Govee LBS
    Govee LBS
    Hat jemand GOVEE im Einsatz ?
    Hab begonnen den LBS zu schreiben - recht rudimentär noch alles, hab aber wohl kaum Zeit (und Lust) das ordentlich zu machen.
    Mir reicht die Funktionalität erstmal ( eigentlich reicht on/off)
    Hier mal der LBS:
    PHP-Code:
    ###[DEF]###
    [name            =    Govee  V0.0.1]
    [e#1                        = Enable #init=1]
    [e#2 IMPORTANT    = IP                        ]
    [e#3 TRIGGER = get states                         ]
    [e#4 TRIGGER = PWR state                                ]
    [e#5 TRIGGER = Brightness                                ]
    [e#6 TRIGGER = RGB as hex #init = aabbcc]
    [a#1        = nothing          ]
    ###[/DEF]###
    ###[HELP]###
    ###[/HELP]###
    ###[LBS]###
    function LB_LBSID($id) {
        if ($E=logic_getInputs($id)) {
            if (!isEmpty($E[2]['value'])) {
                    logic_setInputsQueued($id,$E);
                logic_callExec(LBSID,$id);
    ###[/LBS]###
    ###[EXEC]###
    define ("LOG1689","LBS19001689");
    define ("LOG_STEP",'0');
    define ("LOG_ERROR",'1');
    require(dirname(__FILE__)."/../../../../main/include/php/incl_lbsexec.php");
    set_time_limit(0);
    sql_connect();
    $E=logic_getInputsQueued($id);
    $enabled = $E[1]['value'];    // LBS enable from $E[1]
    $deviceIP = $E[2]['value'];    // IP address from $E[2]
    $devicePort = 4003;
    $color['TemInKelvin'] = 7200;
    $command = "";
    if ($enabled) {
        // Create a socket
        $socket = socket_create(AF_INET, SOCK_DGRAM, SOL_UDP);
        if ($socket === false) {
            writeToCustomLog('LOG', 'LOG_ERROR', "socket_create() failed: " . socket_strerror(socket_last_error()));
            $comOK = 0;  // Communication error
        } else {
            // Connect to the Govee device
                if (socket_connect($socket, $deviceIP, $devicePort) == false) {
                writeToCustomLog('LOG', 'LOG_ERROR', "socket_connect() failed: " . socket_strerror(socket_last_error()));
            } else {
                // Define the command to send to the Govee device
                        if ($E[4]['refresh'] == 1){
                            if ($E[4]['value'] == true) {
                        // If $E[4] is true, send a command to turn on the device
                        $command = '{"msg":{"cmd":"turn","data":{"value":1}}}';
                    } else {
                        // If $E[4] is false, send a command to turn off the device
                        $command = '{"msg":{"cmd":"turn","data":{"value":0}}}';
                        if ($E[5]['refresh'] == 1) {
                            $brightness = $E[5]['value'];
                            $command = '{"msg":{"cmd":"brightness","data":{"value":'.$brightness.'}}}';
                        if ($E[6]['refresh'] == 1) {
                            $hex = $E[6]['value'];
                            $color['r'] = hexdec(substr($hex,0,1).substr($hex,0,1));
                            $color['g'] = hexdec(substr($hex,2,1).substr($hex,2,1));
                            $color['b'] = hexdec(substr($hex,4,1).substr($hex,4,1));
                            $command = '{"msg":{"cmd":"colorwc","data":{"color":{"r":'.$color['r'].',"g":'.$color['g'].',"b":'.$color['b'].'}}}}';
                // Send the command to the Govee device
                            writeToCustomLog('LOG', 'LOG_STEP', "writing command =" . $command."");
                if (socket_write($socket, $command, strlen($command)) == false) {
                    writeToCustomLog('LOG', 'LOG_ERROR', "socket_write() failed: " . socket_strerror(socket_last_error()));
                } else {
                // Close the socket
                socket_close($socket);
    sql_disconnect();
    ###[/EXEC]###
    Christian
    __________________
    Ich habe davon eine Lichterkette sowie zwei RBGW LED-Fluter zu Hause, die bei Feierlichkeiten dann und wann im Einsatz sind.
