Edomi Beendet - Kein Status verfügbar
    Fehler: Edomi Beendet - Kein Status verfügbar
    First of all, I am not German speaking. However, feel free to respond in German. I will understand. Vielen Dank!
    I installed Edomi on my Synology via Docker. I used pfischi's edomi-docker. Installation went well, and all seemed to work. E.g. I was able to read the KNX Monitor via Edomi and created and activated a project.
    I "paused" Edomi for some reason. And now I'm not able to re-start it. When I log on to Edomi (https://IP:42901/admin/) I get "Beendet - Kein Status verfügbar"
    What I tried:
    * Stop and restart the container;
    * Restart my Synology (host OS);
    I wanted to log on via SSH (port 22222), but I get an "Access Denied". Should I use the same log on credentials as the Edomi graphical UI (admin/admin)?
    My apologies if this is a stupid question.
    Kind regards,
    Dries
    The login credentials are "root / 123456".
      vento66 : thank you!
      I checked the log file. It is not telling me much:
      https://dl.dropboxusercontent.com/u/16028211/edomi.csv
      I didn't configure much (I just created an empty project), so I could just delete everything and start over. However, if I don't understand the problem, it might come again.
