Make GA listen to other GA
    Hello,
    I have a dimmer which I send a value to. Fo the value I use + and - with raster.
    I would want that the GA with value to listen to the dimmer status GA, so that when I add/subtract raster value I do it on the current dimming state.
    How can I make this possible in Edomi?
    In Gira HS, there was an option för a GA to listen on a status GA and keep it self updated, is this possible in Edomi aswell?
    Use the GAs for + and - to trigger two Wertauslöser LBS. Connect the Dimmer Staus GA to E2 of the two Wertauslöser. At the Output of the Wertauslöser connect a Addition or Subtraktion LBS and send the result via Ausgangsbox to the Dimmer Set GA.
      Thanks, yes I have considered that option aswell. But I thought it will be alot of logic and internal GA's to take care of.
      I guess there no easier way then? Like the Gira HS letting a GA listen to other GA?
