json String
    json String
    Hallo alle zusammen,
    vielleicht kann mir hier jemand bei Helfen. Ich versuche folgenden JSON Sting aus einander zu pflücken.
    {"result":{"data":[{"key":"2021-12-15 08:21:00","value":"0"},{"key":"2021-12-15 08:41:00","value":"144"},{"key":"2021-12-15 09:00:00","value":"704"},{"key":"2021-12-15 10:00:00","value":"983"},{"key":"2021-12-15 11:00:00","value":"1290"},{"key":"2021-12-15 12:00:00","value":"1366"},{"key":"2021-12-15 13:00:00","value":"1637"},{"key":"2021-12-15 14:00:00","value":"1996"},{"key":"2021-12-15 15:00:00","value":"1335"},{"key":"2021-12-15 16:00:00","value":"226"},{"key":"2021-12-15 16:08:00","value":"48"},{"key":"2021-12-15 16:16:00","value":"0"},{"key":"2021-12-16 08:22:00","value":"0"},{"key":"2021-12-16 08:41:00","value":"144"},{"key":"2021-12-16 09:00:00","value":"708"},{"key":"2021-12-16 10:00:00","value":"858"},{"key":"2021-12-16 11:00:00","value":"1099"},{"key":"2021-12-16 12:00:00","value":"1240"},{"key":"2021-12-16 13:00:00","value":"1168"},{"key":"2021-12-16 14:00:00","value":"984"},{"key":"2021-12-16 15:00:00","value":"649"},{"key":"2021-12-16 16:00:00","value":"153"},{"key":"2021-12-16 16:08:00","value":"36"},{"key":"2021-12-16 16:16:00","value":"0"}]},"message":{"code":"0","type":"success","text": {} ,"info":{"latitude":"52.58","longitude":"8.85", "pl ace":"27245 Kirchdorf, Landkreis Diepholz, Niedersachsen, DE","timezone":"Europe\/Berlin"},"ratelimit":{"period":"3600","limit":"12" ,"remaining":"11"}}}{
    Ich bin ich sehe den Baum voller Wald nicht. Ich habe es mit dem LBS extractor und den LBS Decoder versucht. Aber ich habe wohl immer noch nicht die Syntax dahinter verstanden.
    Danke für eure Hilfe
    Marhal
    Am einfachsten mal hier rein kopieren: http://json.parser.online.fr Da siehst Du den Aufbau besser Die Werte sind dann unter
    data/result[0] -[23]
    zu finden
      Wenn Du dann die Struktur "verstanden" hast schiebst Du den String in den JSON Extractor und ziehst Dir raus was Du brauchst.
        Hallo vento66 Danke für deine schnelle Antwort und für den Link. Das ist schon mal sehr hilfreich.
        Ich bin da auch richtig das ich dafür dann den LBS Decoder brauche um die Wäre herauszubekommen ?
        vielen dank schon mal
        Marhal
          Mit dem Extractor kannst Du Dir quasi einzelne Werte "ziehen". Du musst aber genau angeben was extrahiert werden soll. Der Decoder zieht Dir eine ganze Ebene raus. Mit Bezeichnung UND Wert. Schwer zu erklären....
          Am besten wäre es Du schickst mal Deinen String in beide LBS und schaust Dir den Unterschied an. Evtl. wird es Dir dann klarer. Wir wissen ja jetzt auch nicht genau wie Du die Daten weiterverarbeiten willst.
            gibsonrocker danke für deine Unterstützung. Ich bin da auch echt gerade am verzweifeln wann welcher Baustein der richtige ist. Momentan meckert er mir immer bei dem Decoder an das er ein Array bekommt. Aber ja ein String möchte. Im Grunde möchte halt mir nur die Werte in der Visu anzeigen lassen. Wie 2021-12-15 08:21:00 = 0 . Es ist halt daten von Forecast die ich darstellen möchte. Aber wie gesagt ich bekomme das zerstückeln nicht wirklich hin.
            Marhal
              Sorry, hab gerade keine Zeit. Ich schau es mir später an wenn keiner zuvor kommt.
