HomeServer passwords
    Too happy, too early :-|
    > Under both tabs 'Gira 1024 ...' you need to set the starting point for the visu,
    Yes, OK, I forgot
    > so the page where you want the user to start.
    OK
    Thanks to both
    The errors during transfer are gone :-)
    There is still an issue with the Visu.
    To make sure, I reboot the Visu and the HS, I wait for the first beep, and some later, the 3 double beeps.
    At that time, everything looks fine:
    the icons are there, I can navigate the tree, up & down, but nothing happens, it is as if there is a missing connection, or a password mismatch.
    I'll check if the log can teach me more
      Zitat von bramlangen Beitrag anzeigen
      If you have an Ajax visu in your project, why would you not want to use it?
      Well, it *is* an Ajax Visu, so far I used it without much problems, thanks to the kind help of NilsS
      What exactly is it that is not working for you?
      As mentioned above, the situation evolved a bit (I thought it was solved)
      So, when booting fresh, I see the whole boot process, up to the 3 double beeps, everything looks fine, but no contact to KNX.
      In a desperate move, I set all password to be the same. No luck
      I still persist my problem has to do with password, access rights, permissions or so but I've no clue yet
      Is there any doc available around the topic "password" "access rights" ?
        Is the HomeServer working at all? When you say you do not have contact with KNX, is that the current situation? Can you let the HS execute an action by forcing a KO using HS-Monitor? If that would not work, then nothing in the visu will result in an action either.
        I am not aware of any documents specifically on the two topics you mention. For your testing, I suggest you use the credentials of a user with full access rights. In your screenshot you show only 4 levels being checked. In Experte, check for your visu elements if you have the proper user group(s) checked, so that there is at least a match between the visu element (user group) and the access rights of a user...
          Sorry to be a pain, but I'm unable to do that.
          Maybe I miss a pre-requisite ? or a password defined somewhere else ?
          Would you be so kind to provide me with a short example ?
          I guess it has to be defined in 2 places
          Thank you for your patience.
            What exactly is it that you are unable to do?
            You wrote earlier that the HS starts up, you get the three double beeps. You also write there is no contact to KNX. Does this mean that in the HS debug page you have plenty of entries under 'Scan-Fehler', and under 'EIB' the table shows nothing sent or received, or maybe high numbers under telegrams lost? If that is the case, it may help an Experte expert if you post a screenshot of the EIB section of the debug page to verify your HS indeed does not 'talk' to the bus.
            Or do you think that the HS is working, and you cannot get HS-Monitor to work? The software you can download from the download pages of this forum. The settings need to match what you have set in Experte under Network--> Comminication object gateway. The topmost checkbox, and the bottom three checkboxes must be checked. Define a local IP port (mine is 50003), enter 0.0.0.0 for IP address and Net mask, enter a password, and check the checkbox for that line. On the HS-Monitor settings page enter the same port number and the same password (key).
