NTP | CentoOS | Edomi
    wenn ich nicht möchte, dass sich CentOS selbst mit einem Internet-Zeitserver (NTP) synchronisiert, sondern nur mit der Firewall (NTP-Server = pfsense.localdomain), was muss ich hier alles auskommentieren bzw. hinzufügen (server pfsense.localdomain) ?
    DANKE vorab !
    nano /etc/ntp.conf
    # For more information about this file, see the man pages
    # ntp.conf(5), ntp_acc(5), ntp_auth(5), ntp_clock(5), ntp_misc(5), ntp_mon(5).
    driftfile /var/lib/ntp/drift
    # Permit time synchronization with our time source, but do not
    # permit the source to query or modify the service on this system.
    restrict default kod nomodify notrap nopeer noquery
    restrict -6 default kod nomodify notrap nopeer noquery
    # Permit all access over the loopback interface.  This could
    # be tightened as well, but to do so would effect some of
    # the administrative functions.
    restrict 127.0.0.1
    restrict -6 ::1
    # Hosts on local network are less restricted.
    #restrict 192.168.1.0 mask 255.255.255.0 nomodify notrap
    # Use public servers from the pool.ntp.org project.
    # Please consider joining the pool (http://www.pool.ntp.org/join.html).
    server 0.centos.pool.ntp.org iburst
    server 1.centos.pool.ntp.org iburst
    server 2.centos.pool.ntp.org iburst
    server 3.centos.pool.ntp.org iburst
    #broadcast 192.168.1.255 autokey        # broadcast server
    #broadcastclient                        # broadcast client
    #broadcast 224.0.1.1 autokey            # multicast server
    #multicastclient 224.0.1.1              # multicast client
    #manycastserver 239.255.254.254         # manycast server
    #manycastclient 239.255.254.254 autokey # manycast client
    # Enable public key cryptography.
    #crypto
    includefile /etc/ntp/crypto/pw
    # Key file containing the keys and key identifiers used when operating
    # with symmetric key cryptography.
    keys /etc/ntp/keys
    # Specify the key identifiers which are trusted.
    #trustedkey 4 8 42
    # Specify the key identifier to use with the ntpdc utility.
    #requestkey 8
    # Specify the key identifier to use with the ntpq utility.
    #controlkey 8
    # Enable writing of statistics records.
    #statistics clockstats cryptostats loopstats peerstats
    Danke und LG, Dariusz
    Die 4 Zeilen die mit "server" anfangen musst du auskommentieren (also ein "#" davor) und dann "server pfsense.localdomain" unten dran schreiben... ntpd neu starten oder rebooten. Mit "ntpq -p" kannst Du sehen gegen welche(n) Server synchronisiert wird.
      DANKE, der Teil bis ntpd -p war OK
      Nun bekomme ich folgende Antwort mit der ich nichts anzufangen weiß:
      [CODE][root@edomi ~]# service ntpd -p
      mit ntpq -p erhalten ich Folgendes:
      [root@edomi ~]# ntpq -p
      No association ID's returned
      Heißt das jetzt dass der Server nicht verfügbar ist oder etwas anderes ?
        Ich habe es jetzt auf die IP-Version geändert … Nun sieht es besser aus - warum auch immer ...
             remote           refid      st t when poll reach   delay   offset  jitter
         10.0.10.1       .INIT.          16 u    -   64    0    0.000    0.000   0.000
          Vermutlich kann pfsense.localdomain nicht per DNS aufgelöst werden.
            Möglich … Mein MBP tut es aber …
            Hauptsache es geht, egal ob via Hostname oder IP-Adresse … (Mein HP-Switch verlangt auch die IP…).
              Deswegen schreibt jonofe auch DNS und nicht mDNS (resp. Zeroconf)
                OK, ich weiß jetzt - hoffe ich - was lost ist … Das CentOS hat nicht die Berechtigung auf die 10.0.100.1 (VLAN1) direkt zuzugreifen und somit nicht auf pfsense.localdomain, somit funktionier nur 10.0.10.1 (VLAN10 in dem CentOS „wohnt“).
                Mit Freigabe des VLAN1 zum Testzweck, erhalte ich auch eine Rückmeldung/Auflösung wenn ich die pfsense.localdomain pinge (mea-culpa):
                [root@edomi ~]# ping pfsense.localdomain
                PING pfsense.localdomain (10.0.100.1) 56(84) bytes of data.
                64 bytes from pfSense.localdomain (10.0.100.1): icmp_seq=1 ttl=64 time=0.344 ms
                64 bytes from pfSense.localdomain (10.0.100.1): icmp_seq=2 ttl=64 time=0.359 ms
                64 bytes from pfSense.localdomain (10.0.100.1): icmp_seq=3 ttl=64 time=0.345 ms
                64 bytes from pfSense.localdomain (10.0.100.1): icmp_seq=4 ttl=64 time=0.357 ms
                  Ich hoffe das mir jemand weiterhelfen kann. Mein Edomi hat seit kurzem ein Zeitproblem, was sich dahingehend äußert, dass die EDOMI-Systemzeit falsch ist. Nach einem Neustart ist sie anfangs korrekt, läuft dann jedoch weg. Hat einer noch eine Idee was das Problem sein kann? Edomi als VM im Proxmox. HWClock läuft laut Ausgabe korrekt.
                  hier der Auszug aus der /etc/ntp.conf
                  restrict 127.0.0.1
                  restrict ::1
                  #restrict 192.168.0.0 mask 255.255.255.0 nomodify notrap
                  #server 0.centos.pool.ntp.org iburst
                  #server 1.centos.pool.ntp.org iburst
                  #server 2.centos.pool.ntp.org iburst
                  #server 3.centos.pool.ntp.org iburst
                  #server ptbtime1.ptb.de
                  #server ptbtime2.ptb.de
                  #server ptbtime3.ptb.de
                  #crypto
                  keys /etc/ntp/keys
                  #trustedkey 4 8 42
                  #requestkey 8
                  #controlkey 8
                  # Disable the monitoring facility to prevent amplification attacks using ntpdc
                  # monlist command when default restrict does not include the noquery flag. See
                  # CVE-2013-5211 for more details.
                  # Note: Monitoring will not be disabled with the limited restriction flag.
                  disable monitor
                  server 192.168.0.1
                  NTP-Server spielt hierbei eine Fritzbox, bisher gab es hier nie Probleme. Selbst wenn ein öffentlicher NTP-Server verwendet wird läuft die Zeit davon:
                  [root@edomi ~]# timedatectl status
                  Local time: Mo 2022-03-21 10:46:26 CET
                  Universal time: Mo 2022-03-21 09:46:26 UTC
                  RTC time: Mo 2022-03-21 09:51:20
                  Time zone: Europe/Berlin (CET, +0100)
                  NTP enabled: yes
                  NTP synchronized: no
                  RTC in local TZ: no
                  DST active: no
                  Last DST change: DST ended at
                  So 2021-10-31 02:59:59 CEST
                  So 2021-10-31 02:00:00 CET
                  Next DST change: DST begins (the clock jumps one hour forward) at
                  So 2022-03-27 01:59:59 CET
                  So 2022-03-27 03:00:00 CEST
                  [root@edomi ~]# hwclock
                  Mo 21 Mär 2022 10:51:26 CET -0.453342 Sekunden
                  [root@edomi ~]# ntpq -pn
                  192.168.0.1 40.95.204.66 3 u 50 64 1 0.988 294204. 0.000
                  [root@edomi ~]# ntpstat
                  unsynchronised
                  polling server every 8 s
