PHP-Code:
$json->time_received
PHP-Code:
$json['time_received']
. . . logic_setOutput($id,1,([B]$json->time_received[/B])); . . .
$json = (json_decode($result)); // Hier steht dein JSON String als Object
###[DEF]###
[name = NEDAP v0.1]
[e#1 = Trigger #init=1]
[e#2 = Loglevel #init=8]
[e#3 = UserID]
[e#4 = Passwort]
[e#5 = PR ID]
[a#1 = time_received]
[a#2 = platform_grid_power]
[a#3 = solar_power]
[a#4 = solar_power_input1]
[a#5 = solar_temperature_input ]
[a#6 = solar_voltage_input1]
[a#7 = solar_current_input1]
[a#8 = solar_power_input2]
[a#9 = solar_temperature_input2 ]
[a#10 = solar_voltage_input2 ]
[a#11 = solar_current_input2 ]
[a#12 = battery_state_of_charge ]
[a#13 = battery_bus_power ]
[a#14 = battery_voltage ]
[a#15 = battery_current ]
[a#16 = battery_pack_temperature ]
[a#17 = dcac_grid_voltage ]
[a#18 = dcac_frequency ]
[a#19 = dcac_grid_power ]
[a#20 = dcac_local_voltage ]
[a#21 = dcac_local_power ]
[a#22 = JSON complete ]
[v#100 = 0.0.1 ] // Version
[v#101 = 19009999 ] // LBS ID
[v#102 = NEDAP ] // LBS name
[v#103 = 0 ] // Log level
[v#104 = 1 ] // One logfile per instance
[v#105 = 0 ] // log ID in each line
###[/DEF]###
###[HELP]###
E1: if >=1 update will be triggered
E2: Enable Logging (0-none|1-emerg|2-alert|3-crit|4-err|5-warning|6-notice|7-info|8-debug)
E3: UserID of myPowerouter.com
E4: Password of myPowerouter.com
E5: PowerrouterID
A01 - LastUpdateTime *
A02 - Sensor Leistung [W] *
A03 - Solar Leistung gesamt [W]*
A04 - Leistung Eingang 1 [W] *
A05 - Temperatur Eingang 1 [°C] *
A06 - Spannung Eingang 1 [V] *
A07 - Stromstärke Eingang 1 [A] *
A08 - Leistung Eingang 2 [W] *
A09 - Temperatur Eingang 2 [°C] *
A10 - Spannung Eingang 2 [V] *
A11 - Stromstärke Eingang 2 [A] *
A12 - Ladezustand Batterie [%]
A13 - Leistung Batterie [W] *
A14 - Spannung Batterie [V] *
A15 - Strom Batterie [A] *
A16 - Batterie Temperatur [°C] *
A17 - Netzspannung [V] *
A18 - Netzfrequenz [Hz] *
A19 - Netzleistung [W] *
A20 - Spannung am Local Out [V] *
A21 - Leistung am Local Out [W] *
A22 - Gesamtstring von mypowerrouter *
V1: Indicator whether daemon is running
V100: Version
V101: LBS Number
V102: Log file name
V103: Log level
V104: One log file per LBS instance
V105: log ID in each log entry
Changelog:
v0.1: Initial version
###[/HELP]###
###[LBS]###
function LB_LBSID($id=NULL)
$E = getLogicEingangDataAll($id);
if ($E[1]['value'] != 0 && $E[1]['refresh'] == 1) {
if (logic_getVar($id, 1) != 1) { // dieses Konstrukt stellt sicher, dass das EXEC-Script nur einmal gestartet wird
logic_setVar($id, 1, 1);
logic_callExec(LBSID, $id);
###[/LBS]###
###[EXEC]###
require (dirname(__FILE__) . "/../../../../main/include/php/incl_lbsexec.php");
set_time_limit(5);
sql_connect();
$version = getLogicElementVar($id, 100);
$lbsNo = getLogicElementVar($id, 101);
$logName = getLogicElementVar($id, 102) . "-LBS$lbsNo";
$logName = preg_replace('/ /', '_', $logName);
if ($E = logic_getInputs($id)) {
$uid = $E[3]['value'];
$upw = $E[4]['value'];
$prid = $E[5]['value'];