    Da mein Anwendungsfall recht übersichtlich war, habe ich mir nicht die Arbeit gemacht hierfür einen Baustein zu schreiben.
    Aber wenn er im Angebot ist, würde ich ihn bei Zeiten gerne mal testen.
      Hallo Christian,
      habe mal versucht den Code in eine php.Datei zu packen, in EDOMI importiert und versucht ihn zum Laufen zu bekommen.
      Kannst du noch die Ein- und Ausgänge etwas beschreiben? Mit experimentieren habe ich es nicht hinbekommen…
      Danke
        E1 = Enable (muss 1 sein)
        E2 = IP der Leuchte
        E3 ... macht nix
        E4 = PWR = EIN/AUS
        E5 = Brightness = Helligkeit
        E6 = RGB = Farbe als RGB HexWert z.B. aabbcc
        A1... gibt nichts aus
        sorry .. aber mehr kann das (derzeit) nicht
        Christian
        __________________
          alles gut, Danke für die schnelle Rückmeldung und den LBS.
          Ich kann also über E4 schalten, aber bekomme keine Rückmeldung in welchem Zustand (an oder aus) das Govee-Licht ist. OK. Ist erst mal besser als nichts.
          Dann kann ich wenigste das Licht bei meinem Sohn damit zur Sicherheit abends ausschalten...
          Falls du mal etwas erweitern solltest, bitte gern über das Forum einen Hinweis. Ich teste gern...
          VG Mario
            ... muss noch mal nachfragen.
            Die Govee reagiert nicht auf meine "Befehle".
            Da steht dann im Log: 2023-12-08 16:13:0480625726012LOG_STEPwriting command ={"msg":{"cmd":"turn","data":{"value":1}}}, was zumindest für mich heißt, das Commando geht raus.
            Muss ich denn noch an anderer Stelle, z.B. im Govee selbst noch etwas konfigurieren??​
              Zitat von Kaema Beitrag anzeigen
              ... im Govee selbst noch etwas konfigurieren
              https://app-h5.govee.com/user-manual/wlan-guide
              Christian
              __________________
                Schau ich mir mal bei Gelegenheit an, Danke
                  Läuft! Nach Update des Govees und Anforderung des API Schlüssels, ohne in irgend einzubauen, funktioniert es
                    Hallo Christian,
                    Absolut spitze. Ich kann nun meine Toreinfahrt mit den Wegleuchten mit ins Haus einbinden.
                    Vielen lieben Dank für den LBS!
                    Gruß André
                    ...and I thought my jokes were bad!
                      trax
                      sag mal müsste es nicht in dem PHP vom LBS von dir wie folgt heißen?
                      IST
                      $color['TemInKelvin'] = 7200; // MIN:2000 - MAX: 9000
                      SOLL
                      $colorTem['TemInKelvin'] = 7200; // MIN:2000 - MAX: 9000
                        eXec
                        Zitat von eXec Beitrag anzeigen
                        ...müsste es nicht..
                        müssen eher nicht ...🤷‍♂️
                        // Definition #p-code
                        $color = array(
                        'TempInKelvin' => {Dec-Wert aus Eingang},
                        'r' => {Hex-Wert aus Eingang},
                        'g' => {Hex-Wert aus Eingang},
                        'b' => {Hex-Wert aus Eingang}
                        ... ginge natürlich auch, wäre aber wohl besser kein array
                        $colorTemp = 7200; // MIN:2000 - MAX: 9000
                        Soweit ich die API verstanden habe ​kann man entweder eine Farbtemperatur oder einen RGB Wert einstellen
                        - somit reicht eigentlich 1 Eingang, und deshalb verwende ich 1 Variable die beides "kann" (könnte) // #not_yet_implemented.
                        Christian
                        __________________
                          Ah ok. Ich glaub ich habs jetzt verstanden. Tue mir noch etwas schwer mit dem PHP.
                          Danke für die Erläuterung!
