Fehler Log - verstehen
    nachdem ich das AutoBackup deaktiviert habe (mache ich jetzt per ZSU) möchte ich weitere Fehler eliminieren.
    Dazu eine Frage.
    Wie finde ich bei folgendem Fehler Log raus was es ist?
    Hier mal mein Fehler Log.
     [TABLE="border: 0, cellpadding: 0, cellspacing: 0"]
    [TR]
    [TD]2017-09-10 16:14:47[/TD]
     			[TD]             671406[/TD]
     			[TD]?[/TD]
     			[TD]    16727[/TD]
     			[TD]Exception: The connection was lost.[/TD]
     			[TD]EXCEPTION[/TD]
     		[/TR]
    [TR]
     			[TD]             797307[/TD]
     			[TD]?[/TD]
     			[TD]    16732[/TD]
     			[TD]EXCEPTION[/TD]
     		[/TR]
    [TR]
    [TD]2017-09-10 16:15:05[/TD]
     			[TD]             906128[/TD]
     			[TD]?[/TD]
     			[TD]    17114[/TD]
     			[TD]EXCEPTION[/TD]
     		[/TR]
    [TR]
    [TD]2017-09-10 18:48:13[/TD]
     			[TD]             971441[/TD]
     			[TD]?[/TD]
     			[TD]    29550[/TD]
     			[TD]EXCEPTION[/TD]
     		[/TR]
    [TR]
    [TD]2017-09-10 18:48:14[/TD]
     			[TD]             346865[/TD]
     			[TD]?[/TD]
     			[TD]    29566[/TD]
     			[TD]EXCEPTION[/TD]
     		[/TR]
    [TR]
    [TD]2017-09-10 21:10:38[/TD]
     			[TD]             581326[/TD]
     			[TD]?[/TD]
     			[TD]      7296[/TD]
     			[TD]Exception: The client is not currently connected.[/TD]
     			[TD]EXCEPTION[/TD]
     		[/TR]
    [TR]
    [TD]2017-09-10 21:10:56[/TD]
     			[TD]             593682[/TD]
     			[TD]?[/TD]
     			[TD]      7601[/TD]
     			[TD]EXCEPTION[/TD]
     		[/TR]
    [TR]
    [TD]2017-09-10 21:11:41[/TD]
     			[TD]             882286[/TD]
     			[TD]?[/TD]
     			[TD]      7307[/TD]
     			[TD]EXCEPTION[/TD]
     		[/TR]
    [TR]
    [TD]2017-09-10 21:11:54[/TD]
     			[TD]             306760[/TD]
     			[TD]?[/TD]
     			[TD]     7560[/TD]
     			[TD]EXCEPTION[/TD]
     		[/TR]
    [TR]
    [TD]2017-09-11 00:05:39[/TD]
     			[TD]             675383[/TD]
     			[TD]?[/TD]
     			[TD]      8855[/TD]
     			[TD]EXCEPTION[/TD]
     		[/TR]
    [TR]
    [TD]2017-09-11 00:05:49[/TD]
     			[TD]             142095[/TD]
     			[TD]?[/TD]
     			[TD]      9056[/TD]
     			[TD]EXCEPTION[/TD]
     		[/TR]
    [TR]
     			[TD]             302402[/TD]
     			[TD]?[/TD]
     			[TD]      9058[/TD]
     			[TD]EXCEPTION[/TD]
     		[/TR]
    [TR]
    [TD]2017-09-11 00:06:16[/TD]
     			[TD]             249083[/TD]
     			[TD]?[/TD]
     			[TD]      9615[/TD]
     			[TD]EXCEPTION[/TD]
     		[/TR]
    [TR]
     			[TD]             785778[/TD]
     			[TD]?[/TD]
     			[TD]      9630[/TD]
     			[TD]EXCEPTION[/TD]
     		[/TR]
    [TR]
    [TD]2017-09-11 19:50:15[/TD]
     			[TD]              997911[/TD]
     			[TD]?[/TD]
     			[TD]    13434[/TD]
     			[TD]EXCEPTION[/TD]
     		[/TR]
    [/TABLE]
    Ich denke das sind LBS Exec Prozess Fehler.
    Im Fehler Log wird ja nur die PID angegeben.
    Diese PID ändert sich ja wenn der Prozess geändert wird bzw neu ausgeführt wird.
    Die letzte Fehlermeldung ist ja von heute um 19:50:15 .
    Aber diese PID existiert natürlich jetzt um 20 Uhr nicht mehr.
    Wie kann ich das herausfinden was das ist?
    LG
    Zuletzt geändert von trollmar; 11.09.2017, 19:11.
    Jean-Luc Picard: "Things are only impossible until they are not."
    Ich vermute die kommen von MQTT.
    Man muss wissen welche Exceptions von welchen PHP Libraries geworfen werden.
    Wenn du in Google nach den beiden Exceptions und dem Wort "Exception" suchst, dann steht MQTT bei einer der beiden Exceptions ganz oben.
    Du kannst natürlich auch ein grep auf die Exception Meldung in allen EDOMI php Files machen, dann müsstest du es auch herausbekommen.
    Danach kann man dann das Exception Handling erweitern und diese Exceptions abfangen, darauf reagieren oder zumindest ins Custom Log schreiben.
    Wenn du also herausbekommst, welcher LBS und vor allem in welcher Situation diese Exception wirft, dann kann ich mir das mal ansehen.
    Hoffe das hilft erst mal weiter ...
      ja. das werden die MQTTs sein.
      Leider kann ich keine Ursache ausmachen.
      z.Z kommuniziert eigentlich nur Node-Red via MQTT mit Edomi.
      Die ganze Smartphone nummer hatte ich ja nach DB problemen mit der Server LBSs erstmal auf Eis gelegt.
      Der Traffic ist also z.Z eher gering.
      Ich habe jetzt mal im Mosquitto log mehr infos aktiviert.
      Vielleicht bringt das einen zusammenhang.
      LG
        Hi ich mach dann mal im MQTT Thread weiter.
        #160
        Zuletzt geändert von trollmar; 13.09.2017, 07:58.