$url = 'https://mypowerrouter.com/power_routers/' . $prid . '/logs/1minutes.json?normalize_logs=true&include_last_log=true&solar_power=true&solar_power_input1=true&solar_voltage_input1=true&solar_current_input1=true&solar_temperature_input1=true&solar_power_input2=true&solar_voltage_input2=true&solar_current_input2=true&solar_temperature_input2=true&dcac_grid_power=true&dcac_grid_voltage=true&dcac_frequency=true&dcac_local_power=true&dcac_local_voltage=true&battery_state_of_charge=true&battery_bus_power=true&battery_voltage=true&battery_current=true&battery_pack_temperature=true&platform_grid_power=true&grid_sensor_power_l1=true&grid_sensor_voltage_l1=true&grid_sensor_current_l1=true&grid_sensor_power_l2=true&grid_sensor_voltage_l2=true&grid_sensor_current_l2=true&grid_sensor_power_l3=true&grid_sensor_voltage_l3=true&grid_sensor_current_l3=true&responseContentDataType=json';
$headers = array(
'Accept: application/json',
'Content-Type: application/json'
$ch = curl_init();
curl_setopt($ch, CURLOPT_URL, $url);
curl_setopt($ch, CURLOPT_RETURNTRANSFER, 1);
curl_setopt($ch, CURLOPT_VERBOSE, 1);
curl_setopt($ch, CURLOPT_HTTPHEADER, $headers);
curl_setopt($ch, CURLOPT_USERPWD, "$uid:$upw");
// curl_setopt($curl, CURLOPT_USERPWD, "$uid:$upw");
$result = curl_exec($ch);
$ch_error = curl_error($ch);
curl_close($ch);
if ($ch_error) {
// Error occucred
} else {
if($result){
$json = (json_decode($result,true)); // Hier steht dein JSON String
//OUTPUT
logic_setOutput($id,22,$json); //GESAMTSTRING
logic_setOutput($id,1,($json->{'time_received'}));
logic_setOutput($id,2,($json->{'platform_grid_power'}));
logic_setOutput($id,3,($json->{'solar_power'}));
logic_setOutput($id,4,($json->{'solar_power_input1'}));
logic_setOutput($id,5,($json->{'solar_temperature_input1'}));
logic_setOutput($id,6,($json->{'solar_voltage_input1'}));
logic_setOutput($id,7,($json->{'solar_current_input1'}));
logic_setOutput($id,8,($json->{'solar_power_input2'}));
logic_setOutput($id,9,($json->{'solar_temperature_input2'}));
logic_setOutput($id,10,($json->{'solar_voltage_input2'}));
logic_setOutput($id,11,($json->{'solar_current_input2'}));
logic_setOutput($id,12,($json->{'battery_state_of_charge'}));
logic_setOutput($id,13,($json->{'battery_bus_power'}));
logic_setOutput($id,14,($json->{'battery_voltage'}));
logic_setOutput($id,15,($json->{'battery_current'}));
logic_setOutput($id,16,($json->{'battery_pack_temperature'}));
logic_setOutput($id,17,($json->{'dcac_grid_voltage'}));
logic_setOutput($id,18,($json->{'dcac_frequency'}));
logic_setOutput($id,19,($json->{'dcac_grid_power'}));
logic_setOutput($id,20,($json->{'dcac_local_voltage'}));
logic_setOutput($id,21,($json->{'dcac_local_power'}));
sql_disconnect();
###[/EXEC]###
###[DEF]###
[name = JSON-Abfrage ]
[e#1 TRIGGER = Trigger ]
[e#2 IMPORTANT = Request URL ]
[B][e#3 = Username ]
[e#4 = Password ]
[e#5 = Log level #init=8 ][/B]
[a#1 = Result ]
setLogicElementVar($id, 103, $E[[B]5[/B]]['value']); //set loglevel to #VAR 103
$url = $E[2]['value']; // URL to get content from
[B]$username = $E[3]['value'];
$password = $E[4]['value'];[/B]
[B]$context = stream_context_create(array(
'http' => array(
'header' => "Authorization: Basic " . base64_encode("$username:$password")
));[/B]
if($result = file_get_contents($url[B], false, $context[/B])){
$url = "hier die URL für die Abfrage";
$user = "";
$pass = "";
$headers = array(
'Content-Type: application/json',
$ch = curl_init();
curl_setopt($curl, CURLOPT_USERPWD, "$user:$pass");
curl_close($ch);
if ($ch_error) {
// Error occucred
} else {
if($result){
