defekte Datenbank edomiLive.archivKOData
    Guten Morgen zusammen,
    ich habe wohl eine defekte Datenbank die sich auch nicht mehr reparieren lässt, s. Screenshot.
    Gibt es hierfür eine empfohlene Vorgehensweise um das zu reparieren?
    edit: habe eben mal einen "mysql repair table edomiLive.archivKoData" versucht, scheint aber nichts zu bringen
    Zuletzt geändert von jockele; 08.02.2020, 07:04.
    Was genau war der Output vom repair?
      ich habe leider keinerlei Kenntnisse um das zu interpretieren
      mysql Ver 15.1 Distrib 5.5.64-MariaDB, for Linux (x86_64) using readline 5.1
      Copyright (c) 2000, 2018, Oracle, MariaDB Corporation Ab and others.
      Usage: mysql [OPTIONS] [database]
      Default options are read from the following files in the given order:
      /etc/mysql/my.cnf /etc/my.cnf ~/.my.cnf
      The following groups are read: mysql client client-server client-mariadb
      The following options may be given as the first argument:
      --print-defaults Print the program argument list and exit.
      --no-defaults Don't read default options from any option file.
      The following specify which files/extra groups are read (specified before remaining options):
      --defaults-file=# Only read default options from the given file #.
      --defaults-extra-file=# Read this file after the global files are read.
      --defaults-group-suffix=# Additionally read default groups with # appended as a suffix.
      -?, --help Display this help and exit.
      -I, --help Synonym for -?
      --abort-source-on-error
      Abort 'source filename' operations in case of errors
      --auto-rehash Enable automatic rehashing. One doesn't need to use
      'rehash' to get table and field completion, but startup
      and reconnecting may take a longer time. Disable with
      --disable-auto-rehash.
      (Defaults to on; use --skip-auto-rehash to disable.)
      -A, --no-auto-rehash
      No automatic rehashing. One has to use 'rehash' to get
      table and field completion. This gives a quicker start of
      mysql and disables rehashing on reconnect.
      --auto-vertical-output
      Automatically switch to vertical output mode if the
      result is wider than the terminal width.
      -B, --batch Don't use history file. Disable interactive behavior.
      (Enables --silent.)
      --binary-as-hex Print binary data as hex
      --character-sets-dir=name
      Directory for character set files.
      --column-type-info Display column type information.
      -c, --comments Preserve comments. Send comments to the server. The
      default is --skip-comments (discard comments), enable
      with --comments.
      -C, --compress Use compression in server/client protocol.
      -#, --debug[=#] This is a non-debug version. Catch this and exit.
      --debug-check Check memory and open file usage at exit.
      -T, --debug-info Print some debug info at exit.
      -D, --database=name Database to use.
      --default-character-set=name
      Set the default character set.
      --delimiter=name Delimiter to be used.
      -e, --execute=name Execute command and quit. (Disables --force and history
      file.)
      -E, --vertical Print the output of a query (rows) vertically.
      -f, --force Continue even if we get an SQL error. Sets
      abort-source-on-error to 0
      -G, --named-commands
      Enable named commands. Named commands mean this program's
      internal commands; see mysql> help . When enabled, the
      named commands can be used from any line of the query,
      otherwise only from the first line, before an enter.
      Disable with --disable-named-commands. This option is
      disabled by default.
      -i, --ignore-spaces Ignore space after function names.
      --init-command=name SQL Command to execute when connecting to MySQL server.
      Will automatically be re-executed when reconnecting.
      --local-infile Enable/disable LOAD DATA LOCAL INFILE.
      -b, --no-beep Turn off beep on error.
      -h, --host=name Connect to host.
      -H, --html Produce HTML output.
      -X, --xml Produce XML output.
      --line-numbers Write line numbers for errors.
      (Defaults to on; use --skip-line-numbers to disable.)
      -L, --skip-line-numbers
      Don't write line number for errors.
