After reinstalling Edomi and restoring my "visu" from a backup I'm having a strange problem with all my diagrams.
If you look at image below, the beginning of the lines that start at 14:00 should have been at 08:00. Therefore the actual last 6 hours is not shown in the diagram.
You can also see that the actual now value is not the same as shown in the diagram.
I have now also tried to change the interval to the same way you did it. Still the same problem.
Btw. I'm now running Edomi in a LXC container in Proxmox, used to run as Virtual machine in Proxmox before.
(Much better performance, only 350MB ram used, instead of 2GB, and around 7% CPU usage instead of 25-40%CPU usage)
