user credentials I am aware of.) The user credentials are entered in the screen as shown in picture #2 in the earlier post - it is not really a list.
                Zitat von Warichet Beitrag anzeigen
                So far, I understand that there is a PW needed when transferring a project from Experte to the HS
                Right, you need that password when you upload the project to the HomeServer. When you have a back-up (with passwords) of your project in a safe place you do NOT need to worry about a transfer to the HS when your PC is inoperable. Just install the Experte software on another PC, open the back-up of the project on that PC and you are where you were at the time of the back-up.
                The Ajax visu is a freely configurable visualisation. No 'special stuff' as far as I am concerned. The default folder structure (when Experte is installed) is ...\hsupload\hspv-gira\<startfiles>.htm. Whatever the naming of the folder structure is, is what you have to enter as URL, in this case for instance ..../opt/hspv-gira\start.htm. If you find the 'hspv-gira' too long or too cumbersome, you can rename it to anything you want. If you rename the folder 'hspv-gira' to 'hspv', then you also need to use that shorter name in the URL.
                When transferring a project to the HS it uses the upload folder in the project folder you specified (see attachment). Whatever you have in that directory is what should transfer to the HS.
                You can have as many users as you like, but need at least one. Each user can have permissions as desired. An admin / system management is a user like any other user, only the rights would be extensive. Normally, visu users have more limited rights - but not necessarily. When you want a change of passwords, update the 'User' section (as in figure #2 of the earlier post) with the new password. Transfer the project to the HS using the current (=old, previous) password. Once the project has been transferred, a next transfer will require the new password (if you changed it for the user you use to upload).
                Hope this all makes sense :-)
                Bram
                  Hello Bram,
                  Sorry for being late.
                  My mistake
                  OK, that was an easy one ;-)
                  OK
                  OK
                  I think I got it, I have to exercise a bit, but I'm scared to land up in a non-reversable situation
                  What I'm missing, but with a little help from my friends :-) well known tune, is a table with a summary of passwords, like attached, with the source (where created) and where used ( destination)
                  Thank you for your time & patience
                  This gallery has 1 photos.
                    As long as you know the current user credentials (for a user with full access rights, say: the 'admin'), and you know the new password for that user, then it is a standard process to transfer the project with the current (old) password, and next time use the new password.
                    What I'm missing [...] is a table with a summary of passwords
                    If you only have a few users (say: 3), then the information in the user panel of Experte should suffice. If you have lots of users then a table comes in handy. You will have to create that table yourself. With all the possible user rights (I think the default is 16 levels) that you can turn on or off you need a fairly extensive table - MS-Excel would do. But where you use it, and what you use the different users / user rights for, you will need to define yourself.
                    The easy part of your question to answer is where the user credentials are created, and user rights are set: in the 'User' panel of Experte.
                      I see no end with my misery.
                      After much trial & error (mainly error), I'm still nowhere.I'm up to the point where I'm considering dropping the AJAX part of the Visu and reverting back to the the standard version.
                      Does this make any sens ?
                      Somebody has some experience with such a setup ?
                        No, it does not make sense to me. If you have an Ajax visu in your project, why would you not want to use it?
                        What exactly is it that is not working for you? I use the pocket-visu (hspv), which uses the same set-up as 'hsav'. Same folder structure, same method to access the visu webpage.
                        Let us know what it is exactly that you are trying to accomplish.
                          I'm still hammering on the same nail :-)
                          I made a mistake in the setup, and cannot get rid of it
                          Any idea on what's is going on ?
                          This gallery has 3 photos.
                            Each User needs a Startpage
                              Under both tabs 'Gira 1024 ...' you need to set the starting point for the visu, so the page where you want the user to start. See attachment.