      -n, --unbuffered Flush buffer after each query.
      --column-names Write column names in results.
      (Defaults to on; use --skip-column-names to disable.)
      -N, --skip-column-names
      Don't write column names in results.
      --sigint-ignore Ignore SIGINT (CTRL-C).
      -o, --one-database Ignore statements except those that occur while the
      default database is the one named at the command line.
      --pager[=name] Pager to use to display results. If you don't supply an
      option, the default pager is taken from your ENV variable
      PAGER. Valid pagers are less, more, cat [> filename],
      etc. See interactive help (\h) also. This option does not
      work in batch mode. Disable with --disable-pager. This
      option is disabled by default.
      -p, --password[=name]
      Password to use when connecting to server. If password is
      not given it's asked from the tty.
      -P, --port=# Port number to use for connection or 0 for default to, in
      order of preference, my.cnf, $MYSQL_TCP_PORT,
      /etc/services, built-in default (3306).
      --progress-reports Get progress reports for long running commands (like
      ALTER TABLE)
      (Defaults to on; use --skip-progress-reports to disable.)
      --prompt=name Set the mysql prompt to this value.
      --protocol=name The protocol to use for connection (tcp, socket, pipe,
      memory).
      -q, --quick Don't cache result, print it row by row. This may slow
      down the server if the output is suspended. Doesn't use
      history file.
      -r, --raw Write fields without conversion. Used with --batch.
      --reconnect Reconnect if the connection is lost. Disable with
      --disable-reconnect. This option is enabled by default.
      (Defaults to on; use --skip-reconnect to disable.)
      -s, --silent Be more silent. Print results with a tab as separator,
      each row on new line.
      -S, --socket=name The socket file to use for connection.
      --ssl Enable SSL for connection (automatically enabled with
      other flags).
      --ssl-ca=name CA file in PEM format (check OpenSSL docs, implies
      --ssl).
      --ssl-capath=name CA directory (check OpenSSL docs, implies --ssl).
      --ssl-cert=name X509 cert in PEM format (implies --ssl).
      --ssl-cipher=name SSL cipher to use (implies --ssl).
      --ssl-key=name X509 key in PEM format (implies --ssl).
      --ssl-verify-server-cert
      Verify server's "Common Name" in its cert against
      hostname used when connecting. This option is disabled by
      default.
      -t, --table Output in table format.
      --tee=name Append everything into outfile. See interactive help (\h)
      also. Does not work in batch mode. Disable with
      --disable-tee. This option is disabled by default.
      -u, --user=name User for login if not current user.
      -U, --safe-updates Only allow UPDATE and DELETE that uses keys.
      -U, --i-am-a-dummy Synonym for option --safe-updates, -U.
      -v, --verbose Write more. (-v -v -v gives the table output format).
      -V, --version Output version information and exit.
      -w, --wait Wait and retry if connection is down.
      --connect-timeout=# Number of seconds before connection timeout.
      --max-allowed-packet=#
      The maximum packet length to send to or receive from
      server.
      --net-buffer-length=#
      The buffer size for TCP/IP and socket communication.
      --select-limit=# Automatic limit for SELECT when using --safe-updates.
      --max-join-size=# Automatic limit for rows in a join when using
      --safe-updates.
      --secure-auth Refuse client connecting to server if it uses old
      (pre-4.1.1) protocol.
      --server-arg=name Send embedded server this as a parameter.
      --show-warnings Show warnings after every statement.
      --plugin-dir=name Directory for client-side plugins.
      --default-auth=name Default authentication client-side plugin to use.
      --binary-mode By default, ASCII '\0' is disallowed and '\r\n' is
      translated to '\n'. This switch turns off both features,
      and also turns off parsing of all clientcommands except
      \C and DELIMITER, in non-interactive mode (for input
      piped to mysql or loaded using the 'source' command).
      This is necessary when processing output from mysqlbinlog
      that may contain blobs.
