LBS for running command line commands?
    Is there a LBS for running command line commands?
    If not could someone "put" one together. I'm not very good at programming at all so it would be best if someone else could do it...
    What I would like is a simple LBS where a trigger runs a "command line command" that is written in the "output" box. There is no need for reply or error reporting. Just run the command "blind".
    -Kaj
    you can use the exec lbs:
    https://service.knx-user-forum.de/?c...ad&id=19000559
      You can also use the EDOMI integrated shell command, which you can define in the "Konfiguration"-HTTP/UDP/SHELL section and execute via the "Ausgang" LBSes.
