Fehler bei LBS 19000192 CamMailer
    Hallo zusammen
    Leider habe ich nochmals ein "Shell"-Problem bei der Installation. Wenn ich die Befehle eingebe, kommen folgende Fehlermeldungen. Kann mir jemand helfen, wo das Problem liegen könnte?
    [root@edomi ~]# php -r "copy('https://getcomposer.org/installer', 'composer-setup.php');"
    [root@edomi ~]# php -r "if (hash_file('sha384', 'composer-setup.php') === file_get_contents('https://composer.github.io/installer.sig')) { echo 'Installer verified'; } else { echo 'Installer corrupt'; unlink('composer-setup.php'); } echo PHP_EOL;" php composer-setup.php
    Installer verified
    [root@edomi ~]# php -r "unlink('composer-setup.php');"
    [root@edomi ~]# mv composer.phar /usr/local/bin/composer
    mv: Aufruf von stat für „composer.phar“ nicht möglich: Datei oder Verzeichnis nicht gefunden
    [root@edomi ~]# cd /usr/local/edomi/main/include/php/
    [root@edomi php]# cd PHPMailer
    [root@edomi PHPMailer]# composer require phpmailer/phpmailer
    Your version of PHP, 5.3.3, is affected by CVE-2013-6420 and cannot safely perform certificate validation, we strongly suggest you upgrade.
    Do not run Composer as root/super user! See https://getcomposer.org/root for details
    Continue as root/super user [yes]? y
    [LogicException]
    ComposerRepository: Undefined $data. Please report at https://github.com/composer/composer/issues/new.
    require [--dev] [--dry-run] [--prefer-source] [--prefer-dist] [--fixed] [--no-suggest] [--no-progress] [--no-update] [--no-install] [--no-scripts] [--update-no-dev] [-w|--update-with-dependencies] [-W|--update-with-all-dependencies] [--with-dependencies] [--with-all-dependencies] [--ignore-platform-req IGNORE-PLATFORM-REQ] [--ignore-platform-reqs] [--prefer-stable] [--prefer-lowest] [--sort-packages] [-o|--optimize-autoloader] [-a|--classmap-authoritative] [--apcu-autoloader] [--apcu-autoloader-prefix APCU-AUTOLOADER-PREFIX] [--] [<packages>]...
    Danke.
    Patrick
    Beim CamMailer fehlt wohl ein Line Break in der Doku:
    müsste eigentlich
    [COLOR=#e74c3c][B]php composer-setup.php[/B][/COLOR]
    sein. Das rote ist ein separater Befehl, der den composer installiert. Durch den fehlenden Line Break, wird der Befehl ignoriert.
    Werde das im DL Portal korrigieren.
      Vielen Dank für deine Antwort. Jetzt komme ich weiter jedoch kommt noch diese Fehlermeldung:
      [LogicException]
      Kannst du mir da ebenfalls noch weiterhelfen?
        Leider nein, da ich kein CentOS6.5 mehr einsetze und es daher auch nicht nachstellen kann.
        In CentOS7 funktioniert es problemlos.
          Servus,
          jetzt habe ich auch ein Problem.
          Bei der Installation des Baustein scheitere ich an dem letzten Schritt: "composer require phpmailer/phpmailer"
          Danach wird das hier bei Putty ausgegeben:
          Using version ^6.2 for phpmailer/phpmailer
          ./composer.json has been updated
          Running composer update phpmailer/phpmailer
          Loading composer repositories with package information
          Updating dependencies
          Nothing to modify in lock file
          Installing dependencies from lock file (including require-dev)
          Package operations: 1 install, 0 updates, 0 removals
          Failed to download phpmailer/phpmailer from dist: The zip extension and unzip command are both missing, skipping.
          Your command-line PHP is using multiple ini files. Run `php --ini` to show them.
          Now trying to download from source
          - Installing phpmailer/phpmailer (v6.2.0): Cloning e38888a75c
          Cloning failed using an ssh key for authentication, enter your GitHub credentials to access private repos
          Head to https://github.com/settings/tokens/n...+on+edomi.frit z.box+2021-01-25+1119
          to retrieve a token. It will be stored in "/root/.config/composer/auth.json" for future use by Composer.
          Token (hidden):
          Oder hier das gleiche als Screenshot:
          Linux ist nicht meine Welt. Google hilft aktuell auch nicht weiter.
          Wo liegt mein Fehler?
          Gruß Andre
          GIRA HomeServer 3, Agfeo AS181plusEIB, AVM Fritz!Box 7390, Gira Keypad, Mobotix M1M Dual, Mobotix T24, iPhone 4iPhone 5, iPad2, iPad3, Kindle Fire
            Mach mal bitte ein
            yum install zip unzip php-zip
            Und dann nochmal versuchen ...
            EDIT: Bei mir lief es übrigens gerade ohne Zusatzinstallationen erfolgreich durch.
            Welches OS verwendest du?
            Zuletzt geändert von jonofe; 25.01.2021, 12:39.
              Danke,
              Installation ist jetzt sauber durch ohne Fehler.
              (Hinweis auf bereits existierendes Verzeichnis...)
              LG Andre
              Gruß Andre
                Edomi läuft unter Cent OS7 in einer virtuellen Maschine vom Proxmox auf einem Intel NUC.
                Dort läuft auch noch in einer eigenen virtuellen Maschine HKKNX um auch mit Siri spielen zu können.
                Gruß Andre