      Variables (--variable-name=value)
      and boolean options {FALSE|TRUE} Value (after reading options)
      abort-source-on-error FALSE
      auto-rehash TRUE
      auto-vertical-output FALSE
      binary-as-hex FALSE
      character-sets-dir (No default value)
      column-type-info FALSE
      comments FALSE
      compress FALSE
      debug-check FALSE
      debug-info FALSE
      database (No default value)
      default-character-set auto
      delimiter ;
      vertical FALSE
      force FALSE
      named-commands FALSE
      ignore-spaces FALSE
      init-command (No default value)
      local-infile FALSE
      no-beep FALSE
      host (No default value)
      html FALSE
      xml FALSE
      line-numbers TRUE
      unbuffered FALSE
      column-names TRUE
      sigint-ignore FALSE
      port 0
      progress-reports TRUE
      prompt \N [\d]>
      quick FALSE
      raw FALSE
      reconnect TRUE
      socket (No default value)
      ssl FALSE
      ssl-ca (No default value)
      ssl-capath (No default value)
      ssl-cert (No default value)
      ssl-cipher (No default value)
      ssl-key (No default value)
      ssl-verify-server-cert FALSE
      table FALSE
      user (No default value)
      safe-updates FALSE
      i-am-a-dummy FALSE
      connect-timeout 0
      max-allowed-packet 16777216
      net-buffer-length 16384
      select-limit 1000
      max-join-size 1000000
      secure-auth FALSE
      show-warnings FALSE
      plugin-dir (No default value)
      default-auth (No default value)
      binary-mode FALSE
        Diese Ausgabe ist nur ein Hilfetext mit den verfügbaren Optionen für den Befehl. Der kommt normalerweise wenn das Programm mit Deiner Eingabe nichts anfangen kann. Du musst vermutlich eher sowas wie
        "mysqlcheck -r edomiLive archivKoData" eingeben.
        Backup vorher nicht vergessen!
        EDIT: schau mal hier: https://www.a2hosting.com/kb/develop...ses-and-tables
        Zuletzt geändert von tobo; 08.02.2020, 10:55.
          ok, das hatte ich inzwischen auch rausgefunden, sorry bin noch absoluter Linux-Laie.
          Hatte mich zwischenzeitlich mal auf der MariaDB eingeloggt, allerdings passiert da dann nichts mehr nach dem repair-Kommando. Werde Deinen Tipp nachher in Ruhe mal testen, danke vorab schon mal
            so habs grade getestet:
            Output:
            /var/lib/mysql/edomiLive$ mysqlcheck -r edomiLive archivKoData
            Failed to SHOW CREATE TABLE `archivKoData`
            Error: Table './edomiLive/archivKoData' is marked as crashed and last (automatic?) repair failed
            Zuletzt geändert von jockele; 08.02.2020, 11:05.
              nach längerer Recherche und rumprobieren scheint es nun wieder ok zu sein, die Datenbank wird als ok gekennzeichnet.
              Folgender Befehl hat die Datei repariert: myisamchk -f archivKoData
              Allerdings ist diese eine Datenbank mit über 2 Millionen Einträgen mit Abstand die größte, ist das normal oder sollte ich hier was unternehmen?
                2mio ist nicht dramatisch und absolut unkritisch. Jeder Datenpunkt in einem Datenarchiv erzeugt einen Datensatz. Wenn du viele Daten speicherst und lang vorhältst ist das halt so.
                Marcel
                  gibt es eine Beschränkung nach oben hin oder leidet irgendwann mal die Performance?
                    jockele wohl nicht meine DB hat 24Mio Einträge. Dank deinem Input habe ich herausgefunden wo das Problem ist. Respektive das jeder Datenpunkt in Datenarchiv einen Eintrag erstellt.
                    Um das zu reduzieren müssen diese wohl komprimiert oder gelöscht werden.
