Slider
    Slider
    Abend,
    I would like to use a slider in my popup to set the percentage for dimming.
    I saw one on the forum in an arc model klick on the arc, keep the button down.
    choose the value, was in a box beside, and the arc was growing. It was great !!
    but ....
    I can not find it anymore.......
    I need it for VISU not for quadclient.
    in combi with xxapi is no problem.
    Danke,
    Grusse,
    Ger
    Abend zusammen,
    Just as I hit the send button, I realized XXSLIDER..... aaargggghhh
    Implemented the Slider with the doku thread from Hans, working !!!
    now I want to change the standard slider, also I want a value text neben the slider button, und I would like to use a template.
    How do I make a template?
    grusse,
    Ger
      Hi All,
      This is what I have sofar;
      xxAPI.xxtemplates.MYSLIDER = function ( obj )
      obj.popupbox.addClass("myslider");
      obj.options.xxslider = $.extend({
      "cursor" : pointer
      },obj.options.xxslider);
      xxAPI.xxtemplates.xxslider ( obj );
      and I call it using;
      XXOPTIONS*xxtemplate=MYSLIDER;
      In this try-out want to change the cursor arrow to hand-pointer when over the slider.
      Is this correct sofar?
      grusse,
      Ger
        Hi All,
        I did some digging.
        found the GIRA quadclient pop-up slider. Found them in a SVG (Scalable vector graphic) and a XAML file.
        the knob the slider and the slider background.
        how do I implement this in the template?
        Please help.
        Danke,
        Grusse,
        Ger
        PS, you can find the slider in the zipped "client_icons_svg" dir.
        because of the format I cannot upload them ! sorry
        Zuletzt geändert von TBBW; 21.02.2016, 21:50. Grund: slider source
          Abend,
          How do I set the Slider tooltip to ON?
          Grusse,
          Ger
            Abend leute,
            I would be very happy to get some help on my slider project.
            I want to change the standard slider look.
            also I would like to have the tooltip active, the numbers next to the slider.
            I had a look at the lammelle demo-project from Vento.
            I do not know where to start.
            I can change the original look, but where is it stored.
            or I can make a template that overrides the original, also where do I put it.
            the answer does not has to be from A to Z, a start would be nice aswel!!
            also answers in German is not a problem, only my German writing is poor ....
            thanks in advance,
            Ger
              I have the Same Problem.
