HOYMILES Inverter auslesen -->JSON Probleme
    ich versuche aus meinem HOYMILES converter folgenden JSON in eine Visu einzubinden.
    Scheitere aber an der Aufsplittung.....JSON sieht wie folgt aus und kommt als $result:
    {"inverter":[[{"fld":"U_DC","unit":"V","val":"39.90"},{"fld": "I_ DC","unit":"A","val":"0.03"},{"fld":"P_DC","unit ": "W","val":"1.20"},{"fld":"YieldDay","unit":"Wh ","v al":"91.00"},{"fld":"YieldTotal","unit":"kWh","v al ":"8.76"},{"fld":"Irradiation","unit":"%","val ":"0 .30"},{"fld":"U_DC","unit":"V","val":"38.40"},{"f l d":"I_DC","unit":"A","val":"0.01"},{"fld":"P_DC "," unit":"W","val":"0.20"},{"fld":"YieldDay","unit":" Wh","val":"43.00"},{"fld":"YieldTotal","unit":"k Wh ","val":"7.38"},{"fld":"Irradiation","unit":"% ","v al":"0.05"},{"fld":"U_AC","unit":"V","val":"0.50 "} ,{"fld":"I_AC","unit":"A","val":"0.00"},{"fld":" P_ AC","unit":"W","val":"0.00"},{"fld":"Q_AC","unit ": "var","val":"0.00"},{"fld":"F_AC","unit":"Hz", "val ":"0.00"},{"fld":"PF_AC","unit":"","val":"0.00 "},{ "fld":"Temp","unit":"°C","val":"7.80"},{"fld": "ALA RM_MES_ID","unit":"","val":"341.00"},{"fld":"Yield Day","unit":"Wh","val":"134.00"},{"fld":"YieldTot a l","unit":"kWh","val":"16.14"},{"fld":"P_DC","u nit ":"W","val":"1.40"},{"fld":"Efficiency","unit" :"%" ,"val":"0.00"}]]}
    SO schaut es im JSON PARSER aus
    image.png​
    Interessant für mich sind die Werte die jeweils als "val" abgebildet sind
    Und hier mein Versuch der Daten Herr zu werden und über eine For Schleife 24 Ausgänge mit jeweils einem Wert zu versorgen :
    $json = json_decode($result);
    $ConvData = $json->inverter;
    for ($i = 1; $i <= 24; $i++)
    foreach ($ConvData as $Wert)
    $v_output = $Wert->val;
    logic_setOutput($id,$i,$Wert->val);
    $i++;
    logic_setOutput($id,26,$url);
    logic_setOutput($id,25,$result);​
    Hat mir jemand einen TIP?
    Liebe Grüße
    Axel
    Warum machst du das nicht mit dem JSON Extractor LBS?
    E1: dein JSON
    E2: inverter|0|val
    E3: inverter|1|val
    E4: inverter|2|val
    E11: inverter|10|val
    usw. mit dem nächsten JSON Extractor LBS...
    Als PHP Code würde es vermutlich so funktionieren:
    PHP-Code:
    $data=json_decode($result,true);
    $i = 1;
    foreach ($data['inverter'] as $value) {
       logic_setOutput($id,$i++,$value['val']);
    Zuletzt geändert von jonofe; 02.02.2023, 16:04.
      Salü Jonofe,
      auf Deine Frage hin waruum ich nicht mit dem JSON Extraktor arbeite fällt mir leider keine gute ANtwort ein......
      HAbe es ind dn LBS kopiert,und es kommt folgender Fehler......
      image.pngWenn ich es richtig verstehe ist das wieder die Objekt/Array Thematik...die ich bisher nicht durchdrungen habe....
      Habe es gerade mit dem LBS probiert, der kriegt das Konstrukt leider nicht aufgelöst.........
      Zuletzt geändert von AxelH; 02.02.2023, 14:16.
        Am besten zeigst Du einen Screenshot der Logik und schreibst hier die Inhalte der Eingänge zur weiteren Fehlersuche.
          image.png​
          E1 Momentan handbetätigt, später ein Minutentimer aus EDOMI
          E2 ist die IP Adresse des INverters
          Der Abruf des o.g. JSON erfolgt über die IP Adresse und einem Adressstring (A26) und kommt soweit zurück und wird in A25 ausgegeben
          image.png​
            In meinem Beispiel ist noch ein Fehler. Dort muss es beim foreach natürlich $data['inverter'] heissen, nicht $result[...]
              Habe jetzt nochmals einen anderen Ansatz verfolgt und nun tutet es......Euch vielen Dank....
              $rawDataAsObj=json_decode($result); // die Liste an Datenobjekten für den ersten [0] Inverter aus der gesamten Antwort der DTU
              $inverterDataSet = $rawDataAsObj->inverter [0]; // iteriere über alle Einträge in der Messdatenliste des Inverters
              for ($i = 0; $i < count($inverterDataSet); ++$i)
              $data = $inverterDataSet[$i];
              logic_setOutput($id,$i+1,$data->val);
              Wenn jemand Interesse hat...einfach nachfragen.
              Die Fehlerbehandlung ist allerdings bisher nicht existent......
              LG
              Axel
                Hallo AxelH!
                Wie holst Du die Daten aus dem Hoymiles? Hast Du eine URL, über die Du das abfragst oder so? Habe nämlich jetzt auch 2 Hoymiles und überlege gerade, wie ich die Werte in meinen HS bekomme.
                Olaf
                  ich hol bei mir die Daten aus der OpenDTU Box:
                  Home - OpenDTU Documentation​
                  Im Prinzip ein ESP32 mit einem Funkmodul (NRF24L01+)
                  Anbindung an Edomi oder HASS mittels MQTT
                  lg
                    Hallo!
                    Hhm, ich suche eigentlich nach einer Möglichkeit ohne weitere Hardware (OpenDTU) oder Software (MQTT Server) auszukommen. Hatte gehofft, dass es eine URL gibt, über die man die Werte per Webabfrage direkt vom Wechselrichter auslesen kann.
                      Ah ok..
                      ich glaube die alte Serie hat nur die proprietäre Kommunikation.
                      Die neu Serie (W zum Schluss) hat integriertes WLAN, so verspricht es halt die Werbung ^^
                      HMS-600W/700W/800W/900W/1000W-2T (Wi-Fi integrated) - Hoymiles​
                      Inwiefern man hier die Daten rausbekommt weiss ich aber leider nicht
                        Hallo miteinander,
                        da mein Hoymiles ein proprietären Funkstandard nutzt muss ich ebenfalls über die OpenDTU Lösung gehen. Dnach kann man aber auf den Webserver der OpenDTU zugreifen und schon flutscht es.....
                          Zumindest ein Commandline-Tool gibt es:
                          https://github.com/suaveolent/hoymiles-wifi
                          Alternativ (obiges Tool basiert auf den gleichen sourcen) einen Docker Container, der das publishen zu mqtt übernimmt:
                          https://github.com/DennisOSRM/hms-mqtt-publisher
                          Zuletzt geändert von fisch3009; 30.08.2024, 12:06. Grund: Autokorrektur korrigiert
                          Matze
                            Hey,
                            hab auch nen neueren Hoymiles und benutze den HMS-MQTT-Publisher.
                            wenn du noch Fragen dazu hast, einfach melden.
                            Gruß Dennis
                            Gruß Dennis
                            Alles geht, außer dem Känguru, das hüpft. :-)
